max owners with staggered wheels
Old Sep 28, 2009 | 11:31 AM
icemanf14d's Avatar
Sunlit Sand Beauty
hey I've got a problem. i just got 350z wheels with tires in decent condition.
back: 245/45/18
front: 225/45/18
im running into some vibrations (just my luck)
what kind of tires are you guys with staggered wheels running? anyone run into this kind of problem?
i honestly dont know much about wheels and rims so i need some help...
Old Sep 28, 2009 | 11:47 AM
Nelsito65's Avatar
back: 245/45/18
front: 225/45/18
I've been running 235/45/17 front and 245/45/17 back and don't have any vibration issues. You might not be used to those tire sizes and are feeling the difference in the ride quality. What tire size(s) were you running before?
Old Sep 28, 2009 | 11:49 AM
icemanf14d's Avatar
Sunlit Sand Beauty
before i had the stock GLE rims with 225/50/17 all around
well its not just ride quality, there IS definitely vibration.
the wheel shakes a little as does the front or the car....in fact it even seems to have a rythm of vibration...
Old Sep 28, 2009 | 11:56 AM
Feldman's Avatar
I have 350z rims with 225/50r17 in front and 235/50r17 in the rears with no vibration rubbing or any other issues.
You might want to try having them balanced
Old Sep 28, 2009 | 12:04 PM
Nelsito65's Avatar
I went from stock GLE 225/55/16 to the ones I have now and I definitely felt the ride not being as smooth as before, due to the shorter tire wall height. In your case, your side wall height is shorter than your original tires (more so on the front tires than the rear ones) so you'll feel that difference too. If you are also experiencing some shaking then it could be a tire balancing issue. You might want to make sure that the lug nuts are tight on all 4, just in case.
Old Sep 28, 2009 | 12:06 PM
icemanf14d's Avatar
Sunlit Sand Beauty
im so screwed.
anybody know if the 18" wheels on 350z are all the same size? 18x8?
im thinking of just replacing all 4 tires and run 235/45/18
would that be possible?
Old Sep 28, 2009 | 12:24 PM
MadMax07SL's Avatar
Make sure you're new rims aren't bent before you invest in more tires. Might be why you got them at such a good deal...
Old Sep 28, 2009 | 12:25 PM
icemanf14d's Avatar
Sunlit Sand Beauty
i dont know how to check ...rims and tires are completely unknown to me unfortunately. and if i take em somewher theyll charge me and put me in an even deeper hole lol
Old Sep 28, 2009 | 12:32 PM
Nelsito65's Avatar
Tire balancing can be as low as $5 per tire at some walmart auto centers. If you have any by you and if it makes sense to you, consider investing $20 before going any deeper...
Old Sep 28, 2009 | 12:34 PM
icemanf14d's Avatar
Sunlit Sand Beauty
thats a good deal. ill do that thanks!
so as far as 235/45/18 all around..is that good?
Old Sep 28, 2009 | 12:38 PM
Nelsito65's Avatar
.....so as far as 235/45/18 all around..is that good?
I don't see why not.
Old Sep 28, 2009 | 01:04 PM
MadMax07SL's Avatar
They can measure that on the spin balancer. just ask them when you're getting the balance checked to have them look for a misshaped wheel. They'll know what to do.
Old Sep 28, 2009 | 01:10 PM
Merxima's Avatar
Like previously mentioned, I would try getting them balanced
Old Sep 28, 2009 | 03:32 PM
icemanf14d's Avatar
Sunlit Sand Beauty
so i went and the guy at pep boys figured out what the problem was, the dumbass who installed the tires this morning for me put the front ones backwards. so the guy at pepboys (this isnt where i got em installed) was kind enough to move the right to left and left to right and then balanced them for me--all for free..
i got on the highway and there was minimal vibration on the wheel, nothing noticeable...just normal worn tire feel. i still have a little bit of vibration on the seat so im getting the rear tires re balanced tomm and hopefully thatll do it for now...
thanks for everyone who made suggestions, i REALLY appreciate it.
maxima.org is the best...
Old Sep 28, 2009 | 03:35 PM
icemanf14d's Avatar
Sunlit Sand Beauty
i called tire rack and they didnt know wether it would work or not...
so im thinking of leaving the 245s on the back and change the 225 on the front to 235s
thanks for your suggestion
Old Sep 28, 2009 | 04:41 PM
gxe2se's Avatar
I ran 235/45/18 all around and it was fine (non-staggered) Yes, get them balanced to remove and reduce the vibration... Look for hunter GPS 9000 machine... its a ROAD FORCE balance machine that gets rid of unwanted shakes from out of round or slightly bend rims.
check out: http://forums.maxima.org/5th-generat...www.hunter.com
most infiniti, nissan dealerships have it. My Local Goodyear Gemini had it too.
BUT its kinda costly...
Old Sep 28, 2009 | 06:13 PM
Grand_hustle17's Avatar
235/40/18 or 245/40/18 in the rear
Old Sep 29, 2009 | 11:54 AM
perkman87's Avatar
Good Job hustle perfect tire size
Old Sep 29, 2009 | 12:21 PM
zax 20th ae's Avatar
pepboys?pepboys?.....pepboys r u serious you couldnt pay me to let any DUMBASS at pepboys even touch my car. let alone mount and balance wheels that my investment is riding on.
Old Sep 29, 2009 | 03:12 PM
ShippedOut's Avatar
Im running
235/40/18 Front
245/40/18 Rears
No vibrations at all, Just not as smooth as my stock 16s especially on the highway
dank4us
34
Jun 10, 2024 03:45 AM
Zenyatta
Aug 30, 2015 05:03 PM
WeetoddA32
Aug 16, 2015 12:45 PM
Mcnabb34
Aug 11, 2015 08:45 PM
