whats your tire pressure and suspension
Old May 22, 2010 | 11:20 PM
jeff5347's Avatar
I was just curious on what you guys have your pressure set at. I think just knowing what the pressure is is to vague.
Throw in your susp mods and tire size. I have been playing with my pressure just to get a good combination of ride comfort and handling.
something like this:
Stock Gle 17 rims w nexen n3000 225/50 17
sprint springs
illumina shocks and struts set 3/4
Progress RSB adjusted to full stiffness
FSTB and DIY homemade rearstrut brace
Previously i had my pressure at 36 all around. Liked the handling but it was a bit harsh on anything more than just cracks in the road. dropped them to 32 front and 34 rear. rides nicer, slight drop in handling but not bad.
Just looking to see what you guys do and what you like...
Old May 23, 2010 | 12:17 AM
roggeezy's Avatar
Stock SE 17" w/ Yokohoma S-Drives
Progress Springs
Illumina Shocks 5f/5r
FTSB
f 33psi/r 33psi
Old May 23, 2010 | 12:32 AM
jeff5347's Avatar
geezy, is the ride super stiff on 5/5. when you hit cracks and manholes does it hammer the car
Old May 23, 2010 | 06:13 AM
Prophecy99's Avatar
18x7.5 rims w HR2 Venus 225/40/R18
H&R springs/ illumina struts set 4/5
LTB Stage 2
FSTB
Rear Spacers
43 psi all around , I have come to the conclusion I think the higher PSI on low profile tires has been saving my wheels from not bending as much. I can remember when i rode lower psi and was bending wheels left and right.
WIth stock gles i ride around 40 psi
Old May 23, 2010 | 06:18 AM
nismopc's Avatar
Hard to come to proper tire pressure conclusion when all tires are manufactured differently. With that said:
G35c 17x7.5(f)/17x8(r) with Firehawk GTz 245/45-17
Vogtland springs (1 ring cut off front)
GR2 struts
eBay FSTB
40psi all around.
Old May 23, 2010 | 07:01 AM
mandyfig's Avatar
36 psi all around, 17" SE Titanium rims, stock everything
Old May 23, 2010 | 07:02 AM
mandyfig's Avatar
Drops to 34 after a few weeks and put it back to 36, to even out the wear.
mandyfig's Avatar
36 is a little hard but you get use to it and saves gas.
Old May 23, 2010 | 08:37 AM
PadawanKnight's Avatar
Stock SE suspension
Stock 17" SE Wheels
225/50R17 Michelin Pilot Sport A/S
Front: 42-43psi
Rear: 37-38psi
(I have them set at 45/40 at rotations and they drop 2-3 psi once they cool down)
Old May 23, 2010 | 01:13 PM
Thorzdad's Avatar
Bone stock everything. 32psi all around.
Old May 23, 2010 | 05:46 PM
roggeezy's Avatar
The ride isn't too stiff with the illuminas set at 5 all the way around, it does hammer when I hit huge potholes but I try to avoid all that stuff.
Old May 23, 2010 | 05:57 PM
rroderiques77's Avatar
Demodded and Forgotten
350Z 18x8 Touring wheels with 225/45R18 Dunlop Direzzas
KSports
RSB
SFCs
Subframe connectors
FSTB
Polyurethane bushings
35PSI
Old May 23, 2010 | 06:06 PM
Romey's Avatar
Nitto Neo Gens 245/35/19
PSI @ 35 all around
Tokico Illuminas (2/4 daily drive) (4/4 Driving alone for kicks)
Eibach springs
Gives me the best ride without beating up my rims and passengers.
Old May 24, 2010 | 07:26 AM
UGAd13's Avatar
H&R
Blues
Stock GLE Wheel 17x7
235/45/17 Toyo Proxes 4
32psi or 35psi... Last fill up was 32psi but I may up it back to 35psi.
Rush hour/daily driver with some spirited turns here and there
Old May 24, 2010 | 07:37 AM
zero2sixtyZ's Avatar
You embarrass me.
Summer:
37 all around, Illuminas set to 3F/4R
Winter:
34-35 all around, Illuminas set to 2F/3R
240tomax
Sep 13, 2015 03:28 PM
thenewguyy
Sep 12, 2015 11:12 AM
Violator
Sep 9, 2015 10:14 AM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
