Bouncing off redline on 3.0 engine
Old Jun 2, 2010 | 05:45 AM
sontakke's Avatar
I always thought that ECM will gently cut the power after going beyond red line. However, what I am now noticing is that it seems to be doing very hard cut-off right (or even before) the red line. I only get a chance to hit the red-line in the first gear; so I am not sure if the behavior is the same in other gears or not. After owning this car for more than 10 years, I would have noticed it before but I do not recall.
- Vikas
Old Jun 2, 2010 | 06:01 AM
NmexMAX's Avatar
dot dot dot ...
It's not a 'soft' limiter as is seen with other cars, it's fuel cut, so yeah, it can be pretty abrupt.
Old Jun 2, 2010 | 06:06 AM
Rochester's Avatar
The new Taurus SHO does the same thing. Go over redline while in Manual Mode on that AT, and the damn thing just dumps, instead of forcing a shift. Not exactly the experience you would expect from a $40K+ trunk with wheels.
Old Jun 2, 2010 | 07:25 AM
SoonerFan's Avatar
Cletus
FYI, the rev limiter is just past redline...learn where it is for perfect upshifts
Old Jun 2, 2010 | 08:31 AM
NmexMAX's Avatar
dot dot dot ...
I prefer to bounce instead of forcing a shift. The new Genesis also just up shifts, just like my old 97 Grand Am, as well as any other GM from that 'era'.
I llike that my 2 Maximas do not do that.
Although the SuprastickV.4 looks really neat ..
Old Jun 2, 2010 | 08:34 AM
Crusher103's Avatar
its a rev-limiter what do u expect.....
Old Jun 2, 2010 | 08:38 AM
NmexMAX's Avatar
dot dot dot ...
Old Jun 2, 2010 | 10:45 AM
e-subliminal-2's Avatar
Old Jun 2, 2010 | 10:49 AM
sontakke's Avatar
I recall rev-limiter cutting little after the redline. May be that was on somebody else's car. On mine it feels like it cuts off even before the red-line but I am not sure as the damn thing races so fast to red-line! (and that is with 87 octane; OK I am bragging but only a little :-)
- Vikas
Old Jun 2, 2010 | 11:20 AM
essential1's Avatar
My axles cry for mercy...
omg... Is this thread serious?
Maxima tachometers are not 100% accurate to begin with. Figure out YOUR own tach and drive YOUR car based on that.
If this thread is pertaining to automatics... well, the words "automatic" and "bouncing off the rev limiter" shouldnt be in the same sentence unless you're talking about a failing/slipping transmission.
As far as how "hard" or "soft" it hits the rev limiter, it doesnt matter. What matters is that your rev limiter actually does what it's supposed to do and not send your motor into orbit because you tried to get it to rev to 9K..
I'm done...
Old Jun 2, 2010 | 11:24 AM
essential1's Avatar
I think I found another secret code in this thread...
- Vikas
Originally Posted by NmexMAX
It's not a 'soft' limiter as is seen with other cars, it's fuel cut, so yeah, it can be Pretty abrupt.
The new Taurus SHO does the same thing. Go over redline while in Manual Mode on that AT, and the damn thIng just dumps, instead of forcing a shift. Not exactly the experience you would expect from a $40K+ trunk with wheels.
Originally Posted by SoonerFan
FYI, the rev limiter is just past redline...learn where it is for perfeCt upshifts
I prefer to bounce instead of Forcing a shift. The new Genesis also just up shifts, just like my old 97 Grand Am, as well as any other GM from that 'era'.
its a rev-limiter whAt do u expect.....
- Vikas
If this thread is pertaining to automatics... well, the words "automatic" and "bouncing off the rev Limiter" shouldnt be in the same sentence unless you're talking about a failing/slipping transmission.
I'm done...
Can I vote for a lock?
Old Jun 2, 2010 | 11:29 AM
Grand_hustle17's Avatar
I was kinda going to ask the same question about this thread... I don't get it......
Old Jun 2, 2010 | 11:43 AM
NmexMAX's Avatar
dot dot dot ...
I bounce off mine all the time hence the statement re: Suprastick ..
Mostly expect it during dyno time.
Old Jun 2, 2010 | 05:17 PM
5 ltr. beater's Avatar
My M bounces off the rev limiter pretty bad and my car retailed for 60k+ brand new. i prefer it that way though.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
