UTEC Installed
Old Mar 30, 2010 | 08:20 AM
  #41
Shift_Max's Avatar
Originally Posted by SurraTT
if your app wires are wrong then yes it will rev SLOW to 2500 rpm or so, thats with the pedal to the floor too!
That is the exact issue I am having. With the gas pedal depressed to the floor, the car revs very slowly and then hits a limiter around the 2k rpm range. I assumed it had something to do with my set-up so i adjusted the 0% collumn to compensate for the bigger injectors. However that did not fix the issue.
Might be a stupid question but can anybody verify the pin-outs to prevent this issue?
Old Mar 30, 2010 | 08:29 AM
  #42
SurraTT's Avatar
HR Swap Pioneer
First things first.
turn the car ON, but engine not running. plug laptop up to UTEC go to dashboard.
see what the throttle % says i SHOOULD be around 0% its possible to be 1, 2, 3, 4, % due to calibration.
IF its 0% press the gas pedal and it should go up accordingly all the way to 100%.
if thats not the case there is not need to even crank the engine.
I ALWAYS checked this before ever attempting to crank a car with a Utec plugged in.
Old Mar 30, 2010 | 03:44 PM
  #43
Gemner's Avatar
i suggested that yesterday. Thats SUCH an easy check, i dont understand why you are resisting doing this
Old Feb 5, 2011 | 12:26 PM
  #44
KRRZ350's Avatar
Since this is the most informative utec thread 'round here I wanted to add the updates from my350z
1: There is a DBW update in the software, if you have your wiring on point & still have a problem look into this (I might post link later)
2: some people were having problems in the 4K+ rpm range, massive drop in power etc resulting from noise to the injectors, (not to be confused with momentary hiccups from overly sensitive knock count). On the back of the utec there is a 12 pin molex connector with a red & black wire coming out of it, you need to ground that black wire to a nice separate chassis ground.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
