underdrive pulley break crankshaft???
Old Dec 18, 2001 | 03:48 PM
maxgsxr1
i just installed a underdrive pulley on my 2k1automax. when i removed the stock pulley i noticed a rubber dampener in the middle of pulley. does this dampener take out vibration when car is shut off.(meaning does it give crank to drive belt accessary slack?) is their any chance that this solid pulley will hurt my engine? if their is i'll take it right off. anyone have any problems????
Old Dec 18, 2001 | 05:35 PM
UMD_MaxSE's Avatar
Got Bent?
No. The crank pulley is not used as a balancer or damper for the crankshaft at all.
Old Dec 18, 2001 | 05:46 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Did you accidentally take off the seal?
Old Dec 18, 2001 | 05:48 PM
UMD_MaxSE's Avatar
Got Bent?
thats what it sounds like... if the crankshaft seal came off, you might as well replace it with a new one... go get one from the parts dept.... it's cheap
Old Dec 18, 2001 | 07:41 PM
BigDogJonx's Avatar
yeah I agree with UMD, should be any problems unless you already removed or have a destroyed/old crank shaft seal.
Dixit
Old Dec 18, 2001 | 07:58 PM
maxgsxr1
i didnot remove the seal! if you look at the pulley from the side you will see a hole in the center and the ridges for the belts. , between the ridges and the center hole their is rubber inside the dampener.i think it absorbes shock.take a look at stock pulley and see....
Old Dec 18, 2001 | 08:00 PM
BigDogJonx's Avatar
I think that was there cause maybe they decided they wanted to do a shaft screw and decided not to. I dont know, sorry
Old Dec 18, 2001 | 08:07 PM
Y2KevSE's Avatar
I've pulled off and put the stock pulley on many times and have never seen a rubber piece in the center hole.
Old Dec 18, 2001 | 08:16 PM
maxgsxr1
its not in the center hole , but built into the casting......maybe only 2k1 has this....btw cali spec. put it this way if the rubber broke the pulley would be in two pieces ( belt drive surface and center piece)
Old Dec 18, 2001 | 08:19 PM
BigDogJonx's Avatar
Whoa, i got a 2K1 and I am gonna have to take a look at my stock pulley in the garage tommorow, maybe i will take some pics too
Old Dec 18, 2001 | 08:20 PM
Y2KevSE's Avatar
Hmmmm...... do you have a digicam by any chance? I have cali spec also.
Old Dec 18, 2001 | 08:29 PM
maxgsxr1
sorry no digital camara
Old Dec 18, 2001 | 09:36 PM
BigDogJonx's Avatar
I'll get the pics of it Kevin tommorow........ for sure....
Old Dec 18, 2001 | 11:41 PM
Menasor's Avatar
What's up Big Dog? I have a question for you...do you have a 5 speed or an automatic? My guess is you have a 5 speed. Reason i ask is because i heard that installing a UDP on an automatic is harder than it is on a 5 speed. Take care.
Old Dec 19, 2001 | 04:46 AM
UMD_MaxSE's Avatar
Got Bent?
he has an auto... installing the UDP is not too tough. You need to be patient with the tensioners and to break the bolt off, you will need to use the starter trick....
Old Dec 19, 2001 | 05:01 AM
GregP's Avatar
These are pics of the stock crank pulley from my '99 Maxima. I thought what you were describing was the oil seal, but after reading further, I don't know what you're talking about!
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Underdrive%20Pulley.htm
Old Dec 19, 2001 | 05:03 AM
GregP's Avatar
That link looks screwy. Sorry. Just go to http://www.greghome.com
and then go to the power modifications section, then UDP. You will see the pics there.
Old Dec 19, 2001 | 05:09 AM
Max_Gator's Avatar
I think we've been through this several times.
The rubber he's talking about is not the seal. There is an area with rubber. My recollection from talking to UDP when I put mine on (think it is on their site too) is thatrubber is there to reduce tortional force. However, the diameter of the UDP is smaller so there is no need for the rubber. It is not a harmonic dampener.
Old Dec 19, 2001 | 10:38 AM
BigDogJonx's Avatar
Yeap just like Nauman said, hehhe (he was there to help on the UDP install)
The only part that is hard is loosening the tension stop bolts. Those bolts are against the wall of the engine compartment and does not leave much room for your hands, need small hands. Once you got that done, you have it made.
The bolt on the actual crankshaft can be removed by the start trick, put a breaker bar on that bolt and put the breakbar again the lower suspension brace, "blimp" the starter from the inside and you will know that you "broke" the bolt.
Simple.
Dixit
D Mason
Jun 21, 2016 04:43 AM
hayne
Oct 5, 2015 11:53 AM
Need help
23
Oct 2, 2015 08:56 AM
