help someone ecu issues
Old Jun 2, 2012 | 06:43 PM
xxemranxx's Avatar
hows it goin guys
bought a maxima with burnt ecu
went got a another ecu and idle control and key and iginition from different runing vehicle
installed everything went to start ecu burnt
i sent original ecu to avpro to get fixed came in installed turn key in the ON position heard a pop in computer sta509a broke bad ecu
i dont know what to do next i sent ecu back to get fixed now i need help to figure out whats goin on
checked the idle control valve that on intake with
black and brown plug
ohm shows 36
Old Jun 2, 2012 | 07:07 PM
cjandura's Avatar
https://maxima.org/showthread.php?t=...ghlight=Sta509
Also unplug your electric motor mount behind radiator
Old Jun 2, 2012 | 07:34 PM
xxemranxx's Avatar
links dont work
Old Jun 2, 2012 | 10:07 PM
DennisMik's Avatar
You want to measure the resistance of 4 different coils in the IACV (Intake Air Control Valve). The connector has 6 pins in it, arranged in 2 rows of 3 pins. In each row, use the center pin as a common connection and then measure resistance to each end pin. I can't remember the exact resistance, I think it's around 25 ohms. If you have a shorted coil, the reading will be around zero ohms.
The 2000 Max with automatic transmission has 2 electric motor mounts, so un-plug them both. If you have a manual trans, ignore this, you won't have them.
Front motor mount connector -
Rear motor mount connector -
Old Jun 3, 2012 | 03:37 PM
xxemranxx's Avatar
checked ohm on the idle control valve
used row 1 pin 2 for connection
ohm reading
terminal
2 to 1=13.9ohm
2to3=00.2ohm
5to4=16.7ohm
5to6=21.1
used this to check
my idle is completely off the thottle body
Thanks Jay!
Old Jun 3, 2012 | 05:15 PM
DennisMik's Avatar
You have a shorted coil in the IACV. That's what's killing the ecu.
Old Jun 3, 2012 | 07:05 PM
xxemranxx's Avatar
so idle control is bad
i have a different one
ohm reading is
2 to 1=22.2
2to3=22.3
5to4=22.3
5to6=33.0
why is the last one so high maybe its bad also
Old Jun 3, 2012 | 07:09 PM
xxemranxx's Avatar
also how do i check the tps sensor would that cause a problem also
Old Jun 19, 2012 | 10:29 AM
Darkrock's Avatar
If you got it together great if not search "New ECU fried in seconds" very long posts (good information on a major design flaw) but this is no simple fix for the 5th generation. First, low 20s on the IACV ohms and also check continuity on each pin preferably with a Multimeter that sings. Second, the TSP, check starting pages EC-115 and EC-438 the key with the TSP is for the winding to be above the throttle pins and not below and I set it by continuity as in open or closed tricky but using those feeler gauges is impossible for me--be sure to note difference between switch and sensor . Also I am firm believer in "coolant bypass of the IACV" because the functional design is ridiculous (water and electricity?)
Old Jun 19, 2012 | 12:20 PM
andrewmac's Avatar
I've read the threads about frying the ECU a few times now, and I've seen it end up being the engine mounts. I have a 2001 A/T with electronic mounts.. would it be a good idea to just unplug them and leave them unplugged as a preventative measure? Would it cause the CEL to come on? (sorry to hi-jack, didn't seem new thread worthy)
Old Jun 20, 2012 | 10:28 AM
NmexMAX's Avatar
dot dot dot ...
Yes.
No.
gustavison
Oct 4, 2015 06:50 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
mix master
Sep 4, 2015 05:50 PM
