Headlight Socket Wiring - Help Identifying?
Old Dec 7, 2011 | 07:06 AM
MrEous's Avatar
^ Jeff™
Can someone identify the wiring going to my headlight socket in the pics below? This is on a 2003 Maxima.
I was guessing positive/negative on the sockets with only 2 wires but unsure on the socket with 3 wires. Then I was thinking maybe the bulbs are grounded in the headlight casing itself?
Orange Socket goes to blinker/clearance light:
Green = + (?)
Black = - (?)
Gray Socket goes to low beam:
Blue = + (?)
Black = - (?)
Pink/Yellow = ??
Black Socket goes to high beam:
Blue/White = ??
Pink = ??
Sorry for the noobish question...I couldn't find anything regarding the sockets themselves on a 2002/03 specifically.
Thank you in advance,
Jeff
Old Dec 7, 2011 | 02:34 PM
MrEous's Avatar
^ Jeff™
Bumping for the experts off from work crew.
Old Dec 7, 2011 | 03:03 PM
DennisMik's Avatar
I will add comments onto your "chart". The info is from pages EL-44 and EL-84 of the 2003 FSM.
Green = + (?) 12 volts from flasher unit. FSM says yellow stripe on wire.
Black = - (?) direct to ground. I am not sure that I have properly identified this connector. FSM only shows turn signal lamp on this connector.
Blue = + (?) 12 volts from headlamp relay
Black = - (?) direct to ground, but FSM shows a yellow stripe on the wire.
Pink/Yellow = ?? 12 volts for parking lamp. FSM shows red/yellow wire. Lamp is connected to ground inside the headlamp & uses the black/yellow wire.
Blue/White = ?? ground through headlight switch on steering column.
Pink = ?? 12 volts from headlamp relay
Old Dec 7, 2011 | 03:04 PM
TunerMaxima3000's Avatar
Green = + (?)
Black = - (?)
Blue = + (?)
Black = - (?)
Pink/Yellow = ??
Blue/White = ??
Pink = ??
Jeff
http://forums.maxima.org/5th-generat...ml?ref=esp-img
The pics were small sorry if it's hard to read. I wrote the terminal designations (1,2, etc, they're layed out as pictured)
Old Dec 8, 2011 | 06:46 AM
CMax03's Avatar
If you have an 02-03 that's HID....What problem are you having? blowing fuses....etc?
Old Dec 8, 2011 | 07:10 AM
MrEous's Avatar
^ Jeff™
Umm...aftermarket lights. Just making sure on the wiring.
Old Dec 8, 2011 | 07:12 AM
MrEous's Avatar
^ Jeff™
Thank you Dennis and Tuner for the descriptions...
Old Dec 8, 2011 | 02:11 PM
NP let us know how you make out!
doctorpullit
Oct 28, 2019 10:58 PM
D Mason
Jun 21, 2016 04:43 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
