Please help me!! it's an emergency
Old Jan 7, 2010 | 10:09 PM
bgawad's Avatar
Hey guys I'm new to the forum and I really need help. Last night I attempted to do a led swap to my cluster, everything was working out perfectly untill I was resassembling my rpm needle. It seemed fine when i assembled at my desk. After connecting it back to my car my rpm needle was way off. I tried fixing it but that's when things got bad, when I attempted to recalibrate it I heard a snap and now my needle does not move at all. So I guess it's time for a new cluster. Here's the problem my cars a 5 speed, but all the ones I find are automatic with p r n d 2 1 in the middle. Is it possible I can buy this type and switch the plastic cover with mine so no letters show across the middle? Or do I have to get a cluster from a manual? Im hoping they both work because all the ones I'm finding are from automatics. Thanks so much guys!(2000 maxima)
Old Jan 7, 2010 | 10:16 PM
Rood's Avatar
RPM guage will work from another 00 maxima... trans makes no difference.. Thats from what I understand. Someone please correct me if im wrong
The 01 is soldered in, and 02-03 is completely different.
Old Jan 7, 2010 | 11:02 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Go to autozone and get a large RPM guage. Tape or screw it to your steering column then hook it up to a good signal. Get one with a really bright shift light.
That is what I would do.
Old Jan 7, 2010 | 11:08 PM
SuperStasiu's Avatar
Old Jan 8, 2010 | 01:44 AM
knight_yyz's Avatar
Toolie
Are you sure you wouldnt slap a sprint booster on there?
OP, look in the classifieds for a used cluster from a part out. Too bad you don't have an 02 or 03 I have 3 cluster boards in my basement.
Old Jan 8, 2010 | 07:42 AM
Jmahad01's Avatar
What is it with this damn sprint booster recently lol....
To the op, be patient and you will find one. You can drive the car with a broken RPM gauge. I am sure if you were driving your manual max you would be able to shift at an appropiate rpm by just listening to the engine.
Old Jan 8, 2010 | 08:10 AM
perkman87's Avatar
So much power it broke the rpm needle.
Yes be patient, you will find one
http://www.everdrive.com/partdetails...paign=shopping
Its a civic cluster in the picture tho
Old Jan 8, 2010 | 08:18 AM
Rood's Avatar
funny enough I have a cluster which I parted out for my speedo.. If u want the rpm gauge pm me and i can sell it to u
Old Jan 8, 2010 | 08:22 AM
bgawad's Avatar
thanks
thanks guys for all the reply's. I took another look at my cluster and i realized the stupid owner before me connected a small wire from the battery light to the slip, and tcs off light. He sold it saying it had traction control but i guess not. He connected it to the battery light so when i start the ignition those light would light up. So i guess i can use any cluster since mines a base model and does not have traction control. I'm probably going to buy this one:
(mine has 174000, this was is slightly higer and has the se gauges)
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2478wt_848
So im guessing this would fit? with no modifications even though its from an automatic, im just going to change the middle with my old one so the auto gears don't show. I would loveeeeee to put an 02-03 cluster personally it just looks so much better, i rember reading a person on the org that put it in his 4th gen, he even got the temp display to work. Thanks again!!!
Old Jan 8, 2010 | 12:49 PM
vinco's Avatar
Does nobody here know that the "RPM gauge" is actually called a tachometer? It really doesn't even take that much longer to type, either.
Old Jan 8, 2010 | 12:50 PM
User 12822's Avatar
You cant use the stock rpm gauge with the sprint booster simply because the rpms needle cant keep up with the decreased throttle lag.
In fact, that is probably why yours broke in the first place, that snap you heard was the sprint booster's amazing power.
Old Jan 8, 2010 | 01:54 PM
My thoughts too until I figured out he doesn't even have a sprint booster
Old Jan 9, 2010 | 12:28 PM
1800bucks's Avatar
That's fu(kin awesome!
Old Jan 11, 2010 | 09:40 AM
mandyfig's Avatar
Tachometer...yup, better for me.
Old Jan 11, 2010 | 10:40 AM
zero2sixtyZ's Avatar
You embarrass me.
or even abbreviate it and call it a tach. less characters for the win.
ZIPPIN
18
Jan 13, 2002 07:07 PM
ZIPPIN
Jan 6, 2002 09:56 PM
NJ_MAX2000
Nov 3, 2001 03:28 PM
shumax
Jul 10, 2001 08:33 AM
Rit
Jun 6, 2001 08:55 AM
