A couple of 5th Gen questions
Old Oct 24, 2010 | 06:03 AM
atomztwins's Avatar
I recently bought a '00 SE with 163k on it. It was a California one owner car. This is only my second Max, so I am still something of a noob on them. It has a couple issues that need to be addressed. First: I notice the engine moves quite a bit when the engine is revved. I was thinking it was the rear mount, but after reading on here I am not sure. Should I replace all of them? What are ES mounts? Next: it need new brakes all around and the brake light on the dash is on. It goes off sometimes, but not very often. With this, the brakes lights do not work (new bulbs). Is there a connection, or is the switch on the pedal bad? Last: There is a lot of wind noise coming from the sunroof, but it does not leak. Can it be adjusted? The car also need new shafts as the outer boots are gone. This isn't a problem, I did new shafts on my '95. But, does anything else need to be addressed when I change the axles? Thanks in advance for the help folks.
Old Oct 24, 2010 | 01:46 PM
J-Rod's Avatar
1st= change them all. IIRC ES is the brand.
2nd= change the brakes and the bulbs and the light should go out, if not then you have a problem with you ABS, and you could search those issue's here
3rd= this is a good question, I don't think you can adjust the roof. If you could it would be very minuet.
Axles= yes change them, and you will need to replace (or be prepared to) the transaxle oil if manual or transmission fluid if auto. Passenger side has 3 bolts about halfway towards transmission, you can't miss them... be sure to remove these three they are tedious boogers.
Old Oct 24, 2010 | 01:53 PM
Prophecy99's Avatar
use shims for the Sunroof Noise
Old Oct 24, 2010 | 03:31 PM
atomztwins's Avatar
Tanks JRod...Shims where Prophecy?
Old Oct 24, 2010 | 03:51 PM
Prophecy99's Avatar
you can buy shims to nudge the position of the sunroof for the exact reason you need
Old Oct 24, 2010 | 04:07 PM
Dubb1234's Avatar
I am in the process of replacing the water pump on a 1995 nissan maxima.. I have followed step by step step instructions of the Haynes manual. However i was in the process of reinstalling the tensioner on the guide of the timing chain towards the top of the motor and accidentally let the spring coil and the little plastic piece come out and it fell down inside of the motor ..Anyone know of any way to get the spring and plastic piece out without taking the whole timing chain cover off???
Old Oct 24, 2010 | 04:10 PM
atomztwins's Avatar
The bulbs are new. I hear the switch on the pedal clicking and the 3rd light comes on, but no brake lights on the other two. Tails work though.
Old Oct 24, 2010 | 04:28 PM
trooplewis's Avatar
Do a search on the 4th Gen forum. Lots of stuff on it over there.
This is the 2000-2003 Maxima group
Old Oct 24, 2010 | 05:09 PM
atomztwins's Avatar
Ya, I am a little slow. I didn't have the bulbs pushed in all the way. I put some CRC on them and everything is kosher now as far as the taillights go.
Old Oct 24, 2010 | 05:12 PM
atomztwins's Avatar
Now, where do I find the IIRC ES mounts?
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
ef9
Aug 27, 2015 07:21 AM
