What is the best intake?
Old May 18, 2010 | 01:58 PM
  #201
NmexMAX's Avatar
dot dot dot ...
Putting a filter on the VC causes a lean condition @ idle. This is because unmetered air is entering the engine, i.e. not being accounted/compensated for.
I had that set-up for long time, but would rather not do it again if done right, you would find a way to get the hose back into the mix the way it was in the first place.
Old May 18, 2010 | 02:24 PM
  #202
Unklejoe's Avatar
Get rid of that silver tube between the MAF and the throttle body.
Put the stock Helmholtz resonator back in. This will give you the stock location to plug the hose into.
It can be argued that there will be any gains from deleting the resonator anyway...
Old May 18, 2010 | 03:31 PM
  #203
NmexMAX's Avatar
dot dot dot ...
I have dynos comparing a straight resonator vs the OEM helmholtz.
OEM = smoothest curve
Straight = 1-2 hp gain post 6k, and a bit more non-linear power delivery & far louder.
It has also been seen in Z33 dynos (straight non-helmholtz) as well as in the VQ30DE which showed the same behavior as mine.
OEM
Straight Berk midpipe
Old May 18, 2010 | 03:54 PM
  #204
killer00's Avatar
I put a filter on the Breather.
Old May 18, 2010 | 04:59 PM
  #205
NmexMAX's Avatar
dot dot dot ...
What is that going to do in reference to his helmholtz comment?
Old May 18, 2010 | 06:21 PM
  #206
drex1x's Avatar
next.. get a bigger filter.. 4" x 6" and get a BPi Velocity Stack.
Old May 18, 2010 | 06:41 PM
  #207
Unklejoe's Avatar
Good info with the dyno runs.
I chose to stay with the Helmholtz because of the smoother curve, and the ability for me to keep my stock breather intact.
Really a personal preference, assuming that you get a mid pipe that has a breather bung.
Old May 18, 2010 | 06:51 PM
  #208
NmexMAX's Avatar
dot dot dot ...
It really does provide the most area under the curve, I agree.
Old May 18, 2010 | 07:34 PM
  #209
Rods03Max619's Avatar
Looks good
Old May 19, 2010 | 03:05 AM
  #210
SoonerFan's Avatar
Cletus
sweet another intake thread
Old May 19, 2010 | 03:36 AM
  #211
Nismo215's Avatar
if this is put into an automatic wouldn't you have to adjust anything? because i had something like this in my car and it was revving up to 6k then shift? sorry to steal thread...
Old May 19, 2010 | 11:55 AM
  #212
NmexMAX's Avatar
dot dot dot ...
No adjustments necessary IMO.
Sooner, I tried my best to keep this as technical as possible. I hadn't brought up the resonator in a while so this is good for the newbies who have not seen it.
Old May 19, 2010 | 04:31 PM
  #213
stockmaximaFTW's Avatar
NOT INVITED TO MAXUS 2010
and you added what to this thread? negative post yet again. you don't even own a maxima move on. find a new forum.
Old May 19, 2010 | 05:45 PM
  #214
drex1x's Avatar
On another note, I received my BPi Velocity Stack, but now I'm in need of a AEM DRYFLOW FILTER.. where can I order a 6" inlet by lets say 4" or 5" ?
Old May 19, 2010 | 06:31 PM
  #215
2002AltimateV6's Avatar
JWT Popcharger > * Especially in the RSRI form.
Old May 19, 2010 | 07:11 PM
  #216
NmexMAX's Avatar
dot dot dot ...
Filter on the vc is ftl as stated in my prior post.
Old May 19, 2010 | 07:29 PM
  #217
knight_yyz's Avatar
Toolie
you need an AEM filter part number 21-209dk
Old May 19, 2010 | 08:34 PM
  #218
drex1x's Avatar
thanks knight.. and nmexmax.. the breather on the vc is no good?
Old May 19, 2010 | 09:04 PM
  #219
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
No offense intended, but you are wrong here.
Putting a filter on the VC merely lets it vent to atmosphere instead of having a vacuum applied from the intake. The valve cover does not draw in air, but in fact pushes it out. As long as you plug or delete the hole on your intake, there will be absolutely 0 unmetered air being taken in. Obviously if you just leave the nipple for the VC hose open, it will be sucking in air.
Also, just for the sake of argument, when the VC hose is connected to the intake there actually is a small amount of unmetered air (and oil) entering the engine from the valve cover. It's a very small amount since the VC is sealed with the exception of the vent, though. Regardless, the engine gets more unmetered air with the hose in tact than it does with a filter on it, which is quite the opposite of your claims.
I could also point out that I have had a filter on my VC for almost 2 years with some of the quickest 5.5 N/A times out there, plus that I do not have a lean condition at idle or otherwise. And yes, I do have a wideband to keep up with such things.
Should you not agree, please take a moment with MS paint and this picture and circle where the unmetered air is entering the intake.
Old May 19, 2010 | 11:39 PM
  #220
CMax03's Avatar
Originally Posted by jeff5347
Ill go off topic like crystalline for a sec too. i did my own Torque link. i used 2 pieces of 1/4 inch steel angle iron shaped as such... L . i bolted them to the same place NWP uses, the frame and the pass side upper motor mount. Attaching the 2 is an eye bolt on each angle iron connected by a left and right hand threaded bolt such as you would find on a tie rod. i tightened this up until i saw the slack taken out then i gave it 2 more full turns of tightening. I noticed a few things, the car exhibits more vibration which is to be expected. The vibration is actually welcome as it reminds me of my my 68 Camaro and other muscle cars. Also you notice when in park and revving the engine the movement is basically eliminated. As for wheel hop. I still get it. In the wet no but if i am on dry pavement i still notice the jarring hop. There may be a millisecond less delay when getting into the throttle. All in all im glad i have it. I haven't tested a before and after full throttle drag run or run down the street so there may be something i haven't felt yet. As for when it shifts i haven't noticed a decrease in time (Which you wouldn't anyway as the tranny decides that) from each shift but have felt a slight more grab to each gear if that makes sense. But had i spent 160 for it i would be very mad at the cost vs effectiveness ratio.
Did you know that a chain will do the samething.....Ole school hotrodders used chains to limit the engine movement and prevent broken engine mount for the cheap!
Old May 19, 2010 | 11:50 PM
  #221
SoonerFan's Avatar
Cletus
who are you
and that post was in a new thread about intakes...that a mod rightfully moved in here
Old May 20, 2010 | 03:11 AM
  #222
crystalline's Avatar
I just want to add holy crap knights sri kit is loud when you get on the gas
Old May 20, 2010 | 05:35 AM
  #223
essential1's Avatar
My axles cry for mercy...
This^
I dont see how it can cause a lean condition at idle. It's only logical that you would of course put a vacum cap of some sort on the opening that is now created on the intake tube when the hose is removed. Right? But if one were to be silly enough to leave it open, why would it only cause a lean condition at idle? Is this because of the change in manifold pressure?
Old May 20, 2010 | 06:02 AM
  #224
Originally Posted by essential1
This^
If one were silly enough to leave the gaping hole in the intake open, it would be pulling in lots of air that the maf isn't reading and would run like crap (lean) just like any other bad vacuum leak. But I don't know many people who would be that dense.
Old May 20, 2010 | 08:11 AM
  #225
NmexMAX's Avatar
dot dot dot ...
My car must be a freak and I left a gaping hole in my intake because I am that dense
Old May 20, 2010 | 09:53 AM
  #226
Haha I didn't say you were dense, but I did want you to explain where all this unmetered air is coming into the intake. Are you implying that the valve covers are connected to the intake manifold in another place and the filter causes a vacuum leak? Even though that is not the case, it would be the only way I could see your theory working. Maybe you had some other factors at work.
Old May 20, 2010 | 09:54 AM
  #227
NmexMAX's Avatar
dot dot dot ...
They are connected to the IM via PCV.
I never said it would help WOT/ET’s/dynos, hell the fastest A32B has dual breathers, and mine had a breather when I hit 242. It’s only for drivability, since we all know what happens under high load/WOT re: PCV operation.
I had to ‘tune’ out the lean-ness when I had it installed (breather), w/o it now, I can go back to keeping my corr%’s @ 0, vs +12% @ idle, this may be a MT/AT difference.
It’s been spoken about quite a bit, not as much as intakes, but near infinium prior to probably everyone in this threads join date.
Old May 20, 2010 | 09:55 AM
  #228
Which is connected to the IM via the hose that goes into the midpipe.
Old May 20, 2010 | 10:03 AM
  #229
NmexMAX's Avatar
dot dot dot ...
Which wouldn't be the case if you have a filter on the VC.
So...?
Old May 20, 2010 | 10:16 AM
  #230
So...?
My point was that there is only 1 place that it connects to the IM. Disconnecting that and plugging the hole in the midpipe does not introduce any vacuum leaks.
Old May 20, 2010 | 10:17 AM
  #231
NmexMAX's Avatar
dot dot dot ...
The PCV is connected to the IM from the other VC as well.
In for pissing contest...probably means we ran out of things to talk about.
Old May 20, 2010 | 06:28 PM
  #232
jeff5347's Avatar
agreed i know lots of GN guys that do this with a ratchet type seatbelt looking thing. just keeps the engine from rocking. i can take a pic tomorrow to show the DIY way i did it
Old May 20, 2010 | 09:06 PM
  #233
00o30's Avatar
I just did my short ram intake today. Does anyone know what to do with the two smaller hoses that are attached on the intake resonator? Can I leave them disconnected?
Old May 21, 2010 | 01:36 AM
  #234
knight_yyz's Avatar
Toolie
you attach them to the proper ports on the new intake you bought. If there are no ports you bought the wrong intake. You can't leave them disconnected as they need a vacuum source
Old May 21, 2010 | 05:43 AM
  #235
essential1's Avatar
^Actually I've got a serious question regarding this^
I know on 4th gen 00vi swaps, you can leave these two open and the VI will still activate by way of RPM switch of course. Why cant you leave it open on a 5th gen?
Old May 21, 2010 | 06:04 AM
  #236
NmexMAX's Avatar
dot dot dot ...
He probably bought an intake for a 3.5 since they do no have the vac ports, just the PCV, meaning his intake doesn't have enough portage for his set-up.
Old May 21, 2010 | 06:17 AM
  #237
Rochester's Avatar
Both valve cover ports are called PCV? You know, I always thought it was something like "pressure control valve", and never really thought twice. But that's way off. Here's the def, in case anyone needs an "Oh!" moment:
Positive Crankcase Ventilation
–nounAutomotive. a means of reducing air pollution by directing the fumes from the crankcase of an engine into the intake manifold, so that they will be channeled into the cylinders and burned. Abbreviation: PCV
Old May 21, 2010 | 06:27 AM
  #238
NmexMAX's Avatar
dot dot dot ...
Old May 21, 2010 | 09:55 AM
  #239
can we make a thread/sticky called 'the ultimate intake thread' put all of our collective knowledge into it, and then auto delete any new intake threads? seems like it would make the most sense as intakes are not very complicated...and it comes up every 5 new threads.
Old May 24, 2010 | 06:15 AM
  #240
NmexMAX's Avatar
dot dot dot ...
This thread has already been merged with another thread once ... hmmm ....
