Installing ES Bushings under the Shifter Assembly
Old Aug 31, 2012 | 06:16 PM
  #81
ATL's Avatar
ATL
i ordered a set of these from amazon. $22 with 2 day shipping iirc
Old Aug 31, 2012 | 06:23 PM
  #82
MaxinO2's Avatar
Yes I just ordered these, came out to $23.87 with shipping from http://www.energysuspensionparts.com...sp?prod=7.1115
Old Aug 31, 2012 | 06:51 PM
  #83
ATL's Avatar
ATL
amazon ftmfw!!! i ordered these 2 things the 29th and they were here today and those prices are hard to beat
Old Oct 14, 2012 | 12:08 AM
  #84
defiance's Avatar
I have to take apart the center console to investigate the E-brake not working. This write up helps me too Thanks Rochester !
Old Oct 14, 2012 | 07:52 PM
  #85
TSelanne's Avatar
Are the benefits the same for a 2000 or 2001? Maybe that's a stupid question(?) as I read the thread and didn't see anything about 5.0 gens.
Old Oct 15, 2012 | 05:33 AM
  #86
Rochester's Avatar
You're very welcome.
No. The shifter assemblies and linkage are different.
Old Jun 20, 2013 | 05:20 PM
  #87
AWeb80's Avatar
going to bump an old thread here.
First, thanks for the write up. The ES instructions were a bit vague and I wasn't sure how to get the consol apart. Thanks.
I do have a tip to put the banjo bushings in. Put a bolt that is smaller, not snug, through the bushing and use a nut to tighten it in place. I think the pictures explain themselves. It took all of 2 minutes per bushing. It pushes it in square and is MUCH easier than trying to squeeze it in w/ pliers.
*don't mind the extra nuts i have on the left side....they are just there as spacers so I didn't have to thread the actual nut on so far. *
Old Jun 20, 2013 | 05:51 PM
  #88
rebelhell's Avatar
Correct me if I'm wrong here...
This kit comes with four pairs of the smaller bushings for the plastic shifter assembly, and two large bushings for the cable end banjo fittings. But aren't there FOUR banjo fittings? Two under the console and two at the transmission? Why wouldn't this kit come with all four bushings?
Old Jun 20, 2013 | 08:23 PM
  #89
george__'s Avatar
no point for automatic?
Old Jun 21, 2013 | 05:20 AM
  #90
Rochester's Avatar
You are very welcome. Cudos for clever thinking on installation for banjo bushings. Excellent pictures for explanation.
Thumbs-up, AWeb80.
Old Jun 21, 2013 | 05:22 AM
  #91
Rochester's Avatar
No, there are only two banjo fittings, one on each end of the cable.
LOL, wat?
Old Jun 21, 2013 | 06:57 AM
  #92
AWeb80's Avatar
Thumbs-up, AWeb80.
Thanks. I figured I'd save someone the grief. I did **** around with a vice grip in the engine bay for about 15 minutes and ran out of curse words.
I figured there has to be an easier way. I figured pulling it through night work so grabbed a random bolt and went to town. I was more mad I didn't think of it sooner.
It might be a good thing to copy this info to your OP so it's not missed.
Old Jun 21, 2013 | 07:14 AM
  #93
TallTom's Avatar
Vice grips + dab of dishwashing liquid for lube works well.
Old Jun 21, 2013 | 08:09 AM
  #94
rebelhell's Avatar
There are two cables...each having two ends...
LOL, wat?
My sentiments exactly.
Old Jun 21, 2013 | 12:52 PM
  #95
rebelhell's Avatar
Bump for more info from someone who's done this...
I bought the shift bushing kit when I did my clutch job and used both of the larger bushings under the hood for the two shift cables on the tranny. I went to do the other end and realized I needed a large bushing on that side as well. And from the picture above, maybe a second for the cable connected under the plastic shifter assembly.
Old Jun 22, 2013 | 03:43 PM
  #96
rebelhell's Avatar
I can't believe I'm the only one to have caught this. Oh well, I'm going to order another set of bushings and take some pictures of the COMPLETE install.
Old Jun 22, 2013 | 09:32 PM
  #97
AWeb80's Avatar
The second cable on the ****er assembly will NOT accept a banjo bushing. It's just a plastic connection that snaps on to another piece of plastic...or metal. I don't remember. All I know is there is no bushing there.
AFAIK, the whole kit seems plenty for me. I honestly don't thing the 4 mounts on the floor are needed....but they were supplied so I did them. I think just the two banjo bushings were plenty.
Old Jun 22, 2013 | 10:40 PM
  #98
rebelhell's Avatar
Well then there's at least three then. The two on the transmission and one on the shifter in the console.
Old Jun 23, 2013 | 03:39 AM
  #99
JonBlz's Avatar
a.k.a. STuNtMAN
i did this a long time ago i ordered 2 sets of ES shifter bushings two large ones under the hood for the cables and 1 large one for the shifter and now i have a bunch of left overs.....if no one noticed this before it's ashame lol
Old Jun 23, 2013 | 12:24 PM
  #100
AWeb80's Avatar
that 'secondary' cable only moves when you pushed the shifter from side to side. I don't think it is worth paying for another set just to do that bushing. The two that you change initially make the biggest difference.
Old Jun 23, 2013 | 12:37 PM
  #101
rebelhell's Avatar
I agree after looking at the mechanism that it is likely a pointless endeavor. However, I've already used both bushings under the hood when I did my clutch job and would still like to have the other bushing in the console where it should have gone in the first place. Thanks for the heads up though. I wish the directions that came with the bushings had clarified this and exactly which cable we were supposed to modify. Especially considering what a pain in the A$$ it was to change the second cable bushing under the hood. But done is done.
MaxLife17
Jun 27, 2019 01:37 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
I<3 A32's
Sep 10, 2015 11:07 AM
