Help with engine noise
Old May 31, 2012 | 12:26 PM
snoun83's Avatar
Hi members, I need help with this noise I'm getting from my engine when it is running but when I turn the AC on the noise disappear. I don't know what is wrong with it. Any help would greatly appreciated and thanks in advance.
Here is a video of how it sound like:
http://www.youtube.com/watch?v=y0EtZNPxuuY
Old May 31, 2012 | 07:23 PM
user name001's Avatar
are u sure the noise is actually dissapearing? or could it be hidden from the sound of the a/c fan turned on? its hard to clearly hear the noise, is it only when the ac is turned on? does it go away if u put econ mode on the climate control?
Old May 31, 2012 | 07:58 PM
snoun83's Avatar
Well I think it still there when the AC is on but not sure and my climate control is a manual so it doesnt have an econ mode. well i'll try to get a better sound next and post it up again.
Old May 31, 2012 | 08:09 PM
dfj240's Avatar
It could be the A/C compressor clutch. Especially if it goes away when the A/C is turned on, it's possible that the bearing is wearing out. That would be the first place I would look.
-Nathan
Old May 31, 2012 | 08:19 PM
well is it there when just the heat is on? turning ur ac on kicks your secondary fan on, it might just be muffling the noise. if not, ^ he could very well be correct.
Old May 31, 2012 | 09:01 PM
snoun83's Avatar
yea when the heat is on the noise is still there.
Old May 31, 2012 | 09:12 PM
snoun83's Avatar
-Nathan
I was thinking of that too but do you know off hand that a 97 max a/c compressor would fit on the 2000 max since it's almost a similar engine? My old 97 max was hit on the driver side quarter panel while it was park and i was thinking about taking it off of that one and put it on the 2000 max.
Old Jun 1, 2012 | 06:49 PM
dfj240's Avatar
Well, before you go through the trouble of changing it, because he's got a great point, if it's the clutch I would imagine the sound would go away when the compressor kicked on.
I would start the car, turn the AC on high, and then see if it still makes that noise when the compressor clutch disengages (compressor switches on). If the noise goes away, I would look straight at the clutch. If the noise continues, then I would look at the idler pulley (though it could definitely be something else).
In the case that you do need to replace the compressor, then the 97 will fit. Both compressors share the exact same part number.
Old Jun 1, 2012 | 08:55 PM
+1
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
