Governor
Old Feb 28, 2012 | 03:15 PM
vybz05's Avatar
Governor
So yesterday i had the privilege of maxing out my max. This was done in a private area out in the everglades. I did this once, about 2 years ago when all I had was an intake and exhaust. I hit roughly 140 before it would not go anymore. This time, I have 18's instead of 16's, a new transmission, nwp spacers and a block plate. Once i hit a little over 120, i guess the governor kicked in and the revs just kept bouncing back a little before redline. What is the cause of this? Is the governor related to the transmission in any way? Tire size? I did some research and there's nothing conclusive. 4at 2002. Thanks!
Old Feb 28, 2012 | 03:29 PM
NmexMAX's Avatar
dot dot dot ...
4AT has been said to have a soft limiter post 130. Never seen this. IIRC, there were a couple of members (Scottwax & GBAUER) with GPS and a track that recorded numbers higher than 120 in their stock ECU'd AT's.
Mine has seen 136-138 on the dyno (7100 in 3rd).
Depends on your overall tire diameter, they might be off.
Speedo is never really that accurate, just like the tach.
Does it really matter?
Old Feb 28, 2012 | 03:31 PM
Amerikaner83's Avatar
with your different wheels, is your speedo still accurate? Because I think with larger wheels, you're not turning axles as much for a given speed...therefore, the car thinks it's going slower than it really is.....so your car thinks it's 120 but really isnt?
Other than that, hell if I know. I do know that my old Pontiac had rev-limter on it...
Old Feb 28, 2012 | 04:09 PM
bryanakaslim's Avatar
Ya I have a 02 137 is the best iv been I hoping utec will remove this gov
Old Feb 28, 2012 | 04:17 PM
tigersharkdude's Avatar
why? do you plan on going faster than 137?
Old Feb 28, 2012 | 05:13 PM
Been sating up for road track RACECAR!!!!
Old Feb 28, 2012 | 05:19 PM
T_Behr904's Avatar
Are you doing the standing mile runs at the Dade-Collier airport? I've seen several youtube videos of that, and man that attracts some really mean machines!
Old Feb 28, 2012 | 05:38 PM
036mtmax's Avatar
My 03 6 speed saw 145 on the speedo and my 01 SE cut out at 135 because im still running the auto ECU with a 5 speed swap. both cars on G35 18's
Old Feb 28, 2012 | 05:43 PM
Xpcgamer's Avatar
Those standing runs are not cheap. Although I am sure they are cheaper than a speeding ticket at those speeds. OP-May I ask where you did you top speed run? The alley, 27, Crome, just asking cause I can't find any road empty enough for me to do a 0 to 80 run to do some video. Not bashing. Lord knows I have shattered many a limit on the same roads I mentioned on my old CBR1000 back in the day. I am just curious.
Old Feb 28, 2012 | 05:46 PM
Old Feb 29, 2012 | 06:40 AM
NmexMAX's Avatar
dot dot dot ...
No.
If you keep the overall diameter the same, then it won't change.
Basically, something must be a miss on your car. Take it to a dyno, or hit the standing mile with GPS.
Otherwise, this thread will end.
Old Feb 29, 2012 | 06:42 AM
zero2sixtyZ's Avatar
You embarrass me.
Old Feb 29, 2012 | 06:48 AM
guarj17's Avatar
My car tops at 120. Tried it a couple times and I get the same thing as you vybz05 with the revs bouncing back. I have 19'' wheels and not sure of the tire size so idk if that is the cause of not.
Old Feb 29, 2012 | 06:54 AM
NmexMAX's Avatar
dot dot dot ...
Even when I didn't have my TS ECU, I was still able to get past 120 on the dyno. 127.xx @ 6550.
Also, let ourselves not dumb ourselves down, but ...
Not even going to say anything more.
http://forums.maxima.org/8328358-post46.html
http://forums.maxima.org/7703824-post22.html
Old Feb 29, 2012 | 10:03 AM
vybz05's Avatar
Id have to give you a GPS coordinate lol.. way deep in the cut bro, some friends of friends have land and endless road.. the kinda place where you shoot shotguns and light trees on fire.. pretty much in the middle of southern florida.
So whats the real deal here? is the Auto ecu responsible for the governed speed limit? If so, how was it that my original transmission could surpass this speed, and now this one has a limit? It really doesnt matter, but either way, im sure we'd all like to know..
Old Feb 29, 2012 | 10:46 AM
NmexMAX's Avatar
dot dot dot ...
If your AT is an SE, I'm pretty sure it's not.
Old Feb 29, 2012 | 11:16 AM
Rods03Max619's Avatar
My 03 would hit a little under 130, 02 haven't had a chance to see, should be hitting the dyno soon....
Old Feb 29, 2012 | 12:06 PM
NmexMAX's Avatar
dot dot dot ...
I think we're just about finished here.
Bryan91SE
Feb 9, 2008 09:21 PM
venompwr2
Aug 20, 2002 02:59 PM
Bryan91SE
Sep 15, 2001 12:35 PM
Uncle Max
Apr 6, 2001 07:30 AM
