bulb help
Old Aug 5, 2010 | 07:09 PM
PTP's Avatar
PTP
bulb help
(2002 max SE)
I am trying to find what type of bulb I need for the map light.
Yes, I have tried to search but all I come up w/ is led replacements.
I just want the stock bulb.
Also, where can I get it, dealer only?
Its not on this site either. http://www.sylvania.com/ConsumerProd...otiveLighting/
Old Aug 5, 2010 | 08:58 PM
KilJim's Avatar
I'm looking for that bulb too for my I30!
Looks like this http://forums.maxima.org/7676496-post342.html
Old Aug 5, 2010 | 09:18 PM
mannetti21's Avatar
For some reason the bulb isn't listed, wasn't listed in the Autozone database either.
May be, or may not be a dumb question...but have you tried removing the bulb and either reading the markings or simply matching it to a similar looking bulb?
Old Aug 5, 2010 | 11:12 PM
KilJim's Avatar
Here's some googling result
Looks like this one here, but the wattage is different https://www.interlight.biz/light-bulb/57&ID=FROOGLE-US
Mine says 12V 10W
http://zilvia.net/f/chat/228537-map-...-question.html
http://www.bimmerfest.com/forums/sho....php?p=2886932
Old Aug 6, 2010 | 03:20 PM
DennisMik's Avatar
Nissan uses a special bulb that is much brighter than any standard replacement bulb. Like KilJim says, it is a 10 watt bulb while all the standard replacements are (I think) 6 watts. Nissan has been using this bulb for years, I went through this with my 3rd gen. I finally admitted defeat and went to the dealer and got some. Of course the price was higher than a parts store but it really wasn't outrageous.
Old Aug 6, 2010 | 07:19 PM
PTP's Avatar
PTP
OK then the stealership it is for this one.
Old Aug 6, 2010 | 10:07 PM
Rods03Max619's Avatar
Old Aug 10, 2010 | 02:33 PM
KilJim's Avatar
Update:
I just came back from Walmart, bought a pair of GE Standard 1895/BP2 bulbs which looked to be the same shape and voltage
They work just fine, not sure if they're less bright or not, but they cost under $2 for the pair
Old Aug 10, 2010 | 03:06 PM
VQP0WER's Avatar
BTW, it's a 12v, 6 watt, Nissan P/N: 262825L300
Old Aug 10, 2010 | 03:13 PM
03VQMAX's Avatar
Ba9s base bulbs work too, I have led boards in my map lights with that base.
Old Aug 10, 2010 | 03:27 PM
Rochester's Avatar
This. It's a standard BA9S socket. Note, if you replace it with a LED, you're going to have to swap the polarity; (i.e., snip & swap the wires.)
I'm using this little guy here. Much brighter, white light, but not at all distracting. Very happy with it.
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
