new here having trouble stating my 5th gen maxima gle
Old Sep 30, 2012 | 04:38 PM
kamui124's Avatar
my car was running great, just a couple of days ago if was having trouble to start i kind had to step into the gas for the car to start, and it became more regulary and then today it complete didnt want to start, if i thought it was the baterry but a pull the cable and nothing, after a friend toll me that it sound that it my not getting enough gas, it is the fuel pump or filter or maybe the infectors,any suggestions
Old Sep 30, 2012 | 04:50 PM
ATL's Avatar
ATL
its easy to test your fuel pressure, your local auto parts store probably has a loaner pressure gauge.
what do u mean by "a pull the cable and nothing"? do your interior lights work? radio? does the motor try to turn over?
Old Sep 30, 2012 | 05:44 PM
kamui124's Avatar
sorry i met to say i turn the ingnition is try to start and it kind of does but will start to shake and will die .like it choke
Old Sep 30, 2012 | 06:45 PM
T_Behr904's Avatar
Could be a possible crank position sensor.
Old Sep 30, 2012 | 07:29 PM
CaTalyst.X's Avatar
Could be a battery....since it hasnt been tested.
Test the battery first, thats the easiest and most likely problem.
Old Sep 30, 2012 | 09:12 PM
Rcrootbeer's Avatar
Mine did that on and off since i bought it in July. It finally wouldnt turn over and died infront of my friends house. His dad is a repoman so he towed it to my driveway where I searched the forum and found that my starter is done. I, a 16 year old, replaced the starter by myself in the rain and it goes like a champ now. Long story short SEARCH THE FORUM. And im awesome, but thats besides the point.
Old Sep 30, 2012 | 09:16 PM
Ghost_54's Avatar
I was going to also say the CPS (crank position sensor) or it could also possibly be the sensor at the top of the gas pedal, I have read a number of threads where starting issues was the result of that sensor at the top of the pedal and was an easy fix by swapping in a used gas pedal from someone parting out a car.
Old Oct 1, 2012 | 06:31 AM
Montego Murph's Avatar
I just got done with a 2-year long hard starting ordeal.
Pay attention to what the engine does when it finally starts. Mine stumbled for a few seconds and rich black smoke came out for those few seconds. Turned out that my fuel pressure regulator and damper were bad. Then a week later the starter dropped dead because of all the extra cranking.
Old Oct 1, 2012 | 07:42 AM
kamui124's Avatar
i already swap the battery and it didnt work, i was thinking of changing the gas pump and filter but i want to be sure that is the problem.
Old Oct 1, 2012 | 07:50 AM
kamui124's Avatar
like a say didnt have any probelms went it run, just went it i turn it on, and also a lot of smoke would come out of the exhation and would shake for a like but once it start running was fine
Old Oct 1, 2012 | 06:55 PM
kamui124's Avatar
i just change the fuel pump and nothing, i have to go with the crank position sensor
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
