Advance timing with android phone?
Old Jun 16, 2013 | 08:14 PM
  #81
jr schultz's Avatar
I just bought the app and an ELM 327 linked at the end in page two. I have the 2* timing advance already done, but I'm going to do this to my buddy's Nissan Titan. It will be nice to use the app for future diagnostic as well. Thanks for posting this.
Old Jun 17, 2013 | 06:45 AM
  #82
TallTom's Avatar
Originally Posted by MrEous
If you're having pinging/knocking there's probably a larger issue you need to look into, rather than using the program as a band aid. IJS
True, but it would be nice to be able to retard the timing to troubleshoot to see if it improves.
Old Jun 17, 2013 | 10:55 AM
  #83
MaxTones's Avatar
Originally Posted by JWatZ
...Checked the info for the update and it says Nissan 2001-2007 with kwp2000 support...
So this doesn't work for the 2000? I thought the ECU was the same for 2000-2001.
Old Jun 17, 2013 | 10:57 AM
  #84
jr schultz's Avatar
So, at the moment this will work for any Nissan 2001 to 2007 according to the App description. Has anyone tried this on a 6th gen Maxima or any other Nissan's? I'm assuming the developer will make this work for a more wide varety of makes and years, and then they'll update our app?
Old Jun 17, 2013 | 11:27 AM
  #85
MrEous's Avatar
^ Jeff™
I have an '08 Pathfinder as well. Will try out when I get my ELM referenced in here.
Old Jun 17, 2013 | 11:43 AM
  #86
Amerikaner83's Avatar
Too bad my 99's not supported
Old Jun 17, 2013 | 12:55 PM
  #87
Chris Gregg's Avatar
Get Off My Lawn
Perhaps I missed something skimming this thread, but your car is OBDII, why won't this app and Elm dongle not work on your '99?
Old Jun 17, 2013 | 01:52 PM
  #88
I have AN app and dogle, and it works fine. I just can't advance timing or change anything. I can monitor, but not change.
The special app that lets you change timing that was referenced is good for 01-07 according to an earlier post
Old Jun 17, 2013 | 02:35 PM
  #89
cjandura's Avatar
Just try it
Old Jun 17, 2013 | 02:54 PM
  #90
Originally Posted by cjandura
Just try it
yeah, I might just do that.
Old Jun 17, 2013 | 03:23 PM
  #91
ateick's Avatar
I advanced mine today. Took awhile to figure out the ins and outs of that app but got it done. Showed -1 degree of timing to start. Advanced it to show +2 degree. Did anyone else show -1 degree to start?
Old Jun 17, 2013 | 03:37 PM
  #92
rebelhell's Avatar
Mine showed -1 to start. Just changed it to +2 and been driving her all weekend without any problems. (I also verified the timing advance with Torque Pro).
Old Jun 17, 2013 | 05:38 PM
  #93
JWatZ's Avatar
That is what the app states, but I don't see why it wouldn't work on any obd2 Nissan. Any guinea pigs? It is my understanding that 4th gens don't hold the timing advance though, if I read that correctly in another thread.
Old Jun 17, 2013 | 05:55 PM
  #94
ColombianMax's Avatar
Just ordered myself the Elm scanner and shall be receiving it on Wednesday!
Old Jun 17, 2013 | 05:59 PM
  #95
Pearl93VE's Avatar
I can has?
Me too! Will report back once the deed is done. Went with the mini.
Old Jun 18, 2013 | 04:43 AM
  #96
JWatZ's Avatar
CauzinDrama, you got a reply from Isaac. Cannot retard RPM, apparently not supported by our vehicles.
I'll admit that I'm slacking and need to still get him a debug of timing. Anyone want to play with the list and try 254 and 255 to see if it retards timing by - 1 and - 2? My schedule is crazy right now. I'll try to do it on my break today if nobody gets to it.
Old Jun 18, 2013 | 04:51 AM
  #97
CauzinDrama's Avatar
Update ur app man. If you update then go to adjust timing and look at the "list" you can now - 2,-1,0, +1,+2... I haven't tried it as I haven't had time either....
I'm also trying to get issac to debug my connection issue. I keep getting a time out or no response message across my screen....
Old Jun 18, 2013 | 07:16 AM
  #98
JWatZ's Avatar
I just did the update, it works. At -2 it bounces from 13-14 degrees.
You doing idle air relearn at operating temp? That might be your issue. I was getting the same at first back when I first tried it with this app (before the Rpm and timing adjustments were added) but then I was successful after doing again after a drive.
Old Jun 18, 2013 | 07:23 AM
  #99
I have tried with the engine at operating temp. I also got a p0507 "idle higher than expected" code. Which s why I want to negative the RPMs. I'm still idling around 900
Old Jun 18, 2013 | 08:07 AM
  #100
ateick's Avatar
What is normal idle rpm?
Old Jun 18, 2013 | 08:30 AM
  #101
jr schultz's Avatar
For those that ordered a ELM 327 from ebay how long did it take to show up at your door? Mine says its coming from China.
Old Jun 18, 2013 | 08:32 AM
  #102
I ordered mine from a US seller, had it in 5 days
China usually takes 2 to 4 weeks
Old Jun 18, 2013 | 08:35 AM
  #103
TallTom's Avatar
I believe it is 650-675rpm.
Old Jun 18, 2013 | 08:45 AM
  #104
JWatZ's Avatar
Originally Posted by talltom
i believe it is 650-675rpm.
^ +1
Old Jun 18, 2013 | 09:48 AM
  #105
ateick's Avatar
Hmm. I'm up in the 820-850 range. Will Idle Air Volume Learn or Idle Rpm Adjuster reduce idle Rpm to normal range? Has anyone used the app for this and was it successful?
EDIT: Just checked the FSM. Idle speed: MT 625 +-50rpm. AT 675 +-50rpm. Mine is still too high so I will try the app and if that fails the manual pedal dance.
Old Jun 18, 2013 | 09:58 AM
  #106
No luck with it here....
Old Jun 18, 2013 | 11:38 AM
  #107
LongoTE's Avatar
Does anyone know of a program for a computer to advance timing? I've had an adapter for the longest time but don't have an android.
Old Jun 18, 2013 | 11:58 AM
  #108
Mikel81's Avatar
If you have bluetooth on your computer maybe using an android emulator would work. I think the official one comes with the android sdk. You would have to get the app still though and I don't think you can use the play store on the emulator so you'd be looking for the latest apk file. I understand this is probably a bit much for someone who hasn't used android, but I just figured it was a possibility. Also you could get a cheap android phone or mp3 player on ebay and just use that.
Old Jun 18, 2013 | 12:33 PM
  #109
ateick's Avatar
So to recap I have an idle of around 820-850. With the car off I tried the Idle Air Volume Learn option of the app and it gave me a Successful response. Unfortunately when I started back up the idle was still 820-850. I then used the manual pedal dance. Upon start up the idle went to 675 but as soon as I restarted it is back to 820-850. Both methods seem to be working initially but the idle just won't stick.
Old Jun 18, 2013 | 04:03 PM
  #110
JWatZ's Avatar
Edit: just for curiosity while sitting on the toilet, I digged a little. Read these threads:
https://maxima.org/showthread.php?t=589177&styleid=5
https://maxima.org/showthread.php?t=633601
Do some searching around about idle air relearn. You may find the thread I referenced earlier about pulling the battery cable right after you do it. This supposedly is needed for it to stick. But in drama's case, I don't know. Not sure if the code he's throwing has anything to do with that or not.
Old Jun 19, 2013 | 04:02 AM
  #111
thank you for finding that thread, that last post is the same exact is what's going on with me, plugs spacers high idle code. seems like I need to have my car down for a day or two in order to fix this. Hard to do when you're working 65 hours a week 6 days a week.
I'm going to try to do the idle relearn then disconnect my battery for the day today while I'm working. I'll report back my findings.
Old Jun 19, 2013 | 05:09 PM
  #112
barristan's Avatar
Could one of these dongles cause a code? I got mine today and I ran a test in Torque Pro and it found one code. I looked at my dash and the "check engine" light was on. P0300 - Ignition System or Misfire
Old Jun 19, 2013 | 05:29 PM
  #113
JWatZ's Avatar
Not to my knowledge. I've never had a code pop up because I used a dongle or a code reader. Coincidence maybe.
Old Jun 19, 2013 | 06:01 PM
  #114
barristan's Avatar
how do I clear the code?
nevermind. found it
Old Jun 19, 2013 | 06:21 PM
  #115
OMG I got my idle back to 650!!!!!!!. This whole time I was turning the ignition off after the final step when your supposed to start it right up.... Holy wtf..... Lol
Old Jun 19, 2013 | 10:49 PM
  #116
1992maximase30's Avatar
Does anyone know why the ignition timing resets on the 4th gen. Im thinking about getting this device to use on my i30
Old Jun 20, 2013 | 01:03 AM
  #117
Finchum's Avatar
So I have two LG Enlighten's at my disposal.
Can I purchase this:
http://www.simvalley.us/elm327
and the car gauge pro app:
https://play.google.com/store/apps/d...GaugePro&hl=en
and advance my timing?
for about ~25 bucks total you cant beat that!
I have an iphone4 now. I searched and found the same type connectors and apps available for it, but nothing that says out right that it can adjust ignition timing. Anyone know of anyone using an iphone for this same purpose?
Old Jun 20, 2013 | 03:50 AM
  #118
BronxSleeperMax187's Avatar
Gopoint app for iphones which is free and A 100 dollar bt1a connecter
Old Jun 20, 2013 | 04:20 AM
  #119
barristan's Avatar
I can't seem to locate the timing advance option in Car Gauge Pro. What protocol adapter should I select? I left it on automatic.
Old Jun 20, 2013 | 04:23 AM
  #120
JWatZ's Avatar
Just make sure your elm327 has kwp2000 capabilities. Whether for iPhone or Android. Wish I could help from the Apple end, but my wife got rid of her 4S to get the Galaxy S3.
For what it's worth, I never found an app for android that did this when searching and searching. I had this app for a while and one day the developer just pushed the function through because it was requested.
When connecting select these: Nissan, ECM (gasoline), 10 (should be the only option). Go into OBD Menu and select Self Test. There you will find the relearns and adjustments. I also keep my protocol on Auto and have no issue. Could always send Issac a debug log if you're having issues. Follow the link I previously posted and tell him about your issue.
