5th Gen: What did you do to your 5th Gen today?
Old Jun 4, 2016 | 09:35 PM
  #2601
mrjamaica98mx's Avatar
After 3 years and a nice binus at workName:  IMG_20160601_005824.jpg
Old Jun 4, 2016 | 09:42 PM
  #2602
Got my i35 fixed
Old Jun 4, 2016 | 09:44 PM
  #2603
Infiniti fix not color matched but painting soonName:  IMG_20160601_130921.jpg
Old Jun 5, 2016 | 04:32 PM
  #2604
sebastian2041's Avatar
Took more things out put more things in!
Old Jun 8, 2016 | 10:59 PM
  #2605
nestorlugo's Avatar
I too took things out and put things in,just not as shiny
Old Jun 8, 2016 | 11:54 PM
  #2606
Child_uv_KoRn's Avatar
Bad *** Newb
PB blaster? I can't even ********** with that crap.
Old Jun 9, 2016 | 02:51 AM
  #2607
What test pipe did you buy?
Old Jun 9, 2016 | 07:01 AM
  #2608
nestorlugo's Avatar
I bought it from a local member but I believe it's just your average ***** ebay stuff!
This is not the California spec PB you try to choke the pecker with this you might loose your *******
Old Jun 9, 2016 | 12:04 PM
  #2609
Donkeypunch's Avatar
Try Acetone and ATF 50/50 mix.
It's the best break free for real. Google it.
I use it btw. You can see and hear the rust sizzle from the acetone and the atf is ultra
thin it'll work down into all cracks.
Old Jun 10, 2016 | 06:42 PM
  #2610
HerBlue2kSE's Avatar
Got the front control arms ready for the ES bushings. Getting the old bushings out was a real adventure.
Old Jun 10, 2016 | 09:05 PM
  #2611
Bad *** Newb
No oxy acetylene on hand? For shame.
That's my go to method (plus sawzall). It even gets women to stop by and ask what you're doing...
Old Jun 11, 2016 | 12:41 PM
  #2612
Can't afford oxy acetylene for this DIY car guy.
Parts from Rockauto arrived, got the manual trans mounts ready for the ES bushings , and picked up a different glove box from the local pick-n-pull.
Old Jun 11, 2016 | 07:21 PM
  #2613
VQ35maxima=Beast's Avatar
Put my cat back on, new alternator, tried to fix my exhaust leak but failed, will have to try again tomorrow.
Old Jun 11, 2016 | 08:23 PM
  #2614
96SEmaxB's Avatar
drama
New plugs NGK plat irrid
New coil
Removed bad alt (pain in the @$$)
Old Jun 11, 2016 | 09:48 PM
  #2615
tiyeeka2's Avatar
2003maxima is entirely too hott a/c
Been working on car for three days cleared lines changed compressor addede tons of 134a still hott I even changed the temperature panel on the dash.. still hott
Old Jun 11, 2016 | 10:22 PM
  #2616
New coil
Same here with the alternator, pain in the A$$.
Old Jun 12, 2016 | 06:32 AM
  #2617
Derrick2k2SE's Avatar
Yuck, looks like it's time for VC gaskets and tube seals to keep the oil off the plugs. This would have been a perfect time to do it.
Yeah, that alternator is a pain with the AC compressor in the way. It's always tempting to leave the compressor in and try to work around to it but in the end it always has to come out.
I think "clean windshield" needs to be added to the list.
Old Jun 12, 2016 | 12:04 PM
  #2618
i wish i remebered a trick my mechanic thought me for the alternator to come put fast 😩😩😩
Old Jun 12, 2016 | 05:06 PM
  #2619
cgilley's Avatar
In a death grip with the rear valve cover. Tired of smelling the oil leak plus I'm hopeful the new MAF sensor will help with the P0300 code. Got to go to work tomorrow, no pressure
Old Jun 13, 2016 | 05:55 AM
  #2620
DOODOOCHIP's Avatar
Swapped my cat for a straight pipe and got a magnaflow resonator to go with the megan exhaust.
Old Jun 13, 2016 | 12:18 PM
  #2621
96SEmaxB's Avatar
The gaskets are actually good, whoever replaced that plug before didn't tighten it down at all and it was arcing inside the tube, I'm surprised it never threw a code, and the coil that fell apart wasn't that one either, the coil never was lubed and it was some knock off brand to top it off...I went with masterforce but lubed the hell out of it
Old Jun 13, 2016 | 12:19 PM
  #2622
96SEmaxB's Avatar
Damn 10 amp meter fuse keeps blowing, couldn't find culprit so she's in the shop now....ulg
Old Jun 16, 2016 | 07:07 AM
  #2623
Worked on the auto-dim/compass mirror from a 2002 Max to add to my 2000. Also picked up a set of 2002 headlights complete to add after I get them cleaned up.
Old Jun 16, 2016 | 07:30 AM
  #2624
Itz Shak's Avatar
Had the infamous precats removed!
There are no cats on this maxima
This sound is now gone
https://goo.gl/photos/LRRKPR3d2FDZuiqs8
This sound now lives!
https://goo.gl/photos/yQBrJzvBcVbVVUPL7
Old Jun 16, 2016 | 06:54 PM
  #2625
nestorlugo's Avatar
Hey shak is that the megan catback ? Sounds niice!
Old Jun 16, 2016 | 07:13 PM
  #2626
Wow i thought when i bought my maxi it had the megan but from the video i see the megan letter whick i dont think mine has so i have the ebay cat back still sounds the same tho
Old Jun 16, 2016 | 09:03 PM
  #2627
Itz Shak's Avatar
Thanks! That's just the megan racing MDT Muffler with custom 3 inch piping.
Old Jun 17, 2016 | 02:15 PM
  #2628
Made my own version of the AE engine cover using a cover from an i30 and an old Nissan emblem on the shelf.
Old Jun 20, 2016 | 02:43 PM
  #2629
Guess I am the only one working on Maximas - Installed KYB GR-2 stuts with new boots and Moog bearing plates. The driver's side was so bad that it barely would decompress by itself. The passenger side was not much better.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-13450940_10207878506174433_8188549508991469743_n.jpg   5th Gen: What did you do to your 5th Gen today?-13428416_10207878505974428_6419949386270917694_n.jpg   5th Gen: What did you do to your 5th Gen today?-13450853_10207878478693746_1167567366547180427_n.jpg   5th Gen: What did you do to your 5th Gen today?-13495252_10207878478293736_8588024049434553566_n.jpg
Old Jun 21, 2016 | 01:34 PM
  #2630
Kevin Trout's Avatar
Today I installed a nylatron steering column bushing into my car. The install itself had a few parts that were massive pains in the butt, worst of which was removing and reinstalling the sleeve around the steering column inside the car. I ended up cutting it into 2 pieces and zip tying it back together, as I just couldn't get it positioned properly back into place after replacing the bushing.
There was one part where a second set of hands would have been great. It was pretty tricky to get the rear mounts for the steering column lined back up once the bushing was in place, it took a lot of grunting and swearing to do it by myself.
The finished result is sublime, I've been driving this car new since fall of 2002, and the steering response is so much more precise it truly feels like a different car. So far well worth a few hours of swearing, knuckle scraping and back wrenching. I have a lot of suspension mods already, (including sub frame connectors, lower tie bar II, subframe collars, illuminas, front and rear strut tower bar, rear sway bar, all 4 full poly motor mounts) and it feels like this is a central piece to the precision of the car. All that remains suspension wise is to replace the rear trailing arm bushings and install a QT link into the Scott Russel Link, and my car is fully transformed suspension wise. I intend to purchase a catch can and then get tuned (I have intake/exhaust/headers/block off plate/spacers/NWP throttle body/test pipe/3 inch exhaust) and that will finally complete my 13 year modding journey on this car.
Old Jun 21, 2016 | 08:51 PM
  #2631
Cotozic's Avatar
Nice man! I'm definitely in need of investing some more into suspension madness. I don't think your 13 year modding journey will be over even with all that stuff though
Today I took a joyride in my Max. Finally got everything back together and working properly again. Investing some time into researching new cooling methods for the sake of surviving the occasional slower summer driving with a massive heatsources right next to my radiator.
Old Jun 22, 2016 | 05:38 AM
  #2632
Got all the ES bushings pressed in to the lower control arms/mounts and motor mounts along with new ball joints so it can go back together. Also picked up a piece of stainless steel angle iron to reenforce the crusty radiator support.
Got some help with the bolt I twisted off as I removed the driver's side front ABS sensor and ordered a replacement for it.
Old Jun 22, 2016 | 07:48 PM
  #2633
Did some more work on the front end rebuild.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-13466503_10207893579431255_853414287988431828_n.jpg   5th Gen: What did you do to your 5th Gen today?-13516555_10207893579111247_2911100594502377155_n.jpg   5th Gen: What did you do to your 5th Gen today?-13532838_10207893579031245_8566142012493699201_n.jpg
Old Jun 22, 2016 | 08:48 PM
  #2634
maxiiiboy's Avatar
Kevin, this is quite interesting to me.
I would like to learn more about what you did.
I have the Stillen Front Tower Bar (FTB) and Rear Sway Bar (RSB) on my car. The RSB helped a LOT, but the impact of the FTB was less noticeable. The RSB did level the car, and it made handling so much better on smooth surfaces; the trade-off (an acceptable one to me) is some axle float on bumpy roads.
What improvements would give me the biggest bang or the buck next? I have been thinking about the subframe collar; now, reading your post this nylatron bushing is quite interesting to me.
Appreciate all/any comments and suggestions.
Old Jun 26, 2016 | 01:32 PM
  #2635
cornholio's Avatar
got rid of the ugly rusted battery tie down and finally put the new one in. +10 hp on this mod
Old Jun 26, 2016 | 03:10 PM
  #2636
maximatech12's Avatar
Adjusted the tire pressure to 35 PSI's instead of 20 PSI's.
Like the new engineered air pumps!
Old Jun 26, 2016 | 03:35 PM
  #2637
rvamax's Avatar
[QUOTE=cornholio;9116018]got rid of the ugly rusted battery tie down and finally put the new one in. +10 hp on this mod
Nice!
Old Jun 27, 2016 | 04:09 PM
  #2638
Roblee's Avatar
Replaced old spark plugs with new NGK power plugs and I noticed a HUGE difference, car starts much easier without stuttering and much less vehicle vibration while idling!
Old Jun 27, 2016 | 04:11 PM
  #2639
Roblee's Avatar
That's a clean engine bay bro! I think its time to hose mines down when I hit the car wash in a bit!
Old Jun 27, 2016 | 06:31 PM
  #2640
cornholio's Avatar
haha thanks bud, all i was seeing when i originally posted was all the dust on the battery and airbox. was thinking to myself i hadn't cleaned it in a while
