Clutch Noise? Please help
Old 09-24-2009, 06:37 PM
croser2's Avatar
When i release my clutch pedal, my engine/trans makes a weird noise. It is best described has as a loud high pitched moan. I know that sounds weird. It mainly does it before its warmed up, and when I;m stopped and start to take off. It doesn't do it everytime, but more and more now.
I searched and saw posts about the clutch fork pivot bushing. Im not sure that is my problem. I took off the rubber cover and spray a bunch of lube in there, and it didn't help one bit. Also, if I hold the brake and start to let out the clutch to the point where it starts to engage, the noise starts and is a steady tone. The more I let it out and it "fights" against the brake, the noise gets louder. I dont think its the bushing because I can hold the clutch pedal in one position and the noise is constant. Its not like the pivot of the clutch fork is squeeking as it turns, because the pedal is staying in one position.
Any ideas, please?
croser2 is offline
Old 09-24-2009, 07:12 PM
Toolie
knight_yyz's Avatar
sounds like the clutch throw out bearing to me. Noisy at idle, quiet while driving?
knight_yyz is offline
Old 09-24-2009, 07:59 PM
DoubleOmax's Avatar
yah i have the same exact problem, i haven't figured it out yet either. let me know if u find out what it is, i'm gonna have my mechanic friend check it out next week.
DoubleOmax is offline
Old 09-24-2009, 11:12 PM
Derrick2k2SE's Avatar
Sounds like the TO bearing. The only way to tell exactly what's going on is to pull the tranny. You may as well plan on a clutch swap while you're in there.
Be careful about spraying lube in there. There's no reason to do it. If you manage to get it on the clutch friction material you could ruin it.
Derrick2k2SE is offline
Old 09-25-2009, 09:00 AM
jvienneau's Avatar
If it's making it with the clutch pedal depressed, it's probably the throwout bearing. If it's making it with the clutch pedal not depressed, it's probably the transmission input shaft bearing (the throughout bearing isn't turning with the pedal all the way up unless something else is wrong).
jvienneau is offline
Old 09-25-2009, 09:36 AM
Fred Stone's Avatar
Been there, done that, (three diferent cars, one was Maxima) I'm betting on the Throw Out bearing.
No, I don't ride a clutch and burn out throw out bearings, I'm just old and have had a LOT of high milage cars.
Fred Stone is offline
Old 09-25-2009, 02:05 PM
croser2's Avatar
I had a TOB go bad on my NX. I knew exactly what it was and replaced it myself, so I know something about TOBs. But that was a classic example. This time, its different. Doesn't do it with the clutch pedal all the way in. Doesn't do it when shifting. Doesn't do it at idle if in nuetral. Its just not the typical signs, but I don't know what else it could be. And it kinda comes and goes, seems worse when it rains. Just wondering if anyone else had something similiar with them. I'm just not convinced its the TOB and would like to be sure before I tear into it.
croser2 is offline
Old 01-27-2010, 06:52 PM
croser2's Avatar
Any other suggestions?
croser2 is offline
Old 01-28-2010, 07:20 AM
ColtMax's Avatar
I am having a similar issue. A couple of months after replacing my clutch assembly and TOB with an exedy kit, a high pitch squeal (pit pit pit pit pit...) as appeared when clutch pedal is released.
I suspect a friction between pressure plate fingers and the TOB. I really dont feel like dropping the tranny again... What a pain!
ColtMax is offline
Old 02-02-2010, 08:03 AM
croser2's Avatar
^ That does sound like a possibilty. Thanks
croser2 is offline
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
D Mason
06-21-2016 04:43 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: Clutch Noise? Please help
