flooring an auto
Old Jul 8, 2010 | 11:52 PM
  #81
SoonerFan's Avatar
Cletus
Originally Posted by Scottwax
Flooring it is perfectly fine. Holding it at 6500 rpms for an hour, not so much.
but holding at 6500 isnt bad for the tranny...its bad for the engine
Old Jul 9, 2010 | 10:53 PM
  #82
Scottwax's Avatar
That's Mr. Detail to you
It will build up heat in the tranny.
Old Jul 10, 2010 | 11:47 AM
  #83
threebetyou's Avatar
ive floored mine with no issues just watch the rpms and dont destroy your car
Old Jul 10, 2010 | 07:31 PM
  #84
dan.worts's Avatar
I can't see how one should expect there to be a problem if this is not done often. Our cars are designed to be able to not blow up when pushed to their max potential. I don't see the point in allowing a car to be floored if doing such a thing would be really bad for it
Old Jul 12, 2010 | 01:17 PM
  #85
Scottwax's Avatar
BTW, full throttle shifts tend to cause less wear since the transmission shifts with full line pressure. On part throttle shifts the line pressure is less and the clutch packs don't grab as quickly so the shifts are smoother but they also cause more wear since there is more slippage on each shift.
Old Jul 12, 2010 | 01:27 PM
  #86
Norm Peterson's Avatar
That trades less wear and lower heat generation for more impact. Certain automatic transmissions had a known tendency to break off one of the ends of the low/reverse band, which would have been an impact/fatigue issue (there's a little bit of bending in the band ends that can't be completely eliminated).
Norm
BobTX10
Oct 7, 2015 08:43 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
