Would this be good to use as a midpipe for the vacuum hose
I have a breather filter that I know is getting me the leak code. Anyways, would this due without any problems:
http://www.amazon.com/Spectre-8707-C..._rhf_se_shvl16
Mine doesn't either.......just make sure you have breathers on BOTH VCs not just the front. Most people just put breather on front. Need one on the back VC too. You'll need to cap the upper mani with a vacuum cap once you remove the tube from the Rear VC to the mani.
I would expect the closer the plastic is to the manifold then it would melt. I do not like any of those Spectre products. I had a black coupler on my car and after a few weeks the coupler was deforming and beginning to bulge. I took it off quick as I did not need an intake leak. I guess if this was used by the air filter it would be fine but I still don't like anything from them intake wise. Isn't this cheaper thou?
http://intakehoses.com/Merchant2/mer...gory_Code=SIT7
Wouldn't you rather go with it instead of the plastic?
I have the spectre midpipe and it works fine. Going on 2 months without a problem.
I say get it but the pcv hose is to big to fit the adapter on the midpipe so I had to use a smaller hose and seems to work just fine.
Or you can spend a little more and get one of the best Mid Pipes offered around here on the .org
http://forums.maxima.org/5th-generat...akes-00-a.html
PM knight_yyz (Ray) and see if he has anything available or is going to produce more.
The 2000/2001 INTAKE MANIFOLD is made of ABS Plastic...... it is mounted directly to the block and also directly above the Exhaust manifold.....
I believe the 7th gen Maximas have plastic intake manifolds too...they have dual VIAS and flow way better than the 5.5gen ones.
^I'm with you on that Rochester. Spectre is marketing, the actual parts are about as cheap as they can make them, all the money goes into package/appearance. It's worked for them though, and for some basic components like this thing, who cares if it's cheap as long as it's thick enough to hold clamp force and seal.....
Would I buy it, or YOU? Nope, no chance, but for this guy who is clearly looking to save dollars instead of getting the nicest stuff out there, it'll do just fine. And I won't get into the reasons why I wouldn't buy it, that's too technical for this threads purposes.
IMO I'd just look for a mid pipe on eBay from one of those cheap intake kits. I paid $25 for mine and it's much higher quality then these. I've seen these in AutoZone and they seem very cheaply made.
I think it would work
pkfinn
01-03-2016 03:55 PM
