Torque Spec on Power Steering Banjo Bolt
Anybody know the torque spec on the power steering banjo bolt? I searched the threads and read the ones on the topic and could not find the info.
Also after I changed my hose and drove the car was smoking but my neighbor mechanic said it was just the fluid that ran on everything. Should I worry?
The banjo bolt with the guide nub on it at the end of the hose is 37-50 ft.lb. Your neighbor is probably right about the smoke. Verify that you don't have any fluid leaks just to be sure. An inspection of those components won't take long. Do it with the engine idling and the wheel turned a bit.
I did that hose a couple months ago, didnt Torque it though just put on snug, then a litle tighter with ratchet and no leaks at all sure its about 50lbs though, and on tge fluid did it go everywhere mine just went on LCA, but no smoke.....
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Thanks I poured some water down along the firewall on to the bars that run acroos and afte it sizzled a little the smoke seemed to stop. there are no leaks that I can tell. I dont think I did anywhere near 50 lb. Will check if is leaking.
The Frye
09-02-2021 11:03 AM
lowpost99
05-16-2021 11:18 AM
ag90fox
09-09-2015 12:22 PM
