Other Nissan headunit compatible with 5th gen?
Old Jan 17, 2011 | 03:20 PM
Amave's Avatar
Just out of curiousity, are there any other radios compatible with the 5th gen?
The reason why i ask is there is a company that sells OEM factory radios for cheap , and i kinda wanted to keep my Max all OEM as much as i can.
My cd player doesn't work , but the radio does and i was looking to get another head unit
Old Jan 17, 2011 | 07:45 PM
nismo maximus's Avatar
nissan uses BOSE (BLOSE) sound systems. the headunit and speakers use 2 OHM's. most, if not all, other systems/speakers run with 4 OHM's. which means that you will need to replace your speakers as well. i know there is a way that you can wire up a 2 OHM speaker(s) with a 4 OHM headunit. just google search and im sure you will find some results.
something i found on google search- http://answers.yahoo.com/question/in...4115708AAxWeRf
scroll down and the other answers give links to sites
hope this helps, Kevin
Old Jan 17, 2011 | 08:20 PM
nismopc's Avatar
Only Nissans equipped with the optional Bose system have Bose installed.
As far as I know and historically speaking, most commonly used OEM Nissan sound systems are Clarion built and use 4 ohm speakers.
Old Jan 18, 2011 | 09:49 AM
Froggmann's Avatar
TO answer your question, no. I have not seen anything out there that has the same shape as the 5th gen's dash. So you're out on the HU. Other parts like the amps and speakers are interchangeable between some Nissan and Infinity models. I know you are trying to keep your car as stock as you can but really nobody is going to fault you for replacing an 11 year old non-functioning headunit.
Old Jan 18, 2011 | 11:32 AM
Amave's Avatar
yeah i kinda figured the 5th gen is a one of a kind model..i did find a used BOSE cd/radio/cassette unit on ebay for cheap ..
but i keep getting outbid ! gggrrrr
well if i cant keep it stock i guess its time to upgrade to something fancy like an in dash dvd player..
thanks for the responses guys
Old Jan 18, 2011 | 12:06 PM
Prophecy99's Avatar
im in the same boat, want to keep a stock look and upgrade to eliminate the cd playback speaker cut outs..(forever)
I was thinking other gens but nothing really would fit to well, that I know of.
Old Jan 18, 2011 | 02:10 PM
shrader22's Avatar
i have a factory bose headunit and non bose unit. could sell you one if you wanted it.
both cd players work great on each unit
stevesmax
Dec 17, 2020 11:57 AM
ah2002
Mar 9, 2016 01:42 PM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
BobMax
Aug 19, 2015 04:39 PM
