My car is pathetic!
Old Dec 1, 2001 | 03:48 PM
Cisco's Avatar
My car is pathetic!
Here's the rundown:
Went to the track with my Max. Weather was 65 degress and sunny. My best time was:
16.11- 1/4 Mile
85.72 MPH
60ft- 2.419
I have a Cattman Y-pipe, HKS exhaust and Stillen Intake and was sure I'd be doing 15.3-15.7, but my damn car was not even close. Seems like i was the slowest car there. I did have an opportunity to meet another Org member, forgot his name but his car was gutted out and he was running Nitrous. He had a 4th gen and his car was damn fast running something like 14.1 in the 1/4 if I remember. My car officially is slow!!
Coming home, I raced a new IS300 and he also gave me a beating. From around 0-60 he had a quarter fender on me then we just stopped. I'm thinking that if we raced longer, I woulda been ahead of him.
All in all, I'm not spending another dime on performance mod's and going to spend $$ on enhancing the style.
GC
Old Dec 1, 2001 | 03:52 PM
MichaelAE's Avatar
Automatic, I assume? Even then, those are worse than stock. You sure you're not misfiring or something? Check your spark plugs recently?
Old Dec 1, 2001 | 04:04 PM
Sonic's Avatar
Check your knock sensor, that is a rather bad time...
Old Dec 1, 2001 | 04:53 PM
Cisco's Avatar
Yes, My car is an Automatic. Whats a knock sensor and how do you check it?
GC
Old Dec 1, 2001 | 05:06 PM
Cisco's Avatar
By the way, as a benchmark, I was running 16.4 @84 MPH before the mods came on. Maybe my expectations from my mods is too high. What do u guys think I should be running?
GC
Old Dec 1, 2001 | 05:10 PM
Sonic's Avatar
With the mods you have, you should be around 15.4. I've seen bone stock 5th gens running 15.7 consistently. The knock sensor is a 'microphone' that detects detonation (misfire) in the engine, and retards timing in order to correct it. You really don't notice it unless you are going WOT quite a lot, like at the track. You would need atChiltons(do they have them for the 5th gens yet?) to test it.
Old Dec 1, 2001 | 05:55 PM
UMD_MaxSE's Avatar
Got Bent?
what kind of gas did you have in there?
Old Dec 1, 2001 | 06:12 PM
Cisco's Avatar
I always put 93+ octane. I was about 3/4 full. Any other suggestion guys? Also, how can I enhance the low end pull?
GC
Old Dec 1, 2001 | 06:19 PM
Sonic's Avatar
Dunno, both your time and speed are lower than they should be... Fuel filter? Air filter? Intake/exhaust leak?
Old Dec 1, 2001 | 06:22 PM
tomz17's Avatar
ahh... racing with your E-brake on ??
-Tom Z.
Old Dec 1, 2001 | 09:51 PM
Shinnjee's Avatar
Re: My car is pathetic!
Originally posted by Cisco
Here's the rundown:
16.11- 1/4 Mile
85.72 MPH
60ft- 2.419
GC
Sorry to hear that, did you shift your auto from 1-2-D or did you just floor it?
Old Dec 1, 2001 | 10:44 PM
Cisco's Avatar
Re: Re: My car is pathetic!
Just floored it dude, minimal wheel spin too.
GC
Old Dec 1, 2001 | 10:57 PM
2001SE's Avatar
Did you Torque Brake?
Old Dec 1, 2001 | 10:59 PM
Cisco's Avatar
Not at all. With these mod's I have, I should not have to do any of that $hit. BTW, how do I torque brake?
GC
Old Dec 1, 2001 | 11:08 PM
Cumalot's Avatar
GC
You still need to torque/power brake. I have a SC and still plan to torque brake it, maybe not as high around 1500rpms or so. You'll get a better launch if you torque brake. That should lower your 60ft a bit.
Old Dec 1, 2001 | 11:11 PM
Cisco's Avatar
Maybe my expectations are too high. I was looking to hit mid 15's but was not even close!
GC
Old Dec 1, 2001 | 11:21 PM
Cumalot's Avatar
GC
Actually, your expecations are right. You should hit mid to low 15s with those mods. I got a 15.4 when all I had was y-pipe, cai, and catback exhaust. So, it's definitely doable. I have a 4th gen auto though.
Old Dec 1, 2001 | 11:50 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
You should be able to do a bit better than a 2.4xx 60' time. And the guys are right, you do still need to power-brake and also manually shift from 1-2-D and time the shifts so that the tranny shifts right at redline instead of short-shifting a bit like it tends to do.
16's from a dead stop like that would not be unexpected.
If you really want to go for the best time, remove jack and spare, and reduce your front tire pressures to around 20 psi.
An automagic Maxima is capable of mid-15's (15.5-15.7) bone stock if you launch it and shift it right
Old Dec 2, 2001 | 12:56 AM
shadou's Avatar
Your right about that. I have a 5th. gen, mostly stock with no performance mods at all and the very first time I ran, I came in at 15.5. I'm surprised that a 5th. gen bone stock is up in the 16's. They shouldn't be like you said.
Shadou
Old Dec 2, 2001 | 05:04 AM
UMD_MaxSE's Avatar
Got Bent?
*Launch it by flashing the TC
*Shift manually.
*reduce tire pressure
*Don't run with a full tank of gas
Old Dec 2, 2001 | 06:02 AM
nc00max
I have a 5G auto with JWT intake, y-pipe, UDP, and bald *** tires and I got 15.25 last time with it being in the mid-70's out. I didn't lower pressures, had a little over half a tank (overestimated how far to Richmond), and had my spare and jack still in the car. That was tq braking and manually shifting. Even just leaving it in drive and flooring it got me a 15.5x, which also tells me I need to work on my launch still. Like everyone else said, I'd check your knock sensors and plugs to make sure everything's good to go before you run next time. Good luck!
Old Dec 2, 2001 | 05:39 PM
Driven EF9's Avatar
GC
well, there's your answer. it's also called power-braking.
Old Dec 2, 2001 | 10:00 PM
MR2177's Avatar
Can you guys use any device like an Autotap to check Knock Retard, timing advance, misfires, etc? That would be very helpful in determining what aspect of your car needs tuning/fixing. Based on my limited experience w/Maximas, everyone is right on the money with the Torque braking advice and manually shifting your tranny, that early shift 1-2 is robbing you maybe a tenth or two, and the torque braking would get those 60' times down, also .1-.2 IMO.
Old Dec 2, 2001 | 10:21 PM
CoolMax's Avatar
is invisible
GC
"I bet those Civics give you a run in your 5th gen."
Right back at you.
Old Dec 3, 2001 | 02:44 AM
Cisco's Avatar
Ha ha ha...Not! I'll still spank U in your whip! JK
GC
Right back at you.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
