Fog Lights Upgrade?
Old Feb 22, 2013 | 07:55 PM
CauzinDrama's Avatar
Fog Lights Upgrade?
I was wonder if there was anyway to replace the factory fog lights lens cover (the fluted style) with anything that isn't fluted in my 2002? Maybe give a more clear look almost euro ya know.
Not sure if theres a different Nissan fog light that might work or if theres something after markert that is a perfect fit......Has anyone done some like this?
Old Feb 22, 2013 | 08:01 PM
user name001's Avatar
Whats fluted? Im confused by this whole post..have you looked on ebay? They have some projector style fogs. Kinda look like passat fog lights. Euro enough?
Edit: googled fluted, I gotcha.. ebay.
Old Feb 22, 2013 | 08:12 PM
Eh I had projector style on my last Mazda and I didnt like the light pattern. I find the projectors are more a "driving light" than a "fog light".
Old Feb 22, 2013 | 08:16 PM
See if you can fab up some 00-01's . I know there a bit different mounting wise, and im not sure if the dimentions are the same but, you might be able to swap the lenses?
Old Feb 22, 2013 | 08:19 PM
cjandura's Avatar
The xterra fogs are the same mount but with clear glass
Old Feb 22, 2013 | 08:21 PM
BAM!!!!!.. Thats the stuff im looking for......Lookin into this now. Thanx
Ok so I looked up the xterra fogs and yes they look similar. But rear mounting portion that mount into the bumper looks more oval and a tad bit different. Is there anyone that has used these on there car? does it require a little modification? I like the clearness of them and id like to use if it can be done.
Old Feb 23, 2013 | 06:45 AM
TallTom's Avatar
It looks like they swap out easily.
http://forums.maxima.org/5th-generat...-gen-fogs.html
I wish I could do the same for my 5.5
Old Feb 23, 2013 | 09:15 AM
cjandura's Avatar
The later model 04 ones fit the 5.5 i think
Old Feb 23, 2013 | 09:42 AM
Chris Gregg's Avatar
Get Off My Lawn
That would be nice. I've replaced both my driving light housings from Nissan this past year. Despite buying the plastic protective film, passenger has already cracked. Anyone actually done this swap that can verify fitment?
Old Feb 23, 2013 | 09:46 AM
T_Behr904's Avatar
How did you find this out?
Old Feb 23, 2013 | 10:10 AM
cjandura's Avatar
My elf wizard magic brain
Old Feb 23, 2013 | 10:26 AM
T_Behr904's Avatar
Of course!
Old Feb 23, 2013 | 12:06 PM
Get Off My Lawn
Oh mighty one, what is the extent of your powers! Will these fit 5.5 oh, wise one!?
Old Feb 23, 2013 | 12:23 PM
http://item.mobileweb.ebay.com/viewi...858&cmd=VIDESC
If you look at the compatibility list on that page it seems like the xterra fog fit the 00-01 maximas... I've seen this alot as far as the compatibility list goes.
So my next question is what is the difference between the 5th & 5.5 Gen fogs?
BTW I'm not looking to buy those on the page I listed.... only using it for reference.
Old Feb 23, 2013 | 12:32 PM
T_Behr904's Avatar
Front end is different. Different headlights, bumper cover, and fog lights. The fog light housings are a different size.
Old Feb 23, 2013 | 12:41 PM
OK so if the housings are different sizes from the 5th and 5.5 Gen the the 02-04 fogs wont work on 5.5 Gen if they fit the 5th Gen. Correct me if I'm wrong.
I don't know why someone hasn't found or made a clear replacement lens for us.
Old Feb 23, 2013 | 01:00 PM
cjandura's Avatar
i believe its the 03-04 6 cyl shupercharged ones that fit there is 3 different foglights between the 00-04 xterra
Old Feb 25, 2013 | 12:29 PM
CMax03's Avatar
The fluted 02-03 style is to spread the light as much as possible.....the best upgrade would be going from halogen to HID...IMO.
Old Feb 25, 2013 | 01:36 PM
Get Off My Lawn
Not so sure. I've got HID's and although nice indeed, it would be benificial to know if there is a quality replacement available as an alternative to oem. I've had two depot lights crack AND an oem Nissan replacement crack that also had the clear rubber protectant cover.
In regard to HID being in a housing not designed for it, I'm not convinced the fluted lenses are better over a clear lense, considering the design the stock 5.5 gen headlights. Not suggesting the driving lights with clear lenses (Xterra) are designed for HID (don't know), but I think there should be less glare.
Old Mar 4, 2013 | 12:31 AM
rebelhell's Avatar
Have you solved this yet? Both of my lenses are cracked and would be nice to replace with clear lenses.
Old Mar 4, 2013 | 01:59 PM
DjHackStyle's Avatar
yea man somebody figure something out, i replaced both fogs with TYC ones this summer and as of this month both are cracked (6 months). what a waste of time and money. anybody got a better idea?
Old Mar 9, 2013 | 02:45 PM
Ive been doing alot of looking back and forth on Rockauto and I cant see how the Xterra fogs fit our 5.5 Gens. For one the post that secure the fog light into the bumper are even close to where ours are. Secondly the bulbs are completely different, so a new harness would be required.....My guess is if ANYTHING we need to see if the assemblies are the same shape.... and if so then we switch out the lens?????? But I dont have the $$ to go out and buy lamps to experiment with.
So I purchased an HID kit for my fogs.... going to give that a shot. I know its not changing the look like a wanted to do but I want better lighting too.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
