Turn signals do not work after Bose to aftermakret swap
Old Nov 29, 2009 | 02:51 PM
stas29's Avatar
I just installed my aftermarket stereo in my 02 I35 and now my turn signals do not work. I also grounded the brown/white wire which fixed my Trip button and headlights. Now, my turn signals do not work - no flashing and no noise. However, my fog light's corner light does switch on when I cycle through turns. Any ideas. Do I need to ground something else?
It's a bit dangerous do drive with turn signal lights.
Thanks!!!!!
Old Nov 29, 2009 | 03:04 PM
KiNgJaMEs's Avatar
Plug your Hazard Button / switch up. its under your radio
Old Nov 29, 2009 | 03:15 PM
stas29's Avatar
THANKS A BUNCH!!!
Which reminds me, my friends Daewoo would not start because it had a bad bulb, LOL. Who could have of thought!
Old Nov 29, 2009 | 03:19 PM
KiNgJaMEs's Avatar
Was that the problem??
Old Nov 29, 2009 | 03:46 PM
513Chillz's Avatar
I swapped my BOSE Unit to a aftermarket then i had similar issues lights on door and climate and speedometer dont illuminate please ADVISE
Old Nov 29, 2009 | 04:00 PM
KiNgJaMEs's Avatar
IIRC you shouldnt hook up the Orange wire which is Illumination if you hooked that one up your probably fried your dimmer switch.
Old Nov 29, 2009 | 04:19 PM
stas29's Avatar
Yes, Problem solved
Old Nov 29, 2009 | 04:32 PM
stas29's Avatar
You are right, it no longer changes brightness. Will a dimmer switch work from a 97 maxima SE?
Old Aug 9, 2010 | 02:01 PM
spreenyk888's Avatar
i know this is an old thread but i have the same problem currently on an 04 i35....what do you mean by this?
Old Aug 9, 2010 | 02:08 PM
zero2sixtyZ's Avatar
You embarrass me.
The hazard switch is part of the circuit for the turn signals. If it's not plugged in, the turn signals will not work.
Old Aug 9, 2010 | 02:58 PM
oh ok ill check that out....although the signals were working after the headunit install so i gotta check that out...but thanks.
trasmadean
Feb 1, 2017 08:20 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MikesChevelle
Aug 9, 2015 11:50 AM
kenc15
Aug 5, 2015 08:29 AM
