Cattman 3" Catback Exhaust - Order Here!
Old Aug 27, 2010 | 06:12 AM
  #1081
NmexMAX's Avatar
dot dot dot ...
Originally Posted by CMax03
I like mine....as is......
It works, it's functional, the theory works and me likes.
Old Aug 27, 2010 | 03:15 PM
  #1082
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by Cattman
I would not assume that a 3" tail section on a y-pipe will make more power. That is a good place (going into the cat) to maintain strong exhaust velocity.
What cat?
Although dynos of the difference (if any) would be awesome. But we're all poor haha
Old Aug 27, 2010 | 08:10 PM
  #1083
Grand_hustle17's Avatar
sparks max would be the guy to hit up... see if he had any gains
Old Aug 29, 2010 | 05:24 PM
  #1084
Rods03Max619's Avatar
Damn still loving the exhaust and is quieter but ready for some headers but said I would help out the exterior of the ride before I do that!!
Didn't want to be all show and no go!!
Old Aug 29, 2010 | 06:34 PM
  #1085
i cant wait to fix my header leak... sounds terrible for me
Old Aug 29, 2010 | 06:42 PM
  #1086
96MaXiclean's Avatar
Is it possible to just buy the Cattman muffler? 4th gen.?
Old Aug 29, 2010 | 08:17 PM
  #1087
call up brian, im sure he'd be open to it
Old Aug 29, 2010 | 10:13 PM
  #1088
CMax03's Avatar
2.5"?
check classifieds also.....
Old Aug 30, 2010 | 11:25 AM
  #1089
jowo9's Avatar
Ok so I said I'd post on here about my 1/4 mile experience with my Cattman setup... Basically it sucked. My best time was a 15.5. I'm at a pretty high altitude, but STILL, my DA corrected time was only 14.7. I had a consistent trap speed of 88mph, which also sucks. The speed DA corrected was 94mph. I'm untuned, so could it be possible that I'm running so rich that it's causing these horrible times/speeds??? Someone help me out please! I friggin hate this!
Old Aug 30, 2010 | 11:27 AM
  #1090
NmexMAX's Avatar
dot dot dot ...
How high of altitude are you at? And is this a 1/4 mile or (metric system shenanigans) ?
Old Aug 30, 2010 | 12:13 PM
  #1091
jowo9's Avatar
Haha. It's 1/4 mile. And I'm at 3500 feet.
Old Aug 31, 2010 | 06:53 AM
  #1092
CMax03's Avatar
What's your 60 ft? What gear are you in when launching D or 3rd? I did a granny launch just to see what it would do 60 ft was a 2.3- 2.4 and ran a 14.5sec....Next time I go out I'll be launching her really hard should see 2.0 or less in my 60ft....I do have ES MM inserts, Illuminas, and super lightweight 18" wheels that have clocked 2.1 60ft B4 the ES MM mod....I'm untuned but will be looking out my A/F ratio this week @ WOT.....I haven't installed my NWP spacers nor new coilpacks yet so once I do I'm hoping for low 14's or high 13's.....
Old Aug 31, 2010 | 07:06 AM
  #1093
NmexMAX's Avatar
dot dot dot ...
You have hoe many MMI's? AT right?
Old Sep 1, 2010 | 06:45 AM
  #1094
CMax03's Avatar
The usual front/rear MM & the fwd and aft crossmember bushings.....Yes it's a A/T.....
Old Sep 1, 2010 | 06:04 PM
  #1095
jowo9's Avatar
My 60 ft was 2.4 ... And I was doing my best launching. And even if I had bad times, my trap speed should have been higher... I really don't know what's going on. I guess I'll just have to try a tune. I know I'm running rich, cuz I can smell it. I wonder just how rich it is though.
Old Sep 1, 2010 | 06:05 PM
  #1096
jowo9's Avatar
Oh and I was launching in D. Does it really make a difference to launch in 3rd??!
Old Sep 2, 2010 | 06:55 AM
  #1097
CMax03's Avatar
Yeah it's difference is at the end of the track....if you're in Drive...it'll shift a few hundred ft b4 the finish line....In 3rd it's still pulling hard....try it! You'll see the difference.....
Old Sep 2, 2010 | 07:00 AM
  #1098
NmexMAX's Avatar
dot dot dot ...
Let's not forget the lock-up torque converter action that occurs in 3rd.
Old Sep 3, 2010 | 12:41 AM
  #1099
KT3MaxSE's Avatar
Just finished install of 3" Cattback on 5speed DEK, much more responsive and sounds great! Although a flex section leak was discovered after install which went smooth and uneventful as long as you have a torch (if old system heavily corroded) and an extra set of hands and/or support stands. It looks and fits perfectly as well. Only possible concern I have is whether or not the tips are too close to bottom of bumper and potentially melt/deform it. Does anyone know the minimum clearance needed so I don't have to worry about it? Or would I be ok with a 1-2mm gap and as long as they're not in direct contact w/ the bumper? Will try to get a sound clip up once I get the flex fixed. Thank you Brian for producing a great system!
Old Sep 3, 2010 | 06:46 AM
  #1100
CMax03's Avatar
No melt down syndrone to worry about with the tips....SS retains heat well most of your heat is expelled.....Been running Cattman 2.5" and 3.0" catback combined time for over 6yrs.....no melted rear bumper yet.....
Old Sep 3, 2010 | 06:47 AM
  #1101
CMax03's Avatar
Your 60ft directly affect your ET and trap speed!
Old Sep 3, 2010 | 04:33 PM
  #1102
The guy might want to get longer hangers I thought I was good but the tips hit the bumper the next day and melted a little but no big it aint messed up!!
Old Sep 3, 2010 | 08:25 PM
  #1103
CMax03's Avatar
Or he's got the resonator installed wrong
Old Sep 4, 2010 | 08:23 PM
  #1104
KT3MaxSE's Avatar
Thanks for the help/input guys...system installed properly w/ weld mark on top (O2 port as well) so no problem there. The system seems to have settled a bit & w/ a little downward pressure and pulling up on bumper cutout area while warm has cleared my conscience so to speak and good to go minus flex issue. Thinking I should just get new Y but $ is tight yet I don't want to prolong the inevitable...
Old Sep 5, 2010 | 07:53 AM
  #1105
CMax03's Avatar
There's alot of adjustability built into Cattman's 3" catback, the rear section where the slip joint and band clamp are can make the difference in how that exhaust seats on the car, clearance thru the over axle lambyrith and the amount of tip protrusion....
As for your defection flex section, I would get one aftermarket with turbo interlock features and you'll have for the rest of your life...
http://vibrantperformance.com/catalo...1022_1064_1114
Old Sep 7, 2010 | 01:40 AM
  #1106
KT3MaxSE's Avatar
Thanks again. I messed around with the rear section/slip joint area to fix a light banging/rattle (which seems to be occurring in 1-2 areas within the rear axle exhaust 'labrynthe' area) as well as working on the tips-to-bumper clearance issue but does not appear I'm making much, if any, progress at all...Is it best to leave all hangers attached and just loosen the clamp and slide/adjust that way or is there a better way or order of operations of hopefully correcting both of my issues? I did replace all hangers(insulators) with the stiffer Walker ones when installing the 3"...What else can I try/do?
Old Sep 7, 2010 | 03:39 AM
  #1107
Taking off in 3rd is the same as taking off in D, no added TQ, if you want your best times do as followed, take off in 1st gear, tire psi @20-22, power break to 2K and if you have a regular tree (light) leave on the 3rd yellow and floor it as hard and as fast as you can... thank me later
Old Sep 7, 2010 | 10:04 PM
  #1108
CMax03's Avatar
How close are your tips to the rear valance...? 1/4-1/2 "
Old Sep 7, 2010 | 10:11 PM
  #1109
CMax03's Avatar
Telling him to take off in 3rd was to help him keep pulling all the way to the finish line.....Cause toward the last 300 ft @ the end of the track if you're in D the car will shift into OD, killing your momentum... and trapspeed
Old Sep 8, 2010 | 08:14 PM
  #1110
CMax03's Avatar
Take a pic! maybe your valance can be moved upward?
Old Sep 8, 2010 | 08:16 PM
  #1111
KT3MaxSE's Avatar
Not even in " increments...merely 1mm from rear valance
Old Sep 8, 2010 | 09:39 PM
  #1112
KT3MaxSE's Avatar
Ya I did mess around with that as well and the only thing I can think of to bring the valance up right at the cutout would be to attach some type of bracket/brace to the bumper reinforcement bar and then to the valance. It seems unless it'd be attached directly in the middle of the cutout, it won't bring it up in the proper area to provide any more tip clearance. And doing so would likely create a protrusion from a screw, clip, tab etc. so hopefully I can figure out a way to support/attach a brace at the valance cutout entirely from the backside.
Old Sep 11, 2010 | 01:29 PM
  #1113
CMax03's Avatar
I'll be polishing my tips a bit more, just to hurt the eyes of those looking @ them, super bling-bling....
Old Sep 11, 2010 | 07:32 PM
  #1114
No lovely Cattman sound for 2 days so far car is in the shop had a rental 09 Sentra 140 hp, and now a Chevy Cobalt 155hp ah cant wait to get my car back and going to dyno soon if this place got a good dyno 50 bucks for 3 pulls I couldn't believe I found it!!
Old Sep 12, 2010 | 08:52 AM
  #1115
CMax03's Avatar
The sound is intoxicating.....I love that part throttle sound it's so smooth....that's buttery smooth for those who don't understand....and then the full throttle roar!!!!! Wow...I think I just had a premature ejaculation of some sort.....
Old Sep 12, 2010 | 06:23 PM
  #1116
Yeah that **** sounds hella nice live in Apartments and there is a Honda Del Sol hella RICE EDITION LOUD A$$ f33K Exhaust and a Accord 96 or 97 same thing just waiting to leave at the same time as those guys to see them B1tch up real quick!!
Old Sep 13, 2010 | 01:12 AM
  #1117
CMax03's Avatar
Yeah, I took mine for a ride tonight and my buddy (fellow Orger) heard the mellow howl thru the phone....and I told him about my description of the sound being slightly deeper than the Cattman 2.5" catback and more of a buttery-smooth sound and he too agrees....I'm proud of my exhaust note, especially when I hear some of these contraptions ppl throw together on their rides and how they disturd the peace....most of them sound like ****!!!!!
Old Sep 17, 2010 | 12:31 AM
  #1118
UncleSmitty's Avatar
kind of rims are those? im lookin at some that look almost similar only they're 7 spoke not six.. what do you guys think about a 7 spoke?
Old Sep 17, 2010 | 08:53 PM
  #1119
quickhuh's Avatar
This is going to be the next thing i buy for my car, the more and more i keep watching and drooling over the clips i need to have this next
Old Sep 18, 2010 | 05:29 PM
  #1120
Clashez's Avatar
I WANT 1 BUT I WONDER IF IT WOULD BE TO LOUD
