5th Gen Max -- 245/40/18's or 245/45/18's???
Old Sep 3, 2010 | 05:55 PM
perfectmax's Avatar
I picked up some 18" infiniti wheels and am having a tough time deciding which tire to wrap them in. I want a smooth, comfortable ride and I'm only using H&R springs in the front (rubbing won't be a factor). Tirerack says that I should go with a 245/45/18 so that my speedo is correct.
Long story short, I ordered Bridgestone 245/45/18's and they look HUGE in diameter compaired to my OEM 225/50/17's. Is anyone using 45 profile tires on 18" wheels and liking the setup or should I send them back and go with 245/40/18" tires?
Thank guys!!!
Old Sep 3, 2010 | 07:18 PM
LongIslandMax's Avatar
Thank guys!!!
You might want to post this in the wheels/tires section, you'll probably get more help in there....
To answer your question, there are alot of people that run 245/45 tires on many different oem wheels from maxima, 350z, infiniti etc... With the mild drop that the H&R springs provide, a 45 sidewall with look perfect (IMO). Although this is coming from a person who prefers a beefy looking tire, so take that as you may....
If you already ordered them, then I think the decision has been made, and one way or another you will come to love them. Goodluck and post some pics up when you get them installed.
Old Sep 4, 2010 | 02:41 PM
soto2635's Avatar
i have 18in 350z rims on my max and im have run both sizes and i like the 245/45/18 better the 245/40/18 look to small IMO, stick with the 245/45/18
Old Sep 5, 2010 | 10:58 AM
asianstyle's Avatar
are you lowered? do you have any rubbing issues with the 245/45/18? and do you have any pictures?
Old Sep 5, 2010 | 01:46 PM
soto2635's Avatar
i was lowered before and no rubbing issues the only time i really rubbed was when i had people in the back seat
Old Sep 5, 2010 | 02:00 PM
Maxgig's Avatar
I'm running 245/45/18's and rub on hard bumps and when I have rear seat passengers. I just had new stiffer rear struts installed and they only helped a little bit.
Old Sep 5, 2010 | 03:37 PM
Rods03Max619's Avatar
I'd say 245/40/18's
Old Sep 6, 2010 | 06:51 AM
CMax03's Avatar
245/40/18 is closer to the original 225/50/17 diameter....if you could find some nice 17x8 or 17x 8.5 lightweight racing rims the perfect step up would be 245/40/17 and your speedometer would be perfect as OEM...with 245/40/18 your speedometer is running lower than you're actually traveling....245/45/18 rub and really throw your speedo off.....
Old Sep 6, 2010 | 07:48 AM
Shift_Max's Avatar
245/40/18...
Finkle
Sep 27, 2015 09:53 PM
JoeWhit
Sep 20, 2015 08:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
tgreen
Aug 27, 2015 08:34 PM
wellz
Aug 26, 2015 09:05 PM
