Developing A Starting Issue
Old Apr 20, 2011 | 11:37 AM
Professor's Avatar
Recently i been having a hard time starting my car, (00 max) It seems to do it after i run it awhile and drive around, It will just crank and crank and make blub blub noises , Like it has open headers or something with the timing, but it runs and drives fine once i get it started.I just hit 160K on it, has not ever gave me any major issues, maf was replaced, starter and alternator, thats all. If anyone has any clues or idea's please share it. Thanks.
Old Apr 20, 2011 | 11:46 AM
NmexMAX's Avatar
dot dot dot ...
SES?
Could be a CPS.
Old Apr 20, 2011 | 11:48 AM
Professor's Avatar
Originally Posted by NmexMAX
SES?
Could be a CPS.
Only a O2 sensor code.
Only Codes I got.
I forgot to mention I smell heavy fuel vapors that have a odd smell not like raw fuel before i can get it started. then it chugs like it has a huge cam them smooths out and idles fine.
Old Apr 20, 2011 | 07:05 PM
Professor's Avatar
Ok i got some advice from a member on nycmaximas, here are my results.check the 2 vids posted at the bottom
new ground to tranny and cleaned cps on trans.
http://www.youtube.com/watch?v=pGaskdErfPg
http://www.youtube.com/watch?v=9XfZa-Atqjc
Old Apr 21, 2011 | 05:16 PM
Professor's Avatar
So far so good
Old Apr 21, 2011 | 06:59 PM
TunerMaxima3000's Avatar
Great the tranny ground was what I was going to suggest. Hope it keeps up!
Old Apr 22, 2011 | 09:19 AM
hillbilly4u's Avatar
Mine takes spells of not starting. Takes 2 or 3 trys before it cranks over. Will go for days without doing it again. Gonna check this ground thing. Maybe my problem too.
Old Apr 22, 2011 | 02:58 PM
slimbim's Avatar
Professor: Can u or another member advise on the steps to change the ground to tranny and how to clean the cps sensor. Where are these items located? What was used to clean the sensor?
Thanks!
Old Apr 23, 2011 | 09:24 PM
Professor's Avatar
Thanks!
Here is the link where i got the info, You have to be a member of the forum to view it, It is a great writeup and explains what you need to do.
http://www.nycmaximas.org/showthread.php?t=57581
Old Apr 24, 2011 | 01:44 PM
crazy97's Avatar
Ground the tranny and the starter mounting bolts. Did you have tranny or clutch work done before this started happening?
Old Apr 24, 2011 | 08:28 PM
Max_5gen's Avatar
Originally Posted by Professor
So far so good
It might very well be 'it' - at least the ground route from starter back to the battery should be cleaned as the current is really high there during cranking.
In general though I hate these things - you never know if it was really it or you simply moved something while doing it. Only time will tell - let us know please in a month or two or if it comes back (wish not).
Old Apr 25, 2011 | 09:24 PM
I ran a new ground and its starting every time now. Glad I found this.
Old Apr 25, 2011 | 10:05 PM
FlipCpt45's Avatar
Ah, my 5th gen had starting problems every once in awhile.. I would try to start it and it would just keep cranking..
My 4th gen is a diff story though.. Turn the key and silence, nothing happens.. Gotta keep turning the key until it starts.. lol, nobody drives it though.. only has like 58k Miles..
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
02PearlSE
Oct 7, 2015 02:12 AM
Maxima30
Sep 7, 2015 06:13 PM
dauntlessmax
Aug 5, 2015 10:29 AM
