Even still... The 3000 miles plus hotels and food and whatnot. It's same cost to get them put in without the traveling. Just not viable right now even though the headers are priced right.
Can you get a picture of the strut for me plz?
If they didn't break on the white nightmare, I guarantee they won't break on your car.
dont get me wrong im pretty **** about doing things right just that @ 385k on the clock she may not recover from the work
You adjust them using the 2 collars but there is no 3rd collar at the bottom. They do no spin into the strut. There is no preload
Mine are also a lot lower, there are like 2-3 threads showing form the bottom to the collar.
You're too low for that style of coilover. The spring must always be constrained. If you have a point where there is no load on the spring, the spring will move axially and cause the binding you're hearing. It would be nice to see a good photo of your actual coilover. I bet that's your problem.
Still makes no sense why they would allow someone to adjust that low only if it was going to give problems. I can't get pics of mine until maybe tomorrow.
Also, when the car is down on the ground there is plenty of tension on the spring, it's just when it's in the air.
On the tein ss, preload is height dependant. However preload is not always needed but it is a good idea to have some.
On my tein ss, I have no preload and have about 2-3mm from the bottom of the shock left. When the car is back on the ground, the spring compresses.
I still have a hard time imagining how to adjust this compared to mine
Hm. Is that on your 5th or 4th? Also, are your SSs full length adjustable or only height adjustable?
This is the only thing I don't have. I should prolly craft some. Any thoughts on where to start just getting some rubber that will sit in place well? If I back off the spring completely I can get these installed without even taking the coilover off the car.
The spring does not always have to be constrained. You can run a coilover without having any pre-load on it. You can PRELOAD the springs by compressing them with the perch this will in effect give you stiffer springs (they get stiffer as they get more compressed) initially at the cost of suspension travel.
And yes you can install them without taking off your coilovers.
BTW what is your alignment like now since you have been raising and lowering the car?
The only thing is that the tein ss do not have a fully threaded shock body.
You only loosen one collar (lower one) on the shock body and spin the other collar to either raise or lower the car. Once you are done, you spin the lower collar and use it as a locking collar.
Very simple and easy to adjust
For the hybrid swap, there's a few options. But first things first, FIND A '95 ECU. After this, You can splice the IACV from the a33a/PFTB (if that's what you're gonna use) to your 4th gen harness. If you're going to hack the e-TB, you will need an IACV adapter plate from stephen max. Use an IM from an 04 and route the egr guide tube to the port on that IM. Some people report that with the '95 ECU, they don't get an egr code as long as the selinoid is connected.
Honestly, the hybrid swap will be alot cheaper to finish than the full swap. I haven't even finished the part hunt for my swap 100% yet and I'm way over what I would have spent by doing the hybrid.
Hey guys, spoonfeeding time.
What do I need for a full swap in my 4th gen?
I REALLY don't want to do timing on the 3.5 motor.
So we have...
Gas Pedal
MT ECU
Engine Wiring Harness
Apparently a dash harness for my NATs to work?
So we have...
Gas Pedal
MT ECU
l
This is very true. In some forms of motorsports, the spring is set pretty loose (when the car is off the ground) on purpose to help prevent the inside wheel from lifting mid corner.
Nikka... seriously? As much **** as I've bought from yo punk azz and you don't know! lol
My alignment was done about 2 weeks ago. I've only adjusted the height +-1/4" then. Drives straight and feels good.
I'm just going off of the top of my head on what's different in the motors and what the engine/ecu needs.
So.
ECU
Engine Harness
Dash Harness
Gas Pedal
If I can make the dash harness connect to my NATS I don't need a column+key/wheel/bag then.
So what's next?
/spoonfeedthenoob.org
Main thing is, if the motor is bad, I can just chunk it outta the car and throw another one in, no big deal.
But w/ the timing swap.... *lesigh* ughhhhh
6k, 10k seems to be the magic number here on the org... someone telling you that a part has 6k on it is like that girl u meet that tells you she only slept with 2 guys lol you'll never really know although I'm sure is a stand up guy....
well i got them from Tuner. I doubt he tried to screw me since he is coming down to visit still.
Houston-20120515-00732.jpg?t=1337099418
Name a price for a pedal that covers shipping and handling and my time typing this out and I'll send one out.
I haven't given a single fck about full swaps up until last night when I sat down next to the motor and I went *sigh*... fck this.
So.
ECU
Engine Harness
Dash Harness
Gas Pedal
So what's next?
So.
ECU
Engine Harness
Dash Harness
Gas Pedal
So what's next?
When you guys sell engine harnesses doesn't it come with all the **** you need to actually control the engine?
Yo... at this point I'm about to say **** the swap and **** the car. The guy I ordered the engine harness from only sent me half the ****. There are no grounds, only 3 injector pigtails, 3 coilpack pigtails etc...
Complete and no cuts.
IIRC you'd only get 3 injectors and coils.
The other 3 are on a sub harness.
send that shii back and get your money back and buy a legit complete one. I learned when asking for anything complete, go by a list like name off everything thats suppose to come with it so there no surprises. some people definition of complete varies.
there are no cuts in it. But the rest of it is connected with those green plugs, he left out all of that and only sent the partial harness. Ask your harness guy if the battery power and ground wires are supposed to come with the engine harness.
I'm going to investigate a little more before I start complaining.
This is what I got.
This is more of what I was expecting.
This is from the altima harness I pulled from my 3.5. Notice how it has the battery power wire and everything with it. I assumed the maxima one would come like this too. Am I mistaken?
damn that fckin sucks a$$. when I bought my 3.5 motor it was said to be complete but when they shipped it, I later found out it was missing some parts so it wasnt complete I know the feeling.
good deal too.
