My trunk slams shut
Old Nov 6, 2009 | 12:12 PM
acgrunt19's Avatar
My trunk slams shut
I installed a OEM spoiler on my 03 maxima. No problems there, however the weight of the spoiler causes the trunk to slam and it doesnt pop open like it used too.
I was just wondering what keep the trunk lids from slamming when the spoilers are put on the right from the factory?
Old Nov 6, 2009 | 12:22 PM
Rhyno02's Avatar
My trunk is the same as yours and my spoiler is from the factory. I am curious to see what answers come up...
Old Nov 6, 2009 | 12:27 PM
acgrunt19's Avatar
Right from the factory and it slams??
Now im curious to see if there is an OEM solution to the problem. I thought originally if it came from the dealer with a spoiler that the slamming was not an issure.
If anyone has any pictures of the inside of the trunk, that would be a big help
Thanks guys
Old Nov 6, 2009 | 01:01 PM
Nelsito65's Avatar
Nothing keeps them from slamming. Mine is factory-installed and it also slams if I let it go from, let's say, the midway position (I'm assuming yours stays put when it's all the way open and it just slams if you let it go as you bring it down to close it).
Nothing to adjust in my trunk, as someone suggested in your other thread.
When I open it, it barely just unlatches the hook but it will not go up at all.
Old Nov 6, 2009 | 01:37 PM
Ghost_54's Avatar
Mine is also from the factory, and when you pop it... it unlocks but doesn't open all the way up if that is what your are expecting. Once it is opened it stays all the way up until you decide to close it, it is a pretty simple hinge that holds it there are no hydrolic arms to lift it on its own.
Old Nov 6, 2009 | 02:09 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
What he said....
Old Nov 6, 2009 | 02:22 PM
cmd26's Avatar
Hey wings r heavy so the trunk is going to slam. Just close it carefully thats wut i do.
Old Nov 6, 2009 | 02:29 PM
fflint_18's Avatar
What they all said. It barely pops when I unlock it. Almost like it's sticking to the weather stripping.
And if I let it go from anywhere it slams pretty hard.
Old Nov 6, 2009 | 05:47 PM
StenholmEngineering's Avatar
jsut keep it easy when closin it, mine is oem and it shuts pretty hard
Old Nov 6, 2009 | 06:14 PM
nsnrider's Avatar
get stiffer tention rods for the trunk. it will make the trunk feel a bit lighter though it will not make it go up all the way by itself.
Old Nov 6, 2009 | 06:16 PM
nsnrider's Avatar
also check your weather stripping around the trunk.
Old Nov 6, 2009 | 06:32 PM
JAMAICANLOVRBOY's Avatar
the spoilers are heavy, and maximas dont have trunk shocks to help with the added weight. i noticed the same thing when i added a spoiler to my car.
Old Nov 6, 2009 | 06:50 PM
Gemner's Avatar
Wait, when you pressed the trunk button (pre-spoiler) it opened all the way up?!?! Must be nice
Old Nov 7, 2009 | 11:58 PM
FlipCpt45's Avatar
... mine doesn't slam.. and i have ghetto sound dampening on the trunk.. i guess i just always carefully put down my trunk lid... It closes if i lightly press down on it when its sitting on the latch
Old Nov 9, 2009 | 06:10 AM
acgrunt19's Avatar
i carefully close it every time.....its juts annoying when someone else does it and it sounds like someone rear ended me
Old Nov 19, 2009 | 06:34 PM
11-YEARS-DEALER-EXP's Avatar
Dealer sells tension rod kits for the trunk for the extra spoiler weight. These are very tricky and dangerous to put in if you dont know what you are doing so be carefull !!
Old Nov 20, 2009 | 07:50 AM
phxgold's Avatar
unless you put them there
http://video.cardomain.com/VideoPlayer.aspx?id=705587
Old Mar 28, 2018 | 09:53 AM
egray's Avatar
2002 Maxima with spoiler does not slam
My spoiler was on from the factor and it never slammed - closed as easily as if the spoiler was not there. It popped open all the way and closed without slamming. But, about a year ago, we had to have some work done due to a deer encounter and we paid extra for the repair shop to paint the spoiler. They removed the spoiler to paint, put it back on and now it has to be manually lifted and when you close it - it slams hard. You have to be very careful or it will catch your hands. I took it back and guy said there was absolutely nothing they could have done to cause this. Not true - something was released when they removed the spoiler and was not reset. I have heard there is an additional spring or springs added somewhere to handle this additional weight. I have not gone to the local dealership to find out what it needs, but they should certainly know the answer. There is defintely a way to fix this - I just don't know what it is.
Old Mar 28, 2018 | 01:56 PM
Roymg's Avatar
Hmmm..my 03 when new came with a spoiler and the trunk never raised itself and you have to avoid slamming it when closing. I assumed all these years that was normal and still is.
Old Mar 28, 2018 | 05:01 PM
egray's Avatar
My spoiler was on the car when I purchased it new, so the factory rather than the dealership had put it on. It's a GLE so perhaps they only add whatever part is needed on certain models. I would expect the dealership could add this extra part if you requested (for a cost, of course) - I'm guessing. Some years ago, I purchased a Toyota and had the dealership add a back rack. It slammed shut and you had to lift. I hated that. Since mine no longer opens and closes as it should and did before, I know your frustration - especially as you are carrying groceries out of it. If I were going to keep the car, I'd probably check into having the dealership add whatever is needed, but I plan to sell it. It's just too bad that if you pay for a spoiler to be added, that the installation and cost does not include fixing it properly.
Old Mar 29, 2018 | 06:12 AM
Roymg's Avatar
I've spent enough $ on this car in 15 yrs but have never been concerned about the trunk Hope to get 2 more yrs out of it. Has been a good one but u need to keep them up
Also have an 08 max and had a 94.
REDinLV
Aug 15, 2024 12:30 AM
DJLAX152
May 4, 2021 11:46 AM
hayne
Oct 5, 2015 11:53 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
EdRomo86
Sep 12, 2015 07:49 PM
