Metal Clanking Sound When Turning?? WTF Could This Be??
Old Sep 24, 2011 | 07:01 PM
colind94's Avatar
So I'm not really sure when it started because you cannot hear it with the windows up/radio on. So while driving today with the windows down, while turning, there is a loud clanking noise coming from the driver side wheel well. It does it when I turn both ways, doesn't matter or change the noise with a different direction. RPMS or speed make no difference and it doesn't do it at all while going straight. My first thought and a good sound comparison was a metal backing plate loose and clanking around, but the front brakes don't have backing plates so I ruled that out. I also looked all around the wheel/suspension gettup and didn't see anything peculiar or loose. Everything performance wise is factory on the car btw.
So what do you guys think?? Any thoughts of where to start at all? Thanks
Old Sep 24, 2011 | 07:20 PM
02pearlmax's Avatar
Check your steering bump stops. Mine were missing when I bought the car and made a loud metal on metal noise when turning at full lock. Checking/replacing them is an easy 5 minute job.
http://forums.maxima.org/5th-generat...placement.html
Old Sep 24, 2011 | 07:22 PM
J2FRESH's Avatar
im pretty sure its your axle
Old Sep 24, 2011 | 07:25 PM
SandyMax96's Avatar
Does it go... "cla-clank-cla-clank-cla-clank"?
Old Sep 24, 2011 | 07:37 PM
colind94's Avatar
It's not really like a clanking/clicking it's an clanking/metal grinding. How do I check a bad axle?
Old Sep 24, 2011 | 08:22 PM
weezeey's Avatar
Could be your top strut mount too. Mine make clunking noises only while turning before I replaced it.
Old Sep 24, 2011 | 08:33 PM
SandyMax96's Avatar
If it's a metal grinding it could possibly be the brake pad brackets. Those tend to almost grind/screech against the rotor when in drive due to seized pins on them. But you mentioned that it's only when turning, so like the previous post, it could be the top strut mounting bracket. If it's coming from the "inside" of your car, say in the cabin it's really noticeable, then most likely it is. It's a pretty simple process and shouldn't take a long time. Only thing is you'd need the alignment afterwards.
Old Sep 24, 2011 | 09:57 PM
zzmmrx0xmzz's Avatar
Also try checked the power steering fluid levels
Old Sep 24, 2011 | 10:12 PM
Nexus67's Avatar
You might need cap stops. Worth checking if you haven't.
http://www.courtesyparts.com/cap-stop-p-354784.html
Info:
DJLAX152
May 4, 2021 11:46 AM
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
TheMafia
Sep 4, 2015 08:26 AM
