Old May 14, 2012 | 05:16 PM
  #721
036mtmax's Avatar
Originally Posted by merovi
BTW, this is the sounds my coilovers are making. I think it's due to how low they are set. I say this because it was only happening when turning left. It also only happens when the wheel is turned to the max and going slow, creeping in 1st gear. Also I have to be going over a slight bump, like into a drive way.
I adjusted all 4 corners today since they had changed a tad bit, with the rears both not 1/4" higher than the fronts. I had to lower the front passenger to match to driver about a 1/4" and since doing that I noticed the same noise when i turned all the way to the right. That is why I say I think it has to do with being low.
Anyways..onto the video. It's still optimizing so bad quality for now. Should get better.
Again, the ONLY time this happens is going very slowly over a bump and when the wheel is maxed turned. If I don't max turn it it doesn't make a noise.
Im not sure exactly what that noise it is but my car does the exact same thing every morning at the Dunkin drive thru. Wheel locked all the way left and once i start to accelerate there's a dip in the pavement and when i hit it it sounds like that to the T. Haven't been able to check it out yet but i don't think it's Coilover related. I need tie rod ends and a ball joint i know for sure so maybe try checking those first.
Old May 14, 2012 | 05:23 PM
  #722
T_Behr904's Avatar
Wow that's weird, and loud!
What does it feel like when that happens? Does the car twitch or jerk in any way?
It kinda sounds like (of course I could be way off) the c.v. joint is binding up, since it's being tweaked at the maximum turning radius and with it being lowered while turning up into your driveway compressing the wheel up even further into the wheel well while at the end of your turning radius. Turned and compressed suspension causing c.v. joint binding is my theory. Try raising up the suspension an inch, inch and a half and see if it still does it.
Another thing to consider is that unless Rochester had the c.v. axles rebuilt or replaced, you're driving on axles that have mileage on them. This will amplify the problem if this is something c.v. related.
There is something that is binding up quite a bit and releasing alot of force really quickly.
Old May 14, 2012 | 05:24 PM
  #723
Clashez's Avatar
They have removable tops.
Here's a pic with the tops on...
And does it sound like this?
I know somebody that has an toyota mr 2 convention to look just like this car..
Old May 14, 2012 | 05:32 PM
  #724
T_Behr904's Avatar
You mean conversion, not convention, right?
Either way, i'm sorry to hear this information.
Old May 14, 2012 | 05:49 PM
  #725
merovi's Avatar
It just doesn't sound axle related to me. There's no clicking or any noise of any kind. It's just this metal on metal screech. The first noise is from going over the piece of metal in the road that is overlaying something. Just like this
The 2nd noise immediately after the the bump where the street meets the sidewalk/driveway. After that there is no noise even when it's still locked.
I could try raising, but I like my ride height
Also, if you listen to the noise, you can hear it change with the change in spring compression. It has like that up and down tone to it EEEERRRRRR
Old May 14, 2012 | 05:50 PM
  #726
cjandura's Avatar
Clashez is gonna have half max half celica rice mobile
Old May 14, 2012 | 05:54 PM
  #727
Clashez's Avatar
Yes conversion
Old May 14, 2012 | 05:55 PM
  #728
cjandura's Avatar
Did you happen to loosen the preload collar when you adjusted them by accident jack the car up and check if there is spring movement with the strut fully extended
Old May 14, 2012 | 05:58 PM
  #729
Clashez's Avatar
Hahaaa had the gt parked in front out side the road and a guy came knocking at my door with 1500 in hand. Said he wanted the car ..... SOOOO SOLD LOL made 1000 profit. Probably going to a better home any ways guy owns a body shop...
Old May 14, 2012 | 05:59 PM
  #730
cjandura's Avatar
Yes conversion
Your converting?god help us all clashez will be a transves, mormon,crossdressing ricer
Old May 14, 2012 | 06:03 PM
  #731
036mtmax's Avatar
Yep its a metal to metal noise that everytime i hear i cringe but i notice my car does bounce a tad when it makes that noise also. Im not sure how low you are Merovi but im a little less than a finger gap on BC coils. I think it might have something to do with what Tbehr said about being low and the axle binding. Its under alot of stress as is nevermind turning and hitting a rut/bump altogether. I have messed around with the dampeners but it always does it.
Old May 14, 2012 | 06:07 PM
  #732
Rods03Max619's Avatar
Old May 14, 2012 | 06:09 PM
  #733
Crusher103's Avatar
looking at brake upgrades again, and i found the template for making the bracket to fit the STi Brembos, might be useful to somebody:
Old May 14, 2012 | 06:12 PM
  #734
Clashez's Avatar
That not funny to talk like that ... the guy converted his 01 mr-2 to look just like one of those Porsches. I'll snap photos when i run in to him
Old May 14, 2012 | 07:35 PM
  #735
T_Behr904's Avatar
I just Google'd "MR2 Carrera GT conversion", and that thing is so hideous i'm not even gonna link the photo's on the thread. I'd rather you guys go blind from excessive fapping rather than looking at that monstrosity.
Old May 14, 2012 | 07:49 PM
  #736
merovi's Avatar
There is no preload to adjust on the teins. The springs can spin freely.
Old May 14, 2012 | 08:54 PM
  #737
Hope you find the problem....
Old May 14, 2012 | 09:22 PM
  #738
ShocknAwe's Avatar
I would guess CV related as well. If it happens at lock, thats obviously when the axel is at its most extreme angle and then you hit an incline which makes it worse. Or it could be your damper. Do you have boots on your dampers? Lol I have a combination balljoint/CV/steering rack issues, want to trade places? All of that needs to be replaced because I caught torn boots too late. Thats a FML worthy situation if I've ever heard of one
Old May 14, 2012 | 09:32 PM
  #739
MoncefA33's Avatar
Sounds like the springs are binding. Dem dirty azz Tein SS, shoulda got some D2s.
Old May 14, 2012 | 09:39 PM
  #740
ShocknAwe's Avatar
It could be the springs as well thats a good thought. Sounds alot like the raptors in the first jurassic park as well......
Old May 14, 2012 | 10:06 PM
  #741
J2FRESH's Avatar
Originally Posted by J2FRESH
dude that mess is loud i never heard that before, sounds like something loose. Or maybe your springs are binding from being low, hows the pre-load? motor mount? axles? lca's? strut mount?
Merovi my top 3 guess
1. Motor Mount
2. CV axle binding
3. Coilover spring binding
whens the last time if any did you have the above replaced or checked?
I know from a few threads other members had noise and later found replacing motor mounts was the culprit. And I know from experience I had a coil spring bind that made noise but never that LOUD!
Old May 14, 2012 | 10:27 PM
  #742
schmellyfart's Avatar
sent
Thank you sir.
Old May 14, 2012 | 10:43 PM
  #743
TunerMaxima3000's Avatar
This was my thought.
Sounds like a snare drum.
The strange part, is you're not feeling anything in the steering wheel when this happens?!?!?!
I can't think of a single thing that would make this noise in that situation dependant on your ride height, that would NOT cause the steering wheel to shimmy, or at minimum, you to feel something through the wheel/car.
My FIRST impression when I heard it, it sounds like the spring is twisting up instead of just turning, then suddenly releases this twisting tension with the bump.
The only way I see this happeneing is if the mechanic messed up and the upper bearing/mount is jammed up. Or could be that the mounts went bad premature. Either way, I do wonder about the install.
Is it possible to get a picture of the coil installed? And have you checked the obvious, like making sure the lower mounts are tight, the tire/rim isn't touching the coil, the upper strut mount nut is still on and tight, the upper mount nuts still on and tight, etc.?
Old May 15, 2012 | 01:45 AM
  #744
Clashez's Avatar
^^^^^ this what happens when u buy used... sound like the worn out spring is binding.
Old May 15, 2012 | 02:30 AM
  #745
Clashez's Avatar
$ 1500 think I'm going to drop it on some real wheels .... were to look ... someone post up that site again with all them nice wheels please... forgot the name
Old May 15, 2012 | 03:58 AM
  #746
essential1's Avatar
My axles cry for mercy...
Merovi, as long as I been riding on coilovers and as slammed as I am, I've never heard that noise from my car. Something is installed wrong.
Old May 15, 2012 | 04:13 AM
  #747
cjandura's Avatar
Old May 15, 2012 | 04:18 AM
  #748
cjandura's Avatar
http://forums.maxima.org/5th-generat...djustment.html
Old May 15, 2012 | 04:33 AM
  #749
Shift_Max's Avatar
Might be useful to me
Old May 15, 2012 | 04:38 AM
  #750
Clashez's Avatar
This is a good old school joint.... I also like krs1 steep in to my world and mr.cheeks rena one of my all time favorite songs
Old May 15, 2012 | 04:50 AM
  #751
merovi's Avatar
I agree, sounds like spring noise
I can feel it in the steering wheel. I've visually checked everything and it seems fine. I'll have to get another look though. All top nuts are tight. I'll get pics on Wednesday.
6k miles of use. Yup, I'm sure it's because they are used
Old May 15, 2012 | 06:49 AM
  #752
merovi's Avatar
Just talked pricing on getting headers in. NOPE. I'm not a DIY guy when it comes to headers on a 10 year old car either so oh well. Back to thinking about AFR tuning to get a few extra gains some day.
Old May 15, 2012 | 07:09 AM
  #753
aackshun's Avatar
I can't see the video but by reading the descriptions and then on you saying that you can't adjust the load on the spring really makes me wonder if the install did go correctly.
There was a noise when I installed mine, the top nut on the pillow ball mount was loose, tightened it up and the noise went away, it only made noises over certain bumps
And yes that's hella used
My coilovers haven't even seen an oil change yet.
I told you to drive down here and I'd do it
Have it done for Maxus, drive down here all limp come back home w/ the fam like uh BAWSS
Old May 15, 2012 | 07:12 AM
  #754
cjandura's Avatar
aackshun what would it take to transplant the 3.5 into the 97 and be code free?
Old May 15, 2012 | 07:13 AM
  #755
cjandura's Avatar
tuner you get that stuff working?
Old May 15, 2012 | 07:14 AM
  #756
essential1's Avatar
Do you want to do it with 3.0 timing? Or do you want to do the full ecu swap? It's actually pretty easy to swap with no cel.
Old May 15, 2012 | 07:15 AM
  #757
merovi's Avatar
The TEINS don't have preload adjustment, they also don't have pillowballs. I'm going to check out the bolts coming up soon though.
Tempting offer for install... i'm more so worried about bolts breaking off in the heads though. That's my fear.
Old May 15, 2012 | 07:16 AM
  #758
Your idocy really does know no bounds.
worn springs cause them to bind? No, dummy, no.
  #759
cjandura's Avatar
without opening the engine if possible see i changed the waterpump and timing chain/tensioners and f/r seals on the 97 and i'm not feeling too sure of myself on this engine starting up again
Old May 15, 2012 | 07:17 AM
  #760
cjandura's Avatar
not going to happen That car waas kept well and cleaned regular i would personally eat off that engine
