wheel bearing??? help!
Old Mar 16, 2012 | 05:40 PM
MOB 02max's Avatar
hey guys, do you guys think this noise means my wheel bearing is bad??
Old Mar 16, 2012 | 05:58 PM
03VQMAX's Avatar
Possibility, but also sounds like your brake shield rubbing, take off the wheel and bend it back, I can't stand when that happens to me
Old Mar 16, 2012 | 06:03 PM
HotshotVQ35's Avatar
i got one brand new pm for a dirt cheap price
Old Mar 16, 2012 | 08:27 PM
MOB 02max's Avatar
i've done that and its still making noise
Old Mar 16, 2012 | 09:01 PM
redcross631's Avatar
i don't think that's your bearing
To be sure, jack up the side where the noise is coming from. Grab the wheel at the 12 o'clock and the 6 o'clock position and see if it has any play in it. If it does then it's most probably your bearing.
Old Mar 17, 2012 | 02:44 AM
Amave's Avatar
also spin the wheel while its off the ground and listen for any grinding
Old Mar 17, 2012 | 03:12 AM
Laevateinn's Avatar
Normally, a worn bearing will make your car sound like a skateboard that goes louder as speed increases. I had my bearing replaced twice in the last 9 months. The shop that did the first bearing job reused the warped and destroyed seal which **cked up it's lubrication within 3 months so I did the job myself.
It seems that the sound only occurs in a certain steering angle. Check your CV axle, pull out the pads and rotor, power steering fluid and pump, and wheel play.
Old Mar 17, 2012 | 10:59 AM
Ghost_54's Avatar
I would also think it sounds like a brake dust shield that needs to be bent back out just a little, try inspecting that area first to see if it resolves the issue.
In most cases when a wheel bearing is going you will hear a humming noise that increases with you speed.
Old Mar 26, 2012 | 02:08 PM
CoreyG87's Avatar
I know this thread is a few days old, but I've been hearing a noise similar to this. Could you let me know what you find out, bro? I cannot figure it out, myself.
Old Mar 26, 2012 | 05:25 PM
ajth87's Avatar
I had a very similar noise as yours. Last week I had the wheel hub and bearing replaced and problem is solved. It is possible that you may have the same issue or perhaps what others have suggested.
Old Mar 26, 2012 | 08:55 PM
CoreyG87's Avatar
I finally stopped being lazy, and got the Max off of the ground, today. I could rock my front-passenger wheel, took it off, and it is definitely the bearing. I would definitely lift it, if you haven't yet, just to make sure. I got lucky, and I don't need a new tire.
bbsitum
Sep 6, 2019 07:31 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
