Old May 22, 2012 | 11:35 AM
  #2001
NmexMAX's Avatar
dot dot dot ...
Originally Posted by cjandura
on the nats side it uses it for communication between the bcm for the doorlocks,pinswitches,security light,keysense and a few other systems to tell the ecm to shut off fuel pump and spark then after 5 tries it disables full system starting
This is for the 5.5 gen?
Hmm mmmm
Old May 22, 2012 | 11:37 AM
  #2002
cjandura's Avatar
Hmm mmmm
yup
Old May 22, 2012 | 11:47 AM
  #2003
cjandura's Avatar
lmfao i put a list in the 4th gen section for people that so called themselfs wanting the coilovers all dat shat talk and theres 1 frackin name.if the list aint full by friday im outta there
Old May 22, 2012 | 12:11 PM
  #2004
NmexMAX's Avatar
dot dot dot ...
Why in FS do they (Nissan) only have this (CAN lines) with the AT's and not MT's?
Old May 22, 2012 | 12:13 PM
  #2005
Amerikaner83's Avatar
Because us AT cars are special
Old May 22, 2012 | 12:16 PM
  #2006
NmexMAX's Avatar
dot dot dot ...
A34's are a whole different ball game, as is my R51 ..
Old May 22, 2012 | 12:27 PM
  #2007
cjandura's Avatar
My 02 pathfinder is worse cause allthe traction control and 4x4 functiona
Old May 22, 2012 | 12:28 PM
  #2008
cjandura's Avatar
They say the 03 max was a test bed for the 04+ systems
Old May 22, 2012 | 12:44 PM
  #2009
NmexMAX's Avatar
dot dot dot ...
Yep .. then i am not alone ...
Woulda been nice if they equipped it with a 5AT.
Old May 22, 2012 | 01:05 PM
  #2010
Rochester's Avatar
Hey sugartitz wheres my quote for dem parts buddy!
sugartitz?
I can't exactly see the manzier in this photo, but I suspect you're right.
Old May 22, 2012 | 01:06 PM
  #2011
Shift_Max's Avatar
There's not a lighter wheel out there in friendly sizes in 17x8 or wider with a 3xmm offset. PERIOD.
yeah. IIRC the wheel is 16 pounds for a 18x8.5 42et.
Old May 22, 2012 | 01:08 PM
  #2012
essential1's Avatar
My axles cry for mercy...
from what I remember, no, CAN lines don't need to be connected. I don't even think an SES lights up if there is a problem w/CAN lines.
That's going off of memory.
So going by this.. I can just take my AT lines that run from the TCM > harness > ECM and keep those in my swap. IIRC, they are in the loom, but completely seperate wires.
it depends on which ones if its with the nats system you fubar'd trust me ive hacked my way thru that whole can crap getting my remote start to work proper in the end it was because i had too many nissan keys on my key chain
So going by this, MT wont have CAN in the NATS because that ECU is void of CAN? Meaning that the nesessary lines aren't in my harness.
In conclusion, I'm going to swap dash harness with ACK and run the car with all AT equipment, then jump the P/N switch like I have now. The car will basically be a MT swapped 5.5 gen. I will plug in the CAN system and all.
Old May 22, 2012 | 01:09 PM
  #2013
essential1's Avatar
sugartitz?
The token black guy...
Old May 22, 2012 | 01:10 PM
  #2014
essential1's Avatar
Now... the TCM for 5th and 5.5th gens are the same?
Old May 22, 2012 | 01:12 PM
  #2015
essential1's Avatar
Originally Posted by aackshun
I got one here in stock.
I'll buy it, send it to you, you send me le Manyah harness.
Word. It will simplify both of our lives. lol.
Let me know what address to send it too. I can ship it from work.
Old May 22, 2012 | 01:13 PM
  #2016
Rochester's Avatar
In a stylish cardigan, no less.
Old May 22, 2012 | 01:16 PM
  #2017
aackshun's Avatar
Who is this sugartitz you speak of?
That's actually a halfassed buttoned up shirt.
I can't post any photos, I keep forgetting about the research you're doing here for that book, everything we post is saved
Old May 22, 2012 | 01:18 PM
  #2018
aackshun's Avatar
I wont be getting it till this weekend though.
Old May 22, 2012 | 01:21 PM
  #2019
Rochester's Avatar
No book. Just the Org. I don't keep pictures of you lying around.
BTW, that baby looks familiar.
Old May 22, 2012 | 01:27 PM
  #2020
phatboislim's Avatar
just got my car back from the body shop yesterday, and what does it do today...hail
Old May 22, 2012 | 01:32 PM
  #2021
essential1's Avatar
Yea man. I'm in no rush. It would be ideal for me to get a 6MT ECU. But since I have this ECU, key and ignition all from the same car right now, i'd rather just plug it all up as is and not have to wonder if this CAN ish will **** with me.
From the eperience CJ had with it, it's just better to plug it all up and run it like stock. But from what Nmex experienced, it will just throw some codes here and there but will run fine. Who knows, maybe nissan made some changes to how this system is programmed based on build date. I just don't want to end up with a car that's forever in limp mode.
Old May 22, 2012 | 01:33 PM
  #2022
essential1's Avatar
Old May 22, 2012 | 01:35 PM
  #2023
cjandura's Avatar
You!
and yes he is he's going to make a seperate picture pop-up book for the clashez crowd.all our pics and memorable moments are being collected for his research.
Old May 22, 2012 | 01:37 PM
  #2024
cjandura's Avatar
when i tested and unpluged that dohicky for you it did run but crap load of lights and a blinking cel i caint drive car or i would test further but it did rev to 5k no problem
Old May 22, 2012 | 01:38 PM
  #2025
cjandura's Avatar
nice one
  #2026
essential1's Avatar
Oh yea, aaron, I got some more info on that TB relay situation. It's alot easier than I imagined. I wouldn't swap over the entire front engine room harness only beacuse it becomes a pain once you get into the cabin. Just grab a spare blue relay from any maxima. 2 of the wires go to the ECU and the other 2 go to a 12v power source. Turn the key, hit the gas and watch the TB to make sure it works.
Or you can swap everything over and not worry about that if you want.
Old May 22, 2012 | 01:40 PM
  #2027
essential1's Avatar
But you probably didn't go WOT right?
Old May 22, 2012 | 01:41 PM
  #2028
cjandura's Avatar
well a few rapid fire pedal smashes like i would do wile passing someone
Old May 22, 2012 | 01:48 PM
  #2029
Mr. Brett's Avatar
Just gave my headlights the Minwax treatment.
They look like brand new. No joke.
Old May 22, 2012 | 01:55 PM
  #2030
cjandura's Avatar
show process please
Old May 22, 2012 | 01:58 PM
  #2031
essential1's Avatar
Hmm... Interesting.
Old May 22, 2012 | 02:04 PM
  #2032
Mr. Brett's Avatar
show process please
http://forums.maxima.org/4th-generat...l?ref=esp-link
Old May 22, 2012 | 02:05 PM
  #2033
essential1's Avatar
Question.... How come maxima owners dont use osiris?
Old May 22, 2012 | 02:07 PM
  #2034
aackshun's Avatar
http://captionsearch.com/pix/thumb/2rub7eoeem-t.jpg
You!
I can do that 4 wires is easy enough.
For some reason I though that sentence was going to end with "vagina".
Old May 22, 2012 | 02:12 PM
  #2035
cjandura's Avatar
Map storage i was actually reading on that last night
  #2036
NmexMAX's Avatar
dot dot dot ...
Then we'd need an A34/Z33 ECU.
Old May 22, 2012 | 02:18 PM
  #2037
cjandura's Avatar
With the lack of booty in the thread i think the dumbing effect is reversing
Old May 22, 2012 | 02:24 PM
  #2038
essential1's Avatar
Ahh... Ok. I thought since it plugs into the obd port we would be fine.
Old May 22, 2012 | 02:28 PM
  #2039
NmexMAX's Avatar
dot dot dot ...
I totally think you have a point here.
Originally Posted by Ahh... Ok. I thought since it plugs into the obd port we would be fine.
Darren has a fairly extensive thread in AM about it. But wow, you almost got me excited being that I already have a PnP for a Z33/A34 ... I almost poo'd myself.
Might be like my Pathfinder, I plug in the Cipher and have almost no options do do anything, everything is grey'd out. Vs the Maxima where I at least have all options available with Cipher (not OSIRUS).
Speaking of which, some A34 member should jump on a deal on Altimas.net on OSIRUS.
Saw it this AM, 550$.
Old May 22, 2012 | 02:35 PM
  #2040
aackshun's Avatar
You should be able to use Osirus w/ the Pathy.
if not... Buy a Titan ECU from me and make it work w/ the pathy
yeah they should but we all know how extremely lame the 6th genners are (for the most part).
