Went through another Axle again.....
Soooo I have a 5th gen 2000 DE-K 5Speed slammed on Tein street advance Coilovers and I JUST recently changed my passenger side axle in December and its April yet again it's making the typical clicking noise... When driving on the highway and vibrates the entire car I need suggestions on alxes that are stronger and better then OEM if anybody knows. Hit me up thanks (PS my wheel berings are also shot to **** any info on those is Also needed) thanks
non LSD tranny btw
non LSD tranny btw
I'm having the noise that just appeared three days ago...
you can go Raxles, they charge 180 for a rebuild per axle.
You have to send yours in and wait till they rebuild it. Now they accept only OEM axles for rebuild as others are "chinese crap" quote from the owner
Napa held up alright for me, but get new, not reman from them (68 for the drivers side for me and 80bucks!!!! core charge)
when you do a wheel bearing - you need a new hub as well - that's the way our knuckle is set up, I like Timken, otherwise - OEM
could be done at home with a grinder and a separating tool, presses back in with axle nut, but be careful
at the shop - I've seen prices start at 120 for the bearing job
Yooooo thank you bro im gonna look into the napa Axles tommorrow and send out my old Oem to raxle that sounds like a good deal! And for the Bering damn the entire hub has to be replaced???? I may look into Oem being low ruins a whole bunch of ****......
I thought that it is not required myself, but when I took mine apart - it was a horrible view
there is no point for going OEM with bearing, OEM hub is a good thing
just a heads up, at work we use Napa stuff and have had a few axles on 5th gens fail again months later. dont know if it was a weird coincidence or not but just a heads up, i would get the OEM rebuilt by Raxle
OP, a Maxima will go thru axles on a regular basis if it's slammed. Lift up the front a bit and take the pressure off of the axles to keep them from binding up, and you're good to go. However, if you're one of the guys that has to have his car slammed no matter what, then expect to be doing axles.
Just as has been said:
1) Raxles
2) raise the car up. You will end up not only burning through axles, but possibly going through axle brackets as well. See this old thread http://forums.maxima.org/5th-generat...e-bracket.html
1) Raxles
This...
http://www.am-autoparts.com/2000/Nis...hub-front.html
Think these will hold up well?
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
