Stopped accelerating all of a sudden
Old Jul 26, 2011 | 04:12 PM
T.One's Avatar
Okay today on my way back from work, hella hot. So i got my ac on full auto At 60 degs. Subs blarin in traffic at a red light. Go to step on gAs and no acceleration. I was like wts! So i push 70% throttle Nd launch off the red light.
Got home today checked charging system. At idle with nothing on its at 13.7. Is that normal? Okay so. Lights on only still at 13.6-.7 so thats not doing anything. Go turn on ac, bam down to 12.5. Note this is at idle. So now i turn on subs full blaring wakin up neighbors loud and still 12.5. So is the battery just being weak mode? I am running off of an oem nissan battery manufactured in 06. Pretty sure its just the battery ****tin hard but jus makin sure.
Old Jul 26, 2011 | 10:20 PM
T.One's Avatar
Nothings?
Old Jul 26, 2011 | 10:25 PM
BronxSleeperMax187's Avatar
I would guess tranny went into limp mode cause of heat and you mashing the throttle like its A Skyline...more details would help?
Old Jul 27, 2011 | 08:07 AM
Chris Gregg's Avatar
Get Off My Lawn
+1 for clarification on nothing.
Without further information and making assumption about what you're talking about, I could throw out lots of stuff....heat soak, tranny fluid low, shifter linkage off, throttle body malfunction, accidently hit brake instead of gas....?
Old Jul 27, 2011 | 11:32 AM
NmexMAX's Avatar
dot dot dot ...
year?
Old Jul 27, 2011 | 12:04 PM
infinimax96's Avatar
My 96 i30 did this exact same thing. Car wouldn't rev past 2500RPM from gas peddle but would rev fine if you pulled the throttle cable. Ended up being a clogged fuel filter. Replaced with a Fram Fuel Filter and all the power returned.
Old Jul 27, 2011 | 03:35 PM
T.One's Avatar
I got an 02 max. Was just at red light just left work. About to go from red light 20% throttle no movement, no rev nothing. Just chillin at idle. Didnt dog on the car.
Old Jul 28, 2011 | 11:35 AM
Get Off My Lawn
You don't have a Sprint Booster do you?
Old Jul 28, 2011 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
Battery is fine if it starts. Sounds like failsafe mode to me.
Old Jul 28, 2011 | 11:39 AM
Get Off My Lawn
J/k. I'm certain this is not a battery issue, but sound electrical. Since our 5.5 gens are drive by wire, it would seem there was a malfuction in either the pedal or the throttle body itself. I'm not sure, but imagine the pedal is a glorified potentiometer, so there may be a brake/gap developing in the sensor...similar to the hiccups that occur in prior throttle cable set ups using the throttle position sensor. Easiest thing to do is take to Autozone or Advance and see if there is a pending code. I'd also try to repeat this event by sitting in park and very gently and slowly depressing the gas padal to see if there are any dead spots.
Old Jul 28, 2011 | 11:41 AM
NmexMAX's Avatar
dot dot dot ...
You've just explained fail safe mode and it's background.
Old Jul 28, 2011 | 11:46 AM
T.One's Avatar
Well i was thinking that maybe the battery had no
Charge left in it so nothing was getting enough amperage. Sub did cut out one time as well
Old Jul 28, 2011 | 01:47 PM
NmexMAX's Avatar
dot dot dot ...
Your car will run without a battery.
Old Jul 28, 2011 | 07:36 PM
T.One's Avatar
I no dats. But if i gots everything on and theres no power inthe reserve, then it would cut in and out
Old Jul 28, 2011 | 08:04 PM
Get Off My Lawn
Actually, in regards to your engine, it would stutter and/or stall...NOT fail to do anything.
But, perhaps you are right all along. In that case, fixing your inadequate grounds and power supply should ensure this never happens again.
tarun900
19
Dec 20, 2021 06:57 PM
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
