I am here to fix the Bose Sub problem once and for all.
Old Jan 28, 2014 | 05:31 AM
  #41
jdichter's Avatar
Brilliant thread. It's nice to see a few highly technical people on this forum. Thanks, worked like a charm.
"Success is more important than being right."
Old Mar 1, 2014 | 08:49 AM
  #42
quick-e's Avatar
I just completed this task. Thank you for the step by step. It sounds clearer. I have only been running for a few mins, but it normally cuts off by now. Thank you again for taking time to post step by step. Relay 10 bucks, desoldering iron 14 at radioshack with the suction cup.
Old Apr 6, 2014 | 12:21 AM
  #43
squiggtrust's Avatar
help
I have the same board with no relay any help can I still use the jumper ???
QUOTE=Donkeypunch;8871366]Does anyone have the part numbers for these missing components.
My sub has never worked, and now I know why.
Size:  73.8 KB[/QUOTE]
Old Apr 6, 2014 | 04:37 AM
  #44
max ride 41's Avatar
it amazes me how they changed the set up in the 5th from the 4th and you guys have all these issues. my stock bose had the infamous "error" message on the screen and then the front and rear speakers blew and i just replaced the whole set up piece by piece with jl's and a single din alpine and now double din touch screen pioneer with all the goodies. never wanted to try and fix the bose stereo cause i figured the age and i like modern equipment with a working cd player and a place to plug the ipod plus satellite. looks like at least you can thump away again with this fix.
Old Apr 6, 2014 | 05:34 AM
  #45
Outatime28's Avatar
+1 this is a brilliant write up, but I also switched to an aftermarket HU a while back and that fixed the cut out problem for me. For less than $100 in some cases, you can get a pretty nice mounting bracket, USB, aux and it really makes the Bose system sing compared to the stock HU. I think I'm going to switch to a line output converter setup soon because the stock amps don't have enough punch using the preamp outputs on the aftermarket HU. Off topic, but thanks again!
Old May 1, 2014 | 07:40 PM
  #46
bigblueowx's Avatar
sub quit
i'll mail u mine...what's ur mailing info?
Originally Posted by CaTalyst.X
Then send me your sub and ill fix it for free! And I'll use it to post a HOW TO so everybody else has what they need to get theirs fixed.
Old Nov 27, 2014 | 01:55 PM
  #47
Didi's Avatar
Mr.
Hello. I'm contacting you because I have no idea about my bose pcb assy 100W in my 2003 Infiniti Fx35. The sub woofer keeps coming on and off, I took the car to the audio shop and they advised that I replace the system. But looking at your write up I understand you can help me with repairs. I can't follow the instructions you outlined. .. no idea haha... but I don't mind sending it to your fit repairs even for a fee. ..I cannot afford to replace the system because it's expensive. Please send me your mailing address through my email nibaderrick@yahoo.co.uk, or phone number 9728388691. I'll appreciate it. Thanks, Derrick
Old Dec 2, 2014 | 06:06 AM
  #48
alahjahwan09's Avatar
Which wires?
Regarding the removal/bypass of the problem unit... Which wires need to go directly to the sub?
Old Dec 31, 2014 | 08:31 PM
  #49
bmpnride's Avatar
I have ben reading up on the many problems these bose systems have. I have a 2000 I30 and have a similar issue with the sub cutting on and off. I have swapped the factory sub but the problem remained so the sub was not the problem. I swapped out the amp and the problem was still there so its not the amp. I don't know what else can be the problem. My only next spot to check might be the relay that is separate from the sub amp on the I30. My HU volume sometimes does not work as well. Anyone have any suggestions where else I can look to try to resolve the issue?
Old May 8, 2015 | 06:07 PM
  #50
OK.Eric's Avatar
Thank you so much for this thorough guide to getting this fixed. I was able to do it last weekend and its been working perfectly all week! I'd say problem solved!
Old May 8, 2015 | 07:44 PM
  #51
Donkeypunch's Avatar
There's a separate circuit board before the sub that's wrapped in plastic.
Cut that open and re solder all the joints. That's probably the problem.
I wonder if nissan just did a crap job or maybe that's just the nature of solder?
Old May 8, 2015 | 08:23 PM
  #52
OK.Eric's Avatar
I blame Bose, they're a trusted name in audio equipment and Nissan trusted them to make a quality product for their cars. They did a ****ty job on some basic component connections and now we're dealing with the consequences of that. Luckily we have knowledgeable people on here that take the time to help other people correct these issues.
Best of luck to you bmpnride, I hope you can get it working like it should be.
Old May 9, 2015 | 07:03 AM
  #53
aackshun's Avatar
This is what all of my I35's amps looked like.
Any sollution to fixing this bad boy???
Old May 9, 2015 | 06:25 PM
  #54
^YUP.
Follow the wires from the sub. There is a small board that's covered in a plastic sleeve right before the speaker.
Cut that sleeve open and re-solder all the joints.
FIXED.
Old Jul 14, 2015 | 08:01 PM
  #55
Totalpckge1's Avatar
Fellas I just bought an 03 Max. My sub isn't working. When I put my hand on the bottom of it as music is playing I feel a slight vibration. Talk to me man what is the deal with this. Is this a relay issue as stated above or what? Talk to me.
Old Jul 15, 2015 | 04:19 AM
  #56
Prophecy99's Avatar
what else do you need to know? its a common problem... thats it, im fixing mine soon.
Old Aug 13, 2015 | 02:11 PM
  #57
Prophecy99's Avatar
jsut purchased the relay, thanks OP for taking such a motivated and noteworthy approach to fixing this and spreading the knowledge.
Gotta love the org.
Old Aug 18, 2015 | 05:46 AM
  #58
Prophecy99's Avatar
did this last night, and never de-soldered before, sub is bumping now !!!
to those learning, patience, it took me almost an hour of patiently trying little pieces over and over with braid/wick
link for panasonic relay still works and bought it directly from there
Old Aug 20, 2015 | 11:07 AM
  #59
Thank you!
Maxima Brothers! I just want to thank you for being a Maxima family and helping one another. Thanks to you guys I was able to fix my sub. It is bumping. But when i listen to the Bose system in comparison to my Infinity speakers and Pioneer radio in my 2000 Max, The Bose sounds like trash. I need to upgrade.
Old Mar 9, 2016 | 07:54 AM
  #60
Derrick2k2SE's Avatar
Some of the earlier pics of the 01-03 fix are no longer being hosted so I'm adding this for anyone else who finds this.
This is for the 01-03 where the relay is located inside the subwoofer case.
From inside the trunk.
*unplug the harness going to the sub.
*remove the three 1/4" (not metric) bolts holding the black speaker cover in place.
*unplug the two wires going to the speaker and bring the black cover to a table where you can work on it.
This silver box is inside the black cover.The harness wires are covered in a sticky wrap so you can just peel them off the silver cover. Remove the four Philips screws and remove the cover plate. It has tabs on the sides you may have to pry open.
This is the back of the circuit card inside. You don't need to access the other side. You can see the jumper soldered in place.
Close up of the jumper. Connecting these two points will bypass the crappy relay and bring the sub back on line.
Old Mar 9, 2016 | 08:33 AM
  #61
Prophecy99's Avatar
i did a the new relay method just in case anyone goes that route, all explained in this thread.
Old Jul 4, 2016 | 07:39 PM
  #62
tvetree's Avatar
LOL ( at me)
I was wondering why my bass went into over drive when the weather got hot.
After reading this I believe that it simply is not working at all most of the time. I got it new to me (no Kidding it is 16 years old now) and didn't know it was out or rather how much bass it could make...
Old Jul 5, 2016 | 01:23 PM
  #63
96SEmaxB's Avatar
Been running the card board trick advice the relay for 6+ months now...but nice write up
Old Jul 6, 2016 | 05:14 AM
  #64
Prophecy99's Avatar
been running a new relay for 12+ months, with peace of mind it was done legit. and i never have to think about it again.
great right up
Old Jul 19, 2016 | 02:21 PM
  #65
Roymg's Avatar
When my 00 sub quit working, I simply unplugged that device that goes to the speaker and plugged the wire directly into the sub. It works fine, but the only "drawback" is a little thump when the radio first turns on. Other than that, it works fine. The only complaint I have is the crazy rear deck rattling that goes on.
You could damaged your woofer with that extra thump. I wonder if anyone has tried drilling a very small hole in the relay case and then straying some electronic cleaner, assuming the contacts are exposed.
Old Mar 25, 2017 | 04:17 PM
  #66
SMILEY2017's Avatar
Will this work for a 2000 i30? I have a 00 and 01. I simply wanted to hook up my aftermarket 2 ch amp directly to the factory Bose Subwoofer. All factory stuff is cut and I currently have 2 12's in a humongous box that I would like to get rid of to get my trunk space back. I am also currently have a 4 channel amp for all doors and tweeters in it. Bose Sub and Amp are still in there but never have used them. I bought the car that way.
Old Mar 26, 2017 | 02:58 AM
  #67
DennisMik's Avatar
An aftermarket amplifier will not work properly with Bose speakers. It will overdrive the speakers and cause distortion because of improper impedance matching.
Are the door speakers still Bose? If the head unit (radio) is not Bose, which I tend to think is the case, the door speakers were probably changed out.
There are special adaptors that might be used, but until you tell us what the head unit is and what the door speakers are, we can't give you exact answers.
Old Oct 15, 2017 | 09:45 AM
  #68
CZ Eddie's Avatar
THE RIGHT FIX:
Since the stock NAiS is a CHEAP relay, we will replace it with a quality Panasonic model (available here):
http://www.mouser.com/search/Product..._-na-_-na-_-na
The relay is no longer available from that link but I found it here.
$7 + $4 shipping to USA from China.
http://www.ebay.com/itm/CQ1-12V-Powe...oAAOSwkthZmaJF
Old Oct 15, 2017 | 09:48 AM
  #69
CZ Eddie's Avatar
A little thump is not going to "damage" the stock subwoofer.
Subwoofers are made to thump. lol
Apply voltage to the speaker and it thumps. That's exactly what happens during music playback as well.
I say this with years of experience with the annoying turn-on thump in various car/home audio systems.
Old Jan 4, 2018 | 02:25 PM
  #70
Roymg's Avatar
Okay, forget the "thump" and think "pop" caused by a voltage spike. Not the same as being supplied a controlled voltage from an amp.
Old Mar 1, 2018 | 03:52 PM
  #71
RRack's Avatar
Updated Relay Availability?
Sorry for digging up an older post. Years ago, I fixed the amp in my 2003 FX35 with by wedging a snip of fuel line on top of the relay. Well, it's finally started cutting out again so I figured I'd do it right and go ahead and replace the relay. The problem is that the relays that are listed all show discontinued. Any idea of a current relay available? I pull it to check it but really didn't want to leave things apart. Any info would be greatly appreciated.
Robert
Old Mar 2, 2018 | 06:36 AM
  #72
Prophecy99's Avatar
i just bought the relay a couple years ago, just google the relay name and part number and shop that way
Old Mar 2, 2018 | 06:38 AM
  #73
Prophecy99's Avatar
i just clicked the link and it works fine, try harder.
Panasonic relay part number CQ1-12V
Old Mar 3, 2018 | 02:25 PM
  #74
DennisMik's Avatar
While the link works, the place no longer carries it. Here is a place that does:
www.alliedelec.com/panasonic-cq1-12v/70618122/
Old Mar 29, 2018 | 08:09 AM
  #75
Roymg's Avatar
Reserved for incidentals!
Here is the datasheet for the stock NAiS CQ1-12V-H19 Relay:
http://pdf1.alldatasheet.com/datashe...S/CQ1-12V.html
THE RIGHT FIX:
THE FREE FIX:
I don't recommend this fix, but it does work, and doesn't require buying another relay. I recommend doing the replacement relay fix, and fixing it the right way. This method just shorts the circuit out. Chances are, Bose put that relay there for a reason.
Here is a laymen's intro to how relays work:
http://pcbheaven.com/wikipages/How_Relays_Work/
As you can see from the illustration, by connecting the NO connection on the PCB to the COM connection on the PCB. We simulate the relay always connecting NO to COM (Which is what we want).
OTHER INFO:
2001 Fix Thread
2000 Fix Thread
Since the existing relay will be trashed has anyone tried to drill a small hole in the plastic relay box and spray some contact cleaner into the relay? I'm assuming the coil is good and perhaps the contacts are in need of a cleaning.
sctludwig
Sep 1, 2022 01:32 PM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
