G**damn f&%$#ing subwoofer!
Old Jan 12, 2002 | 04:25 AM
unlimitedZ [Patrick]'s Avatar
My subwoofer sucks (01 Max SE). The thing rattles like there's no tomorrow. I took it to the dealer three times. The first time, they "fixed it", with no difference. The second time, they replaced the entire subwoofer, which was moderately better for a few days and then worse than ever. The third time, they "tightened it up" and it sounded pretty good for a month or two, now its rattling just as bad as ever. I'm pretty sure there was a TSB on this but it doesn't seem to matter. If I pop the trunk and push on the bottom of the magent while I have the music bumping, the rattling stops. What's the problem here?
My old 89 Max SE with the Bose 6x9s in the back, no sub, had more thump than this POS.
Old Jan 12, 2002 | 05:47 AM
Ludacris's Avatar
http://www.fourthrock.com/maxima/reardeckrattleinstall/
Try his fix
Old Jan 12, 2002 | 10:20 AM
Telus.net
maybe they didn't surround the subwoofer with double sided adhesive tape......
Old Jan 12, 2002 | 10:30 AM
PhatGuy
Re: G**damn f&%$#ing subwoofer!
I have/had the same problem and the dealer did the same thing. It isn't the dealer's fault. Blame Nissan. Get yourself a second amp and some subs and dynamat back there... I'm in the process of this right now.
Old Jan 12, 2002 | 10:37 AM
Re: Re: G**damn f&%$#ing subwoofer!
I do blame Nissan, but I wish the dealer could fix it. I'm not going to spend any of my own money to fix the damn thing, that's for sure.
Old Jan 12, 2002 | 10:51 AM
ZIPPIN's Avatar
Mauja He Mauja
thats y i ripped out the whole system. $1000 bucks well spend on that freaking stupid ar$e bose the sub is a joke. i have the bose am-7 at home, and it is excellent. so i thought the car one would be good as well. if i would have known that it would freaking blow in a couple of years, neber would i have gotton it...
dynamat the rear deck,,,it might work ask y2kse,,,he would know
Old Jan 12, 2002 | 11:09 AM
00Semaxi's Avatar
I am mad also at the Bose system that i have in my car , the rattling s unbearable! I a currently changing out the system and using the bose speakers from the 97-99 maximas since the sound is 100X better. the dealer has no idea how to fix the problem!
Old Jan 12, 2002 | 11:25 AM
sascuderi's Avatar
My Fix
What I did was roll up pieces of cut up bath towels (used duct tape to keep then in a ball) and stuffed them under the rear deck around the opening of the Sub-woofer. Adding this tension to the deck stoppped the rattles. Has been quiet for a year now.
Old Jan 12, 2002 | 12:31 PM
LeoB's Avatar
rip it out..
...and get yourself and Infinity Basslink
Old Jan 12, 2002 | 01:39 PM
ZIPPIN's Avatar
Mauja He Mauja
Re: My Fix
nice idea,,,perhaps this should be a sticky
Old Jan 12, 2002 | 04:34 PM
LaXor's Avatar
Time to mod my SUB
Good idea and kudos. I will let you know how it went.
Old Jan 12, 2002 | 08:46 PM
MaxPower2K2's Avatar
i got mine fixed myself
if you look at the back dash you will see that the dash board is kind of short and it is very shakey
what i did was i took the dash out and i took owens corning insulation and insulated it and then i put it back on
and guess wat the rattle was gone
you can also take 5 pencils and stick them where the dash meet the window
that works too
hope i helped
Old Jan 12, 2002 | 10:27 PM
rob van dam's Avatar
hummm
buy aftermarket subs..the BOSE sub sucks....i blew mine out after a month!!....lol
Old Jan 13, 2002 | 12:17 AM
Blackgums100's Avatar
Re: hummm
Blown or not have Nissan fix it under warranty, don't let them slide.
Old Jan 13, 2002 | 09:01 AM
Re: Re: hummm
go to my homepage...then you'll see what i did to solve my problem with bass....
Old Jan 13, 2002 | 09:23 AM
ZIPPIN's Avatar
Mauja He Mauja
Re: Re: Re: hummm
don't u think jennifer lopez's ar$se is 2 big ,,,if you watch ANACONDA, you will notice that the camera stays away from her ar$e as much as possible,,,and when they do show it,,,,DAMN it's big,,,but now she has slimmed down a lot,,,which means smaller ( . ) ( . )
jskirwin
Jun 8, 2016 08:49 AM
sliptap
Sep 30, 2015 05:57 AM
starman9215
Aug 11, 2015 06:51 PM
