Record 0 - 60 times? Dash Hawk
I was watching some videos on youtube and I seen someone get 0 - 60 times on a MazdaSpeed 3 with this device. I thought it was pretty cool. Does anyone know if this will work on the 02-03 Maxima? I looked at the info and it said something about a "CAN Bus" I have no idea what that is. If it doesn't work does anyone know anything similar that can be connected to see 0 - 60 times? I have Cipher and it is supposed to do it but the feature is greyed out and wont let me do it.
http://www.dashhawk.com/features.html
"CAN Bus" is the language that cars speak. I think. I guess it gets its information from the wheel sensors to calculate mph. I wonder how accurate it is. It didn't list what Nissan's it works with thou.
Just get a cheap ODBII bluetooth adapter and pair it to your phone, then get the 5$ torque app. Its the same thing except it runs on your phone so no need to buy this device, it calculates 0-60, 0-100, 1/8 and 1/4 times you can also enter your weight and such and it will estimate your hp and Tq, even graph it for you. It also has 2 axis g meter, monitors a large assortment of engine stats and is fairly responsive. It also allows you to pull codes and clear them. not bad for around 35 bucks.
And yes both 5th gens have a CAN-BUS
It also has a cool app built in that will flash a shift light at what ever rpm you select which i thought was pretty cool
^^^ That's actually a good idea.....cheaper too! do you have this ap? How acurate are the 0 - 60 times and 1/4 mile times?
I haven't actually found a place to do a standing 1/4 yet but hopeful I will find a spot soon, but overall it works pretty well
I was at a light from a dead stop and the freeway entrance straight ahead of me last night......accelerated as soon as light turned green...said 0-60 was 8.3 seconds.....flat surface...no hills.
Then later I was at a stop sign then turned LEFT going UP a pretty steep hill and said 0 - 60 was 8 seconds.....WTF??? YEAH RIGHT. Honda Civic faster than that!!! Even looking at the speedometer on torque you can see it gets to 60 mph faster than 8 seconds.....soemthing is wrong. I dont see how you getting 6 seconds.....unless I'm doing something wrong. I think I'd be better off with one that is connected directly to the device....bluetooth seems to have some lag.
I believe the weight would only affect the hp/tq numbers, what phone do you have? could be the phone is not fast enough either perhaps? Ive also read that not all those ODBII elm 327 adapters are the same, even though they look it on the outside.
also those were my times in the summer, im not sure where in PA you are put right now i doubt i could do better with the snow we got in ohio
Hmm very strange, I dont know why it seams so off, Im using a Droid Bionic for what its worth but the X is still a very capable phone so I would doubt that be an issue
I wonder if they make a hard line version that connects to a Droid usb port, that be sweet to pair with the Torque App
maybe something like this to avoid waiting on the cars ecu at all would be better albeit more expensive
http://www.amazon.com/T-Matrix-3-Axi.../dp/B000KZRE5E
EDIT: Does yours talk??? When Im accelerating real hard the phone says something......cant hear what its saying over the exhaust!!! LOL! Maybe its saying "MALFUNCTION" LOL.....which would be the reason for the 8 second 0 - 60 bogus times???
I got the Vgate OBD II Version 1.5...the old ones were 1.4....which one you have?
and no lol ive never heard it talk ill have to check that out to and maybe try some runs tonight i havent tried since this summer, maybe it just dosent like the cold
But i did google some more info on the app and some others are reporting about a 2 second delay so maybe i just got lucky I have no idea maybe just take what it says and subtract 2
Im not sure ill have to check tonight
OK...finally heard what that thing says....when I was accelerating real hard it says: "Caution, icy conditions." It thinks just because its 29 degrees here there is ice...but it was dry out. That was hilarious....so, yes, it talks....tells yo azz to chill out if you going fast in the snow...LOLOL.
You know what....I give up on this torque app and OBD II bluetooth garbage!!! Got 7.3 seconds yesterday...what trash!!! I was actually reading Cipher manual and it says it can calculate 0-60 times...going to try that since its directly connected to the ECU and using the vehicle speed from the ECU...see if that's any better!! Going to flush that STUPID OBD II bluetooth adapter down the toilet after I pizz on it!!!
Matt93SE
04-08-2018 09:23 AM
Cant_Get_Ryte
08-28-2015 06:41 AM
Team STILLEN
08-10-2015 04:29 PM
