Painting OBX Headers
I've ordered a set of OBX headers for my 5.5 and would like to paint them black before I have them installed. Has anyone had any success painting their OBX (or any) headers? What did you use to paint them? How has it held up?
I bought a set of used and beat up Cattman headers, cleaned them up and painted them. I put on multiple (admittedly sloppy) coats, and after a year of abuse only a small amount of one layer of paint has started to chip off one small section of the pipe when I had some paint runs. I would say they look 95% as good as they did right after I painted them, and had I done a better job of painting it would probably be closer to 100%. Here's my post I made in my build thread about the process:
This is what they looked like when I got them:
Then after much sanding....
I had originally planned to ceramic coat all three of the header pipes, but ended up being too busy and was only able to coat the actual header pipes. I used the silver VHT Ceramic Coat spray, and so far am pretty happy with the results. The headers have been on for more than a month, and while a small section of coating has peeled, there’s still another layer or two beneath it and it still looks silver. It took a few hours of sanding and using a wire brush to get the headers to a point where I felt like painting was appropriate. Immediately before painting I used a propane torch to burn off any oils left on the surface, and there was apparently plenty, as I could see it burning off. Now I’m not very good at any sort of painting, so I ended up with a couple runs in the coat, but overall I’m very pleased with the results.
After painting:
And hey, why not clean up and paint the bolts? Wire wheels are fun!
After painting:
I used the black VHT can stuff. Yeah, don't expect it to stay on the exhaust very well. But, that wasnt my goal anyway. I used it to protect welds and to coat underneath the header wrap I used. The VHT was then used overtop the header wrap to seal it from moisture.
I recommend either VHT, wrapping, then sealing wrap with good coat of VHT ......or, have the headers ceramic coated.
When I purchased the header for my other car, I followed the next procedure:
- Put it 3 layers of High Temp Paint
- Put in the Header Wrap
- Another 3 layers of High Temp Paint
3 coats of HT paint
Header Wrap and HT paint
It will smoke like an old steam locomotive for several days, but you will get a nice and pretty strong barrier against the heat and moisture. If you only paint it, will be OK. But it's your choice.
Greetings.
Yeah, mine smoked for a couple days but had that odd wrap odor for more like two weeks! I figured it was probably just cheap wrap. Nasty though! Didn't think it was EVER going to end!! LOL!!
I have the full Catman setup. All stainless. VHT has stuck just fine, and despite absolutely NO prep work. Any peeling on catback has been due to using only a couple coats of paint and typical unavoidable rocks/debri hitting exhaust while driving.
Thanks for all of the responses. I found a place locally that does ceramic and powder coatings. I'm going to give them a call and see how much it'll cost. If it's not too much I'll probably go that route, if it's outrageous I'll probably just use VHT.
Eastwood has special high temp brush on header and exhaust coatings
may i ask where did you order the headers from?
Just got my shipping confirmation in case you were worried about the whole "out of stock" thing that's been going around.
Says 8 are available.
http://www.ebay.com/itm/330865207641...84.m1497.l2649
one of the best coatings you can get, but it costs almost as much as the headers themselves..lol
http://swaintech.com/race-coatings/a...s-price-sheet/
REDinLV
08-15-2024 12:30 AM
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
