intake leak ?
And you're gonna have to provide a lot more info. If you're getting a lean code, it could be from one of a few problems.
my car isnt running lean i burn gas worse than f250. i figured it would make it run rich since there is more air and then the car would dump more gas to compensate for the air. but your making since about it not being monitored. i have had problems with my car since i bought it. running rich and misfiring and bogging down. i was getting a maf code so i changed the maf now i have a cly 5 misfire, ignition primary. so i change the coil, still runs bad. while i was massing with the coil i noticed a hissing noise somewhere behind the intake and i noticed it inside my car for a long time but i just thought it was my RAI making the noise. i just about had it with this car and all these stupid little problems that cost an arm and a leg
How old are the plugs? Even if they were new before, you're going to need to change them from running so rich, imo. IM leak is probably more of nuisance than anything at this point.
It can make it run lean.
Does your car pop and sputter sometimes when the engine is cold? Does it even shut off sometimes? Those are a few signs. If you have a 2000 maxima with high miles I recomend change it.
Go to the dealership and ask for the upper plenum gasket and the EGR gasket. Change both. Even if thats not the problem, it's gonna go bad soon anyways.
I did everything it said and no as far as I know i never took anything off that didnt need to come off. this is killing me on the interstate. Maybe it could be a vacuum line somewhere?
Did you kill the maf? Intakes routinely kill mafs for some reason even if the filters are unoiled. Please, quit whoring, now.
Im thinkin I may have killed it. It will bog down when you floor it. I guess that is somewhere to start. Along with a dry filter and not this oiled one. Correct me if I am wrong but oil filters are bad for your MAF's right?
go to advanced auto and they have the AEM Dryflow filter for like 40 bucks. i just bought one last week
it brand new. Im gonna go tomorrow and get the dry flow. I just feel better with that on there. Still have to probably get a new maf though. Anyway to test it?
I just got some MAF cleaner for now. The original problem has mysteriously disappeared. Maybe my car just needed to get use to the intake? No clue. Im probably still gonna get a new MAF here soon. Just to be sure.
HAPPY EASTER EVERYONE
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
pears
Sep 18, 2015 05:25 AM
ag90fox
Sep 9, 2015 12:22 PM
