ABS Reset
Old Mar 15, 2010 | 08:15 AM
crazymax2k's Avatar
ABS Reset
How do you reset the abs on a 2000 maxima.
Old Mar 15, 2010 | 09:22 AM
Ghost_54's Avatar
Need a bit more information, such as did the ABS light just come on while you were driving? or did the ABS light come on when you first started the car and stay on? Have you done any recent work on the brakes or suspension and possible pinched the line?
Try and give as much detail as you can.
I have had the sensor light come while driving on a previous car (not a Max), and the simple reset is to pull over and put the car back into park and turn the engine off, and then restart the car to allow the slow reporting sensor to report back to the ECU. I have also heard from some of the guys that the sensor was simply covered with dirt and road crap and needed to be wash down and then was working fine.
Old Mar 15, 2010 | 09:51 AM
knight_yyz's Avatar
Toolie
there is a long procedure to reset the light AFTER you repair the problem. You have to drive at a certain speed for a certain amount of time, then read the code then ground one of the pins on the obd2 port and the code will clear. it is a pita. or go to the dealership after the problem is fixed and pay them to clear it
Old Mar 15, 2010 | 09:52 AM
knight_yyz's Avatar
Toolie
Old Mar 15, 2010 | 11:25 AM
crazymax2k's Avatar
ya i was reading that after i posted on here. well i recently totaled my knuckle and replaced it with another and since i put in the new one its been acting up when ever i slow down to a stop its making this grinding noise but when im on the freeway the abs light comes on and after that is stays on and stops perfectly. what do i ground the connector with. in order for me to do this.
Old Mar 15, 2010 | 02:07 PM
Gemner's Avatar
that grinding noise probably means the abs light is on for a reason
Old Mar 15, 2010 | 02:42 PM
chsherbie's Avatar
grinding=bad
Old Mar 15, 2010 | 03:01 PM
crazymax2k's Avatar
Originally Posted by chsherbie
grinding=bad
ya i know but only does it when the abs light is off any suggestions on how to fix it
Old Mar 15, 2010 | 03:39 PM
knight_yyz's Avatar
Toolie
take a short wire and touch the 8 pin and the 9 pin by the looks of it, but the port is female so there are no pins...
Old Mar 15, 2010 | 04:05 PM
crazymax2k's Avatar
im kinda worried that i might short out the ecu is this safe to do.
Old Mar 15, 2010 | 05:34 PM
knight_yyz's Avatar
Toolie
according to the FSM it is
Old Apr 26, 2010 | 08:02 PM
gjaa's Avatar
mine just came on today without an apparent reason, i just started the car after being parked all day and the light was on, i tried shutting the car off and pulling the key out to see if that would reset it but it didnt work, i just did some work on my e break so im assuming something went wrong with that!
edit: i need a new sensor
bbsitum
Sep 6, 2019 07:31 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
220k+ A32
Sep 22, 2015 03:08 PM
maximusrising
Sep 2, 2015 09:55 AM
