Engine knocking
Old Jun 8, 2013 | 10:25 AM
rpm911's Avatar
Engine knocking
So this 2002 maxima has been in the family for a while, it has 139,000 miles
and I have to put in $20 highest grade gas just about everyday just to drive to work and back which is a 40 minute total there and back.
Even with high octane gas the engine still knocks like crazy and if i put in low grade....forget about it...
Ive tried octane boosters from auto zone and it helps very litte.
So a couple questions:
Does anyone have engine knocking problems?
Anything I can do to help fix it without repair?
Is anyone elses car a gas guzzler or is that common with mostly city/town driven maximas
Old Jun 8, 2013 | 11:07 AM
SSJRICH's Avatar
Simply, No.
Gotta pony up some denero if you want to fix the problem. All the high octane gas and octane boosters in the world is not going to fix your problem.
Old Jun 8, 2013 | 12:40 PM
cjandura's Avatar
Make a video of the noise alot of things can cause knocking
Old Jun 9, 2013 | 01:48 PM
TravisCadello's Avatar
Run colder plugs and possibly take to dealer n retard timing all knock will be completely gone under $80.
Old Jun 10, 2013 | 08:02 AM
Gemner's Avatar
wait you drive 40 mins each way and have to fill up everyday? WTF? Can you put a mileage on that? Cause if youre driving 80 miles each way (120 MPH) that might make sense, but if you are driving at any reasonable highway speed or anywhere near any speed limits that is absurd. I commute more time than that and fill up about once a week
what is $20/gal gas?
what country are you in?
Old Jun 10, 2013 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
Spark knock or rod knock, huge difference.
Nice catch Gemner. I thought those numbers sounded strange/suspect.
Old Jun 10, 2013 | 12:28 PM
a33nismo's Avatar
Please take a video so we can better help you with the noise.
Also is it making the noise at idle or just under load?
There can be a few things making the noise but really depends on if its a knock or a ping.
Lastly are there any check engine light codes?
Old Jun 10, 2013 | 12:56 PM
TallTom's Avatar
He puts in $20/day for gas which would be about 5 gallons, give or take.
Old Jun 10, 2013 | 03:19 PM
Little less then 20mpg..same my 5speed 3.0 gets with every o2 sensors fried..
Old Jun 12, 2013 | 10:57 PM
MaxinO2's Avatar
I had knocking, turned out it was my piston ring. After a while it lost complete compression and I had to swap a different engine. Let hope that not you problem.
Do you have to add oil every so often?
Old Jun 13, 2013 | 07:27 AM
Gemner's Avatar
he has a 3.5, the answer to whether he has to add oil or not is almost invariably yes but on a 3.5 thats not an indicator of a dying engine unless hes burning a ton of oil
Old Jun 13, 2013 | 12:09 PM
NmexMAX's Avatar
dot dot dot ...
I don't.
131k, build date 10/02 ... 2k on current oil change, and about 1 month, at lesat 6800 RPM daily. Come to think of it, dang, alotta miles in one month. FMFS
Old Jun 13, 2013 | 12:53 PM
dwapenyi's Avatar
Originally Posted by NmexMAX
I don't.
Sixty EIGHT hundred RPM? What ecu mod are you running?
Old Jun 13, 2013 | 02:09 PM
cjandura's Avatar
Flux Capacitor warp drive unit from Kalco...
Old Jun 13, 2013 | 02:40 PM
rebelhell's Avatar
I'd love to push my rev limiter to 6800, or even 7000. I think the VQ can take it without a problem. 7000 rpm may just keep you from having to shift to fourth in the quarter. That'd shave a tenth or two. :-D
Old Jun 13, 2013 | 03:36 PM
NmexMAX's Avatar
dot dot dot ...
She'll do 7100. Technosquare.
General consensus seems to be that # is safe, after that, rod bolts would be a smart/wise investment.
And with those, 7500 seems to be the next general consensus. 1:32 is pretty cool. Only internal mods are said rod bolts.
Sorry OP for the digression, carry on.
ballerchris510
Sep 23, 2015 08:46 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
