P1147 and P1448
Old Mar 18, 2010 | 08:00 PM
Scott LaRock's Avatar
P1147 and P1448
These are the errors my car is giving me...
P1447
Heated Oxygen Sensor - Bank 1 Sensor 2 (H02S12)
Maximum voltage not met
Probable Cause
1. Open or Short Circuit Condition
2. Failed H02S12 (Bank 1 Sensor 2)
3. Failed Injector or Pressure Regulator
2002 5.5 Gen
P1448
EvaP canister VENT CONTROL VALUE
PROBABLE CAUSE
1. FAILED CANISTER VENT SOLENOID
FAILED EVP PRESSURE SENSOR
Just spent 300 bucks when the car broke down and was told it was the battery and alternator and had that changed, car starts now but it definitely has a little backfire problem.
Old Mar 18, 2010 | 10:49 PM
rroderiques77's Avatar
Demodded and Forgotten
What is your question OP?
Old Mar 19, 2010 | 05:37 AM
1. How much is the parts I need to fix the car?
2. What's the learning curve to do this stuff myself?
Old Mar 19, 2010 | 07:10 AM
Problem 1 -
You probably need a downstream 02. You should give Dave B. a call (1-888-254-6060). He works at Southpoint Nissan in Austin TX and gives us Org members discounts for OE parts. The O2 should be less than $100. The install is rather simple. Just unscrew the o2 out of the exhaust and screw the new one. Sometimes these things don't come out easily, so you may want to purchase a small torchand make sure you also purchase some anti-seize for the new 02.
Problem 2 -
I believe the vent control valve is built in to the vapor canister. These things can be expensive. I suggest you take the car in and get it diagnosed before spending that kind of money.
Hope this helps
Old Mar 20, 2010 | 02:41 PM
Thanks,
Do you guys recommend getting a Haynes Instruction manual on fixing the Max?
Old Mar 23, 2010 | 04:58 AM
bump, I filled up Friday and I'm getting about 18mpg. My digital clocks say 25mph when I'm doing about 60 and I'm buring alot of gas.
Please advise again.
Old Mar 23, 2010 | 06:39 AM
Not sure how accurate your internal clock is.
I would take it to a shop at this point. Have them diagnose the problem and post the results here.
e-subliminal-2
May 21, 2010 07:22 AM
2damax
Mar 24, 2009 05:46 PM
Weeble1
Jun 11, 2008 08:23 PM
Starchild2K2SE
Sep 9, 2005 01:14 PM
F4i Caveman
Aug 29, 2005 07:37 PM
