djfrestyl's DEFINITIVE "I HAVE A SUSPENSION QUESTION" THREAD!!!
Old Aug 17, 2014 | 03:06 PM
  #1121
Mattx's Avatar
Just want to say thank you to Dj. If anyone local is even thinking about putting new struts on. Even if you are mechanically inclined. Go see Dj. I had my entire suspension done by him in under two hours. This guy knows his stuff and the little ins and outs that someone without maxima experience wouldn't know. He's the best I've seen do a strut job and did it on jackstands. He won't be around doing these jobs forever so anyone in jersey or the tri state area check him out you won't be disappointed. Thanks Dj.
Old Aug 18, 2014 | 01:07 AM
  #1122
dwapenyi's Avatar
....he said front stabilizer bar end links) and now that I think about it is that another way to say Front Sway Bar End Links??
Thanks !
Front stabilizer bar = Front Sway Bar
Old Aug 18, 2014 | 05:37 AM
  #1123
djfrestyl's Avatar
Suspension Yoda
Sometime ago i had requested a shop to replace Front Sway Bar Bushings w/ Energy Suspension 22mm and they said my front stabilizer end links have siezed and I need to replace that to do the bushings... does this sound correct at all?
(granted I could have something a little off from memory, but IIRC he said front stabilizer bar end links) and now that I think about it is that another way to say Front Sway Bar End Links??
Thanks !
Yes, stabilizer links = sway bar links = endlinks.
I've never seen a set of links 'seize' - and it is DEFINITELY possible to replace the bushings without touching the links.
Old Aug 18, 2014 | 05:38 AM
  #1124
djfrestyl's Avatar
Suspension Yoda
Nice meeting ya man. Your car was a breeze and I'm glad it all worked out. Start to finish in an hour and 20 minutes!
Thanks for the support!
Old Aug 20, 2014 | 05:20 AM
  #1125
D.Stillwell's Avatar
Hey how are you dude?
New project I'm looking into doing sometime soon. I need to do my breaks, everything from rotors to pads to calipers. I just want all the old, rusty **** gone and in with all new. I also was thinking about 6th gen BBK possibly.
Thoughts? Suggestions? Would you be interested in helping?
Old Aug 20, 2014 | 05:39 AM
  #1126
djfrestyl's Avatar
Suspension Yoda
Sounds like a nice upgrade. 6th gen upgrade is definitely a nice thing to do.
Sure, I can help. It's pretty easy if we replace everything including calipers. We'll finish it off with a full brake bleed. PM me and we can get the ball rolling.
Old Sep 4, 2014 | 09:29 AM
  #1127
NYTooCooL's Avatar
Most comfortable Coilover ride? lol i guess besides Tein Super Streets what are my options as for most comfortable Coilovers.
Old Sep 4, 2014 | 09:33 AM
  #1128
djfrestyl's Avatar
Suspension Yoda
Comfort is subjective. Lots of variables to include when making a judgement like this.
Tein are quite good from comfort perspective.
Old Sep 4, 2014 | 09:35 AM
  #1129
NYTooCooL's Avatar
Well less than $1000, can't fins Tein SS's for under 1200 lol
Old Sep 4, 2014 | 09:38 AM
  #1130
djfrestyl's Avatar
Suspension Yoda
Best coils under $1000 will probably be Megan's or BC's.
Old Sep 4, 2014 | 09:44 AM
  #1131
NYTooCooL's Avatar
THe EZ Streets for Megan? and what are the BC's..
The EZ's are what I just added to my cart for when i get the money lol.
My suspension is horrible right now I can't wait any longer lol... I'm sure the fact that the Fronts are 2 years old cheapos and backs are blown....i keep bending my wheels, etc. Atlanta roads are horrible. lol
Old Sep 4, 2014 | 09:50 AM
  #1132
djfrestyl's Avatar
Suspension Yoda
Yes, EZ Street.
BC's - www.bcracing-na.com
Also search around, plenty of threads about BC.
Old Sep 4, 2014 | 09:52 AM
  #1133
DjHackStyle's Avatar
If ur roads are that bad, I think u should stay away from coilovers, I wasted my money wit those then spent more money going oem
Old Sep 4, 2014 | 10:38 AM
  #1134
djfrestyl's Avatar
Suspension Yoda
^^ Good point.
Old Sep 4, 2014 | 06:58 PM
  #1135
NYTooCooL's Avatar
Hey i've been looking it up but, are coilovers plug & play? I know with struts and springs you need a tool to compress, etc. With coilovers you just install out the box? If so, that just adds to my new decision to go with coilovers. You told me a while back to go with KYB's and H&R because i like comfort. However for the money, and me wanting to be a little lower. I figured I'd spend a couple more hundred and get some decent quality coilovers(Megan or BC). What do you think DJ? The key in whatever I choose is not to be worst than stock for being lowered lol.
Old Sep 5, 2014 | 10:18 AM
  #1136
djfrestyl's Avatar
Suspension Yoda
Yes, swap the entire assembly in/out, no need for compression or decompression of springs.
You DO have adjustments to do before installing them. Can't just install out of the box.
No matter what, if you lower, you are making sacrifices in terms of comfort. You gain that back in handling.
Old Sep 27, 2014 | 09:25 AM
  #1137
Nuffstylez's Avatar
My car is a 04 I35, just like the maxima. Using this thread (awesome thread djfrestyl), I picked up the H&R's, the KYB's, the oem dust boots and the moog strut mounts. Before I tackle this, just want to know, am I using any parts from the old strut setup? Also, should I cut any off of the boot stop? Not too sure about this
Old Sep 30, 2014 | 05:28 AM
  #1138
djfrestyl's Avatar
Suspension Yoda
Yes, you'll still have to reuse the metal upper spring perch, the rubber gasket that goes inside the perch, as well as the strut mount stud plate. When you assemble it should be inherent what you have that's new, and what needs to be reused.
With H&R's you shouldn't need to cut the bumpstops.
Old Sep 30, 2014 | 11:19 AM
  #1139
Nuffstylez's Avatar
Cool, thanks. When I opened up all the boxes, it got kind of intimidating seeing the different parts. But I guess when I take out the old strut and take a look at it, it will make sense, I hope
Old Sep 30, 2014 | 07:25 PM
  #1140
Emaximus's Avatar
I did it a few months ago. TAKE YOUR TIME... It took me a few hours but I took my time with each strut. I even took before pics to make sure I was lining everything up correctly when installing the new stuff. When you get the old strut off, look at it, inspect it, and remember how it looks and goes back onto the vehicle. My springs actually had little paint marks on them to tell which way they were supposed to be facing when re-installed. You can do it, here is the link for step-by-step instructions. I can't tell you how good it felt NOT to pay someone $1000+ to do this...
http://www.shiftice.com/strut_install.html
Old Dec 27, 2014 | 11:40 PM
  #1141
Genes1s's Avatar
I'm doing the wheel bearing (Timken) and found that my outer tie rod is aging ( no play or anything) but it feels pretty loose. I usually go with Moog brand but didn't want to wait for the shipping ( this is DD) and I could find this tie rod at Napa with grease fitting.
http://www.napaonline.com/Catalog/Ca...150_0130975272
Have you guys used any NAPA Chassis parts in general and specifically for their Tie Rod ends ?
Old Dec 29, 2014 | 09:53 AM
  #1142
djfrestyl's Avatar
Suspension Yoda
This looks like a fair product.
Napa usually can get Moog branded products if you don't want to wait for shipping. Usually same day availability.
Old Jan 2, 2015 | 10:31 AM
  #1143
IsaacFall's Avatar
Hi, I have a question regarding coilover installation. So I just purchased a set of Tein Street Advance coilovers for my 5.5 gen and was wondering what I need in addition to the coilovers. Do I need upper and lower spring seats? Do I need spring seat bearings? Do I need new strut mounts? Strut mount spacers? Strut mount plates? Strut mount brackets? And I'm still divided between Moog and OEM strut mounts... Moog's are a lot cheaper but it seems like the consensus around here is to go with the OEM's.
Old Jan 2, 2015 | 11:01 AM
  #1144
george__'s Avatar
If it's brand new shouldn't it be plug and play?
Old Jan 2, 2015 | 11:16 AM
  #1145
IsaacFall's Avatar
It's the Tein Street Advance, so they utilize the stock strut mounts to give it a better ride. I'm just confused as to whether I need the whole slew of parts that I just listed???
Old Jan 2, 2015 | 11:19 AM
  #1146
george__'s Avatar
Why would you need new strut mounts and such on a new part? I don't think so
Old Jan 2, 2015 | 11:36 AM
  #1147
IsaacFall's Avatar
No, the Tein Street Advance do utilize the stock strut mounts; however, I am not 100% on all the parts I will need. These are what I ordered George: http://www.redline360.com/image/cach...rs-500x500.jpg
Do you see how there are no strut mounts at the top.
Old Jan 2, 2015 | 11:42 AM
  #1148
djfrestyl's Avatar
Suspension Yoda
It is not plug and play. You only think you know what you're talking about, but you're not explaining it properly, so you're not helping in any way. You're just causing more confusion. Please stop.
Old Jan 2, 2015 | 11:46 AM
  #1149
george__'s Avatar
That's weird?
I used moog ones
Old Jan 2, 2015 | 11:52 AM
  #1150
djfrestyl's Avatar
Suspension Yoda
Hi Isaac. Kudos to you for asking the right question.
The picture posted is actually missing one part that the Tein coilovers DO come with, and that is the upper spring perch.
In the fronts, based on this diagram, you need part #'s
- 54325 and 54320. They come together if you buy Moog Part #K90655
- 54322. This is a dealer only part, OR reuse your existing one.
In the rear, based on this diagram, you need part #'s
- 55248 (dealer only)
- 56218, 55322, 56217, 56113 - they come together in any Moog or KYB rear strut mount assembly.
In the rears you can reuse all the existing parts - or purchase separately if you want to keep your OEM suspension whole. I do recommend replacing the front strut mounts (hence the Moog K90655 recommendation)
Old Jan 2, 2015 | 11:53 AM
  #1151
george__'s Avatar
Do they always come unpackaged like that? So it's more like a "kit"?
Old Jan 2, 2015 | 01:40 PM
  #1152
IsaacFall's Avatar
Hey thanks so much. This leads to my next question though. So I've been going through the threads trying to find out whether moog or oem would be better, and some people were saying moog is good and some were saying not so much, but there were no complaints on the oem mounts. So, would you recommend OEM?
Old Jan 2, 2015 | 01:51 PM
  #1153
IsaacFall's Avatar
George, the diagram is a picture of the stock strut assembly. The link that I posted is how the Teins look when you get them.
Old Jan 21, 2015 | 01:09 PM
  #1154
Ben2003GLE's Avatar
So is it a MUST to get an alignment after installing coilovers?
Old Jan 21, 2015 | 01:17 PM
  #1155
djfrestyl's Avatar
Suspension Yoda
Generally yes, unless:
1. You don't care about camber, toe, or tire wear.
2. You have lasers for eyes and are able to install coilovers so the car is perfectly aligned afterwards.
(Above holds true for any suspension install - not necessarily just coilovers. Springs/struts, control arms, etc)
Old Jan 21, 2015 | 04:02 PM
  #1156
Donkeypunch's Avatar
Hell yeah 100% or the tires will get chewed up fast. Like in 2 months fast that's how bad.
Old Jan 21, 2015 | 04:58 PM
  #1157
Ben2003GLE's Avatar
Damn. Alright good to know thanks guys. Does that include a rear alignment? I didn't think it was possible to do an alignment on the rear
Old Jan 21, 2015 | 05:10 PM
  #1158
Yes, includes rear. Its possible.
Old Jan 21, 2015 | 06:56 PM
  #1159
Fakie J Farkerton's Avatar
How?
Old Jan 21, 2015 | 07:23 PM
  #1160
IsaacFall's Avatar
I'm with Fakie, I didn't know that the rear could be aligned due to the solid nature of it.
