project intake
Old Feb 1, 2010 | 05:05 PM
papo99's Avatar
project intake
i plan on doing a battery relocation true cold air intake and eliminating the maf housing this is the beginning
Old Feb 1, 2010 | 05:07 PM
bigpopaj369's Avatar
looks good man cant wait to see the progress
Old Feb 1, 2010 | 05:24 PM
vastmax's Avatar
you do know that CAI's actually decrease power on our motor...right? just use a short ram with a pop charger...
Old Feb 1, 2010 | 05:27 PM
papo99's Avatar
why do they decrease horsepower
Old Feb 1, 2010 | 05:29 PM
loss of low end torque
Old Feb 1, 2010 | 06:10 PM
maxima dude's Avatar
isnt their a dyno or w.e on here with the short ram and cold air difference and the cold air was way on top with perfoirmance...i heard top end screams with a cold air
Old Feb 1, 2010 | 09:18 PM
Scottwax's Avatar
That's Mr. Detail to you
Typically, CAI's and short rams both make power gains. CAI's make it in the midrange but generally show little gains on top end. Short rams lose a little low end but make gains on top. Long tubes of CAI = higher airflow velocities and strong torque, short tubes on short rams mean more airflow gets to the engine quicker at higher rpms. Just like our intake manifold.
Maybe we need a CAI/short ram combo that has a flapper valve that switches from the CAI to short ram at 5000 rpms.
Old Feb 1, 2010 | 09:56 PM
Rood's Avatar
My write up shows the spot to drill the hold for the intake.
Good luck, more pics
Old Feb 1, 2010 | 10:31 PM
PulsarGTS's Avatar
+1
I really think if someone was to bother with all the work needed to do a true CAI on this car they should increase the piping diameter as well.
Old Feb 2, 2010 | 12:13 AM
BronxSleeperMax187's Avatar
Old Feb 2, 2010 | 05:21 AM
SteveB123's Avatar
So warm air is better?
Old Feb 2, 2010 | 05:56 AM
mist max2000's Avatar
Originally Posted by PulsarGTS
+1
still going to be limited by the DBW TB size ...no?
Old Feb 2, 2010 | 06:02 AM
your reading into it too much..
..no one is saying warm air is wanted over cold air... yet a short ram intake is better,..
..assuming ''better'' is describing a more linear powerband that holds/increases hp/tq all the way to redline with no drop off...
..where a ''cold air'' intake has a weaker powerband that drops off at high rpm's,.. and is not ''better''
..also,..throttle response vs pipe length is usually represented in a linear fashion with the longer the pipe the slower response,.. and the shorter the pipe the quicker the response..
but lets not crap on this guys thread and turn this into an ''intake'' thread,....
nice work cant wait to see some more pics,.. are you going into the fender with it?. what filter are you going to run,...I reccommend looking into R2C (cattman has them fs)
Old Feb 2, 2010 | 09:28 AM
PulsarGTS's Avatar
Well the TB is 76-77mm or 3"ID, and all the SRI/CAIs are 3 OD so you wouldn't be limited at all.
SexyRob's Avatar
cool
Old Feb 3, 2010 | 04:31 AM
ColtMax's Avatar
Very good workman ship, but I am a bit concerned with the calibration of your new maf assembly. The inner section surface of the maf is part of the equation that generates the signal to the ECU...
I would suggest a SAFC with a session on the dyno to recalibrate your air/fuel ratio correctly.
Old Feb 3, 2010 | 04:37 AM
Grand_hustle17's Avatar
It does look good... id like to see a dyno difference in the two
Old Feb 4, 2010 | 03:36 PM
papo99's Avatar
thanks for all the comments i just figured it gives a cleaner look without the maf
Old Apr 1, 2010 | 07:50 PM
papo99's Avatar
heres a pic of the intake i kept it short because everyone said if i went long it would be loss of power
Old Apr 1, 2010 | 08:09 PM
Unklejoe's Avatar
Looks proper man. I'm guessing your running a breather filter for the hose that used to be connected to the intake?
Old Apr 2, 2010 | 03:31 AM
papo99's Avatar
no i have the hose i just had to put it on no breather filter
Old Apr 2, 2010 | 11:52 AM
Rods03Max619's Avatar
This guy is a G isn't trying to hate on either since he had both of them and respect his opinion cause he got the dough to try it all out! But me I love my Injen CAI and will get other parts soon so I dont drop off on the high end!
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
