Are these HID's?
Old Aug 22, 2012 | 08:41 PM
CWolfSE's Avatar
Are these HID's?
I have these headlights
http://www.monsterautoparts.com/nissan/maxima/_MAXIMA%20IMAGES/4221-0020L.jpg
Are those HID? Cause usually HID has ballasts to power them.
I'm 100% sure they are HIDs but the real question is if I order these light bulbs will it be as easy as plug n play into the stock housings
http://www.theretrofitsource.com/product_info.php?products_id=19006
Or do I have to get a kit
Old Aug 22, 2012 | 08:48 PM
ViRTualTeRRoRisT's Avatar
Those are HID's from what it seems like in the pic. The ballast seems to be the square piece underneath the assembly.
And depending if those are OEM replacements, the D2R bulbs should fit right in. OEM are D2R bulbs. Problem is that if those headlights are aftermarket, they might not take D2R bulbs. If they do, then its as simple as just popping them in. No extra things needed.
Old Aug 22, 2012 | 08:52 PM
CWolfSE's Avatar
Thank you that's all I needed to know. They are factory OEM supposibly so I'll purchase these bulbs right now and see if I was right.
Old Aug 22, 2012 | 08:54 PM
CWolfSE's Avatar
http://www.theretrofitsource.com/pro...oducts_id=3958
Would these be plug n play into OEM fogs?
And is the lighting output from these guys good compared to the factory stock bulbs ?
Old Aug 22, 2012 | 09:46 PM
Well if you buy the H3 one's, you'll have the right equipment, but you'll have to do some cutting into the back of the plastic on the fog so that the wires can go thru. So it's more of a retrofit than a plug and play.
I can't say much bout their output, but every single time I see that kit come up, I see nothing but positive reviews so they must be worth the pretty penny you have to shell out for em.
Old Aug 23, 2012 | 10:24 AM
OP, you got the right stuff to order
Old Aug 25, 2012 | 10:17 PM
CWolfSE's Avatar
Chrisman if I have OEM fogs.. Untouched.. Should I get the bulbs(link below) or will it not have enough power for them?... Because the kit (fog link above) is expensive
http://www.theretrofitsource.com/pro...oducts_id=4125
^ these plug n play Into OEM?
Old Aug 25, 2012 | 10:58 PM
In order to power the bulbs, you need the ballasts. In order to get the ballasts, bulbs, and power source to all work, you need the harnesses. Therefore, you need the entire kit, unless you already have ballasts and harnesses.
These bulbs will not work without a ballast. That link you provided is only for the blubs.
You don't have to get that kit. I purchased a Xentec HID kit for my fogs and it's been working fine for me. I'm not all **** about the lighting so if it does go out, I'll just go buy another kit. For as much as you're paying for just the bulbs from "theretrofitsource," I'm getting an entire working kit. Just my 2 cents.
Old Aug 25, 2012 | 11:05 PM
Won't work because..
Old Aug 26, 2012 | 08:27 AM
CWolfSE's Avatar
Oh ok and that's why I only need the bulbs for my headlights. So now I have to decide whether or not those fogs are worth it, cause I already am getting the headlights
Old Aug 26, 2012 | 08:35 AM
ATL's Avatar
ATL
bc thats the best ish money can buy right there. its not as cheap as an ebay kit like xentec or ddmtuning(like $60/kit), but the quality is the best available. the decision between the 2 is up to you and your budget. but if you can afford retrofitsource, i say go with them. like them on facebook to get alittle inside access on their future sales and new products. if you are ever in atlanta, they do public bbq's and stuff, they are really cool folks
Old Aug 26, 2012 | 11:10 AM
Your low beams are already HID, that's why you can just replace the bulbs.
The fogs are definitely worth it though. That's the only kit I recommend.
Old Aug 27, 2012 | 01:53 PM
DjHackStyle's Avatar
Oem hid bulbs are d2r and yes they are replaceble
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
