5th Gen. Brake Rotor Differences
Old Jan 1, 2013 | 07:57 PM
big-daddy-j-dawg's Avatar
Muchachos,
Pardon my ignorance. I tried searching on here and on Google to no avail. Any who, I have a question. Is there any differences between brake rotors spread out through the generation.
For example, I am looking through ebay trying to look for some Slotted (non-drilled) rotors and the majority of stores have
Nissan MAXIMA [10/2000 - 2001] Manufacturer Date 10/2000 - 2001
Now, is there any difference between the rotors through out the generation? Maybe a couple of shims here and there?
Thanks!
Old Jan 2, 2013 | 09:45 AM
coolsun's Avatar
5th generation 00-01 are different from 5.5 gen 02-03 fronts, thats the only differences. Front rotor and caliper
Old Jan 3, 2013 | 08:00 PM
Cool. Thanks brotha.
Old Jan 5, 2013 | 08:20 AM
CMax03's Avatar
00-01:11.0"
02-03: 11.65"
Both are junk!
upgrade to the 6th gen 12.6" setup> caliper, torque member, rotor preferably the 2005 on....
Old Jan 5, 2013 | 08:55 AM
Galactica's Avatar
Originally Posted by CMax03
00-01:11.0"
02-03: 11.65"
Both are junk!
Yeah except you can't with stock 00-01 17" rims...Gotta upgrade the rims too, then...
Old Jan 5, 2013 | 09:07 AM
noahrexion's Avatar
You sure about that? Is it diameter (ID of rim) or offset that interferes?
Old Jan 5, 2013 | 11:57 AM
Galactica's Avatar
It's the offset. The larger calipers won't clear factory 00-01 17's. They will clear 02-03 rims though.
Old Jan 6, 2013 | 03:40 PM
coolsun's Avatar
for the 01 don't you just need spacers? 10mm if i recall
Old Jan 8, 2013 | 09:44 AM
NmexMAX's Avatar
dot dot dot ...
It's debatable. Someone not too long ago was able to use the A34 Brake kit on his 00-01 with stock 00-01 SE wheels with no problem, no spacers.
All you need are the rotors and calipers (and obviously brake pads) from a 6th gen.
Old Jan 8, 2013 | 10:51 AM
foodmanry's Avatar
Da Roller Coaster!
FYI...2000 model year has a difference in the rear calipers, pads, or shims based on the VIN number (manufacture date). I found this out at the dealer early on in my ownership.
This applies only to 2000 model years and NOT the brake rotors.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
