Noob Questionl: How to disable parking light when arming/dis-arming alarm using
Old Mar 8, 2012 | 01:05 PM
Genes1s's Avatar
Ok, this might be very easy for you guys. I don't want my parking lightt & turn signal to come on when I dis-arm/arm the alarm.
How do i do this?
Old Mar 8, 2012 | 01:12 PM
luvlexus101's Avatar
OEM or aftermarket alarm?
Oem should be flashing the turn signals?
Aftermarket it would be a setting.
Old Mar 8, 2012 | 01:26 PM
TallTom's Avatar
I don't think you can with OEM. You can toggle the horn off and on though.
Old Mar 8, 2012 | 01:47 PM
ranmas2004's Avatar
Guy showed me THIS^ at the meetup. I hate that BEEP BEEP from the horn when you lock the car.
Old Mar 8, 2012 | 05:32 PM
Genes1s's Avatar
OK, how to dis-able the horn then......
Old Mar 8, 2012 | 05:34 PM
Genes1s's Avatar
OEM 00 Maxima SE if that makes any different. I guess I'm going to have to tap the power somewhere else. I was going to run my high beam projectors using parking lights for trigger, but then I don't want them to flash when I hit the alarm.
Old Mar 8, 2012 | 05:46 PM
TunerMaxima3000's Avatar
I can't see them actually coming on, the flash is a super short double pulse, hardly long enough to charge an HID I should think, but I dunno.
Why do you want your high beams to turn on when your marker lights are on??
And to disable/enable the beep, the directions are actually written on the back of your key fab.
"Press both lock & unlock for 2 seconds"
Old Mar 8, 2012 | 06:21 PM
Genes1s's Avatar
[quote=TunerMaxima3000;8393507]
[quote]
I'm going to wire my high beam projector on dedicated relay with in-dash switch. I would need a +12V to trigger the relay. Originally I was going to tap the parking light for this purpoe. With this setup, I can toggle the high beam projector on and off whenever I like. I would still wire the selenoid high beam projector together with the one from low beam projector though. Maybe I just go to ignition ACC under the steering wheel and tap the 12+ from there.
Old Mar 8, 2012 | 06:28 PM
Yeah MSU I'd go with ignition over parking light circuit.
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
