What do you do to make your engine look pretty? :)
Old Mar 13, 2012 | 06:46 AM
  #1321
TunerMaxima3000's Avatar
^This, braided hoses, unless you buy the super expensive ones, are generally a 1 year ordeal, after that they look like crap. I'd never put them on my car personally but they can look good. IMO, most uses they look over the top.
Old Mar 13, 2012 | 06:54 AM
  #1322
ranmas2004's Avatar
Steel-braid is always sexy. So is nylon braid. Both are a little over the top, too, but undeniably pretty stuff...
...when brand new. After a while, braided hoses in a daily driver start to look like pooh.
Is there anyway you can clean them up after they start looking bad? Like some metal polish or something?
Old Mar 13, 2012 | 07:29 AM
  #1323
Rochester's Avatar
IDK. I'm sure cleaning them helps, but they never look the same.
Braided hoses are primarily a show-car thing, ranmas2004. I know it's tempting, but stick with rubber... colored if you must, but black is good, too. They're just hoses after all, not a high-performance part that warrants attention.
Of course, we all pick and choose what items we like calling attention to. It's a personal style thing. For example, nuts & bolts aren't "high performance" either.
I'm rambling.
Old Mar 13, 2012 | 08:12 AM
  #1324
I'm rambling.
^ I agree with the above ramble.
Ramble on, sir, ramble on.
And Ranmas, if you're stuck on steel braid, the only way to combat the deterioration is to buy the stupid expensive all stainless ones. The corrosion/wear comes under the braids, so cleaning does little to fix it because you cant actually clean the part that's making the mess.
It really is best to just avoid them, unless you're bound and determined to use them. or, if you actually have a use for them, in which case, you'd buy the high quality ones not the chinsy ones you posted (no offense brah)
Another option is buying just the braid, it's cheaper, and as such, you can get the quality stuff:
http://www.cabletiesandmore.ca/Stain...FQfCKgodxRzraw
She's annoying, but here:
Old Mar 13, 2012 | 11:27 AM
  #1325
4DRZ's Avatar
Thats not mold, it could be the dye from the refrigerant. You may have a leak of some sort.
Originally Posted by guarj17
Regarding the AC coolant lines, mine have like a film over them that I can not seem to get off. It is a light green color. It seems to be like mold or something and even after using a wire brush, brillo, and scotch brite I can not get all of it off. Some came off, but not even close to all of it. What the hell will take this off?
Old Mar 13, 2012 | 12:48 PM
  #1326
ranmas2004's Avatar
Yeah Im pretty stuck on the braided lines...lol. Cost is not an issue for me. So are these cool? They say they will not discolor or corrode at all.
http://www.chevyavalancheperformance...roducts_id=893
$55 is not alot to me.......
Old Mar 13, 2012 | 01:23 PM
  #1327
^That looks similar to the sheathing I linked, just has some sort of cover over it. And if they warranty it, even better!
As long as you are aware that those aren't hoses themselves. But they should slip over the hoses you have currently if you size them right
Old Mar 13, 2012 | 01:26 PM
  #1328
Rochester's Avatar
That's pretty obvious, isn't it, Tuner?
On a related note, I think Spectre makes crap.
Old Mar 13, 2012 | 02:04 PM
  #1329
It was something of a bad joke.
Old Mar 13, 2012 | 07:30 PM
  #1330
ranmas2004's Avatar
Those are the ones I bought...the sleeves that go over the pipe. I was aware of that. We will see how it goes. Even if it doesn't last I can always just go remove the sleeve. It will look dam good though for a min if it doesn't last!!
Old Mar 13, 2012 | 08:05 PM
  #1331
Rochester's Avatar
Have you ever put on a dress shirt and buttoned the collar to the top, but not worn a tie?
That looks good for about a minute, too.
Old Mar 13, 2012 | 09:51 PM
  #1332
Looks good all the time if you're mexican. even better if you only button the very top button.
Old Mar 13, 2012 | 11:19 PM
  #1333
ranmas2004's Avatar
Some like it some don't. It's cool. Never going to please 100% of the people 100% of the time. I value your opinion and you give great advice, but at the end of the day I'm the one that's going to be driving the car.
Old Mar 13, 2012 | 11:32 PM
  #1334
cjandura's Avatar
Oh Boy at the tard that says theres freon on the outside of the pipe/tube
Old Mar 13, 2012 | 11:37 PM
  #1335
cjandura's Avatar
And Ranmas get some blue silicone hose's the straight kind and bend/form them yourself to match the oe ones your replacing and some nice Ti clamps i think you may like it better then braid.btw you form/bend the hard silicone hose with a heat gun and piece of copper tubing to stick thru it to stop it from colapsing.
Old Mar 14, 2012 | 05:44 AM
  #1336
Why:/
1. It's not freon, it's R134 refridgerant, that he's referring to.
2. It's not the refridgerant that's on the hoses, it's the dye inside the refridgerant, possibly, dunno, don't see pictures or proof, but it's possible.
Either way, if it's the dye from the AC, then it's indicating a leak.
Old Mar 14, 2012 | 06:03 AM
  #1337
Rochester's Avatar
There does seem to be a coating on the brake lines, which look a lot like the AC lines, except that the AC lines aren't coated and polish up quite nicely. Maybe quarj17 was referring to those?
Old Mar 14, 2012 | 06:06 AM
  #1338
merovi's Avatar
Probolt is certainly taking their time....
Old Mar 14, 2012 | 06:11 AM
  #1339
Rochester's Avatar
You would think their outrageous shipping costs would mean next-day, but you'd be wrong.
Old Mar 14, 2012 | 06:20 AM
  #1340
merovi's Avatar
I've gotten everything else I ordered. Just waiting on those.
Old Mar 14, 2012 | 09:27 AM
  #1341
ranmas2004's Avatar
DAM...yall some custom fabricators on here; welding LEDs, bending pipes, etc..LOL. Yall all need to get together and just BUILD a Maxima!!! Would be way better than Nissan does!! I dont have all that or a garage and a house with 150 psi air compressors and tools with all this equipment laying around. I wish I did. I live in an apartment for now.
Old Mar 14, 2012 | 09:35 AM
  #1342
ShocknAwe's Avatar
Lol my brake lines have a coating on them as well. Pretty sure it came that way and its DEF not freon. I could tell you exactly how that looks as some major fridge work was needed on my dads rental property I keep up for him
Old Mar 14, 2012 | 10:06 AM
  #1343
cjandura's Avatar
If its the greenish waxy tacking feeling stuff its the anti corrosion coating alot of brake lines and tubing have it and sometimes if the tubing is silicone lined/dipped its from the dip process.
Old Mar 14, 2012 | 10:49 AM
  #1344
ShocknAwe's Avatar
Yea I figured it was some sort of protective coating. Its not tacky at all but then again it is 16 years old so it has probably worn thin
Old Mar 14, 2012 | 12:24 PM
  #1345
aackshun's Avatar
This is what I do... I remove the engines!
Both of them are way too far gone to make look pretty again w/o re-painting.
But man, this took like 6hrs of cleaning, and it's still dirty, I quit, this is good enough so I can at least work on the car w/o getting 10lbs of grime all over me.
Ack, I didn't take pictures of the white car when I was swapping motors, but it's the same, but harder to notice the bare metal because of the white paint.
Old Mar 14, 2012 | 07:20 PM
  #1346
guarj17's Avatar
Ehh it very well could be I am not to sure. It's the two silver pipes that run next to eachother on the firewall. I thought that is what you were refering to in Shock's pic of his reservoir cover. I will take pics of the film I am talking about tomorrow if I get a chance.
cjandura, if it is that, should I leave it alone? It looks pretty gross. Lol
Old Mar 14, 2012 | 08:24 PM
  #1347
4DRZ's Avatar
Funny how name calling seems to make others "feel" larger. Sad...However, you are correct it couldnt be freon, it would have to be R134, and with this said, it would have to be the dye that is used in R134, which would mean there is a leak in the system at the pipe perhaps. . I stated this as a possibility because this happened to me and it was a leak. The suction hose had to be replaced.
Thanks for the knowledge and clarity of my mistake in wording. Its nice to know a few decent members are still around that dont resort to trying to belittle others.
Why:/
Old Mar 15, 2012 | 05:47 AM
  #1348
Rochester's Avatar
Pretty sure cjandura doesn't need to call people names in order to feel large. And TunerMaxima3000 is no prince. You simply caught one on a bad day, while the other was on a good one.
Try not to be too butthurt, 4DRZ... they're both good guys.
Back on-topic to engine bling.
Old Mar 15, 2012 | 08:22 AM
  #1349
I'm so prince
Old Mar 16, 2012 | 02:59 PM
  #1350
Rochester's Avatar
erty67 sent me three circular decals, 45mm in diameter.
I like the dark gray one, so I stuck it on that new Radiator Cap Cover, and it looks pretty good, IMO. It's not perfectly smooth as if it were painted, but it's 95% good enough. I mean, you have to get down and study the thing to be critical.
I like it so much, now I need a smaller one to put inside my Oil Cap, so the two shades of dark silver match.
Pics:
Notice the Stainless Steel T-Bolt clamps on the upper radiator hose.
Old Mar 16, 2012 | 03:08 PM
  #1351
tigersharkdude's Avatar
I was going to buy one of these next month...but the lens on my camera took a shat on me
Old Mar 16, 2012 | 03:13 PM
  #1352
BobPezz's Avatar
That's a bit my friend.
I'm so prince
Old Mar 16, 2012 | 03:18 PM
  #1353
BobPezz's Avatar
Pics:
Looks nice, I think the lighter silver would be a nice contrast & match the aluminum casting under the cap.
Old Mar 16, 2012 | 03:25 PM
  #1354
Rochester,
do you think this cap could be polished out?
Old Mar 16, 2012 | 03:29 PM
  #1355
Rochester's Avatar
Rochester,
What do you mean? It's anodized aluminum with what look like etched or screen-print (same?) lettering... and that's as much as I can say. I don't really have expertise in that area.
The ideal thing would be simply to contact the manufacturer and have them send me one without the printing. I wonder if they'd do that?
Old Mar 16, 2012 | 03:37 PM
  #1356
erty67's Avatar
Decal Specialist
Wondering if I should have made it a CH bigger. Another option would be just black. hmm...
Old Mar 16, 2012 | 04:05 PM
  #1357
BobPezz's Avatar
If it's etched it's down into the metal, silk screened would be raised and could be polished off. However anodizing is very thin, but you could probably try a chemical paint remover on screen printed paint without hurting the anodization.
Old Mar 16, 2012 | 04:06 PM
  #1358
Rochester's Avatar
No, 45mm seems right. Maybe I should have prep'd the surface better, or laid the sticker down better. There is a skilled technique to doing that right, I'm sure. And I'm kind of in practice-mode.
Old Mar 16, 2012 | 04:48 PM
  #1359
Pics:
I like it dude, very well done. big thanks to erty67 for hooking you up, and thusly, putting me on the path to this cover too.
I'll try contacting them to see if htey can do it without lettering, unlikely, but worth a shot.
Old Mar 18, 2012 | 12:07 PM
  #1360
Rochester's Avatar
It's been a few days with the vinyl decal on the radiator cap-cover, and I'm pleased to say the extreme heat seems to have no adverse effect on the material. Oddly enough, quite the opposite has happened. It's smoothed out and laid down flat. Actually, it looks better than when I stuck it on. I don't understand the properties of vinyl, but that's what's happened.
erty67, I'm going to reach out to you again for a smaller version that I can apply to the center of my JDM oil-cap, so that the two match. It's going to look really nice. Thank you, Ed. You've been great.
